Solahart hot water system (Blackchrome flat panel) no longer heats up. Any ideas on what the problem is?
It made gurgling noises for a while, but no longer shows any sign of life. System is about 16 years old. Its a thermosyphon type, and so it seems that the thermosyphon is apparently no longer working. Why would this happen, and can it be fixed? The only heating is now by the electric booster.
  • 451 Answers
Gurgling noise indicate air in the system . To properly circulate all air must be removed from system . Purge system and see if that does the trick. Hope this helps.
Posted on Dec 29, 2013
SOURCE: Goodman Condenser - Heat - Buzzing Noise every 60 seconds
You stated capasitor was checked . if cap. is ok sometimes start terminal wire will burn into at compressor or you may have a loose connection causing a voltage drop (more than 10%).If both check ok try a hard start kit. Who knows it might start. good luck
Posted on Jan 20, 2008
SOURCE: i have a brivis buffalo
u can down load a manual from brivas it has the trouble shooting page in the PDF
Posted on Oct 07, 2008
The HVAC Guy
  • 30 Answers
SOURCE: Goodman GSH130301AB heat pump with
the reversing valve wire needs to be on the o terminal.nothing will be on the b terminal on the thermostat
Posted on Oct 30, 2008
SOURCE: Heat Pump/Furnace Trip Circuit Breaker
My system will run for a short period and then suddenly trips the circuit breaker in the main panel for the heat pump.
I have a Goodman - 3 ton system about 8 - 9 yrs old. I'm being told that I need to replace the heat pump/air conditioner compressor?
What do you think?
Posted on Dec 07, 2008
SOURCE: Intertherm heat pump blows hot then cold then hot
heat pump runs for 10 min. then cuts off. will not run over 10 min.It is a INTERTHERM.could it be the defrost control
Posted on Dec 04, 2009
Why does a 2005 dodge caravan gurgle when turned off?
that indicates that the engine is on the point of overheating
when the engine is turned off the water is no longer circulating around the cylinder walls and head and the heat from those items makes it boil off hence the gurgle
Dec 28, 2015 | 2005 Dodge Grand Caravan
Freezer gurgles
    • Give it mouth wash lol
      Check the water valve on the back of the refrigerator if it has an ice maker. Make sure the valve is turned completely on and not constricting the flow of water to the refrigerator via the water supply line. You might also hear a simultaneous buzzing sound when the gurgling noise occurs. In some refrigerator models, this filling process is on a timer, and you might hear the buzzing and/or gurgling every 15 minutes or so.
    • Check the water supply line for leaks or damage. You might see a puddle of liquid on the floor. If air is pulled into the water line as the refrigerator is pulling in water, that can create a gurgling noise. Replace the damaged hose yourself, or contact an appliance repair technician for assistance
      • f he refrigerator to feel a slight vibration. This is probably the compressor processing the refrigerant, which is a liquid. This flow of refrigerant can produce a gurgling sound, and it is normal. However, a simple way to reduce this noise is to make fewer trips to the fridge. When you open the door, you let hot air in, which means the compressor has to work harder (and gurgle the refrigerant more) to cool things back down.
    • Wait while the refrigerator completes its defrosting cycle if you hear water dripping and gurgling in the freezer area. When the heating coil turns on, the melted water from the frost flows down to a drain pan for evaporation to take place. The defrost process usually takes about 30 minutes. This is automatic and cannot be prevented in most refrigerators. Keep the closed to try to prevent unnecessary frost buildup.
    • Wait while the water equalizes in the refrigerator if you hear a gurgling sound when shutting the door. This is normal and is a result of air being forced through the drain tube. The gurgling can last several seconds but should eventually dissipate this usually happens with old fridges upgrade its a good investment
Dec 10, 2013 | Freezers
Clicking noise no heat
Cloged /stucked hot water tap ,the command does not open way for hot water.Must track the tubes,wires to find the tap.Cloged water system.Cleaning aditive several times it's a luck shoot
Oct 24, 2013 | Audi Cars & Trucks
Hi have a 2004 freestar I changed radiator-, water pump , thermostat, engine coolant if I drive on flat street my van runs good temp is normal but if I go uphill the gauge goes up to almost red once I...
Sounds like a faulty temp guage/r a strange malfuntion in a sensor to me as well, only doing it when it going up hill really makes no sense for the way the cooling system works so I doubt that its actually running hot, which is likely why he asked about the gurgling noise, it would force water back into the resivoir if it was running hot assuming that the thermostatic radiator cap is working properly.
Sep 14, 2011 | 2004 Ford Freestar
Car heating up faster and fan has been over-running / running on when engine turned off, intermittant gurgling noise from coolant bottle area, which when I checked was empty so filled it up. Fan no longer...
Change the thermostat and make sure you blead the system of air and if it still keeps heating up then you have a bigger problem and that is the head gasket.
Apr 08, 2011 | 2006 Mini Cooper
2005 Kia Sorento gurgling noise behind dash
Check the water coolant level because some of the hot water goes into the heater radiator behind the dash. Seems you have air in the system.
Mar 30, 2009 | 2005 Kia Sorento
Service Manual required
I would look on the water heater and find the city and state it made and call them.
Mar 13, 2009 | Water Heaters
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
