Front load washer reading code and tech told me that is the pump?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 129 Answers
NORMALLY YOU HAVE TO EMPTY AND CLEAN THE PUMP AND MAKE SURE THERE IS NO BLOCKAGES IN THE OUTLET TUBE
Posted on Dec 29, 2013
  • 1 more comment
  • Fortunata Dec 29, 2013
    Cleaned the pump everything looks ok
  • Fortunata Dec 30, 2013
    Checked all connections and the pump and still having the problem of F06-E-02
  • william nixon
    william nixon Dec 30, 2013
    A SITE I VISITED FOR YOU SAID THE CODES WHERE A MALFUNCTION ON THE MOTHERBOARD AND WOULD COST ABOUT 150 TO FIX SO MAYBE YOUR WARRENTY WILL COVER
5 Suggested Answers
SOURCE: Technical problem with washer Read out F-24
unlock child safty lock
Posted on May 13, 2007
  • 537 Answers
SOURCE: whirlpool duetsport front load washer
Check the following link:
http://fixitnow.com/wp/2008/09/27/whirlpool-duet-washer-with-f-21-fault-code/
Posted on Nov 08, 2008
blueextc3221
  • 15935 Answers
SOURCE: washer codes F01/F33, have cleaned the pump and
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 28, 2010
SOURCE: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
loud sound during the spin cycle in high revolve, after wash and rinse.
Posted on Jan 17, 2013
Error code F02 on whirlpool
There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
These are very simple repairs that you can perform yourself without the assistance of a repairman.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
NOTE: If you experience any error codes on the front panel, they are not listed in the owner's manual. For an explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and if you have questions, please post back and let me know. I hope you find this information helpful.
Aug 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer will not drain - got error message F21 - was told to clean filter - where is filter
"F21" is a Long Drain error code. This is usually an indication that you may have an obstruction somewhere in the drainage system. Most commonly, there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608588-f21_error_code
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing such as socks or under garments can become lodged in this area as well causing the drain cycle to fail.
NOTE: A "SUD" error code can also often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error (if displayed) should go away.
These are both very simple repairs that you can perform yourself without the assistance of a repairman.
NOTE: For an explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
Read through the information provided and if you have questions, please post back with your complete MODEL NUMBER. I hope you find this information helpful.
May 27, 2010 | Kenmore 43142 Front Load Washer
We have a front load duet washer. it will stop
This is a Suds Detect error code. The following link explains the error and potential causes:
http://www.fixya.com/support/r3608687-sud_error
The number one cause of the error is from using too much, or the wrong type of detergent. You are required to High Efficiency (HE) detergent with these washers because the concentration is formulated for HE washers that use small amounts of water. Using the wrong type of detergent can also void any warranty you may have.
NOTE: HE detergent does not have a lot of suds, which often confuses consumers into thinking they aren't using enough detergent. With HE washers little to no suds if normal and preferred.
Secondary causes can come from something restricting the drainage system. Most notably, something lodged in the drain pump and/or drain hose(s). I've included a follow-on link that explains how to check the drain pump reservior if required.
Each one of these washers come with a technical data sheet inside.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it from time to time to troubleshoot your washer.
Read through the information provided and let me know if you have any further questions. I hope this can help you. Read through the link provided and let me know if you still have questions. I hope this helps you.
Apr 24, 2010 | Washing Machines
GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Feb 07, 2010 | GE WBVH6240F Front Load Washer
Wont drain
sounds a bit pricy for a pump, but they can be damaged any time from contamination (i learned not to wash my aicraft mechanic clothes in there with aluminum chips which embedded into the pump) always empty all pockets!
Aug 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Whirlpool front loader duet sport washer door will not open
without complete f code hard to pin cause but suspect pump not pumping out remove bottom cover reach up to lock area pull small tab down to unlock door remove as much water as possible remove pump clean out by turning counterclockwise clean pump and connecting hoses reassemble and ck
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Thank you!!
"F09" is a "Flood Condition" error code. The following link explains this:
http://www.fixya.com/support/r805532-f09_error_whirlpool_duet_kenmore_elite
Read through the information thoroughly and verify all the recommended steps. More than likely you have a drainage issue with the drain pump as a possible culprit.
If you need to check the drain pump for obstructions, the next link explains how:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Let me know if you require additional assistance. I hope this helps you.
PS All the fault codes are normally in a tech sheet provided by the manufacturer. This tech sheet is usually placed inside the washer behind the lower panel, or affixed to one of the interior cabinet walls.
Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
Problem with operation of front load washer
chance are you have a clogged pump follow take front lower panel off screws near the floor on the pump is a slit open the slit on the pump and you will see the filter if it is clean follow the next instructions.
take the front lower cover off and there is a tech sheet in there look at it and it will tell ya what the code is for and how to correct it I cant remember this code off the top of my head and all the brands have different codes.I have about 5 three ring binders of tech sheets in my van if you cant find it i will look it up for you once you find this sheet clear the code and run it through diag.mode the sheet will tell you how to put in in self or automatic try auto. good luck.for get the code thing i just answered a code question but run it through this test to see if unit is working ok other wise
Sep 24, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
