Question about Rayovac Highbeam Flashlight 1 Watt Luxeon Led Flashlight with Batteries
Bulb replacement maglite mini
Corroded
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
You have to take the top apart, bulb just pushes in once you get to it. make sure you clean it with rubbing alcohol after replacing
Posted on Dec 29, 2013
HOW TO REMOVE CORRODED AAA BATTERY FROM MINI MAGLITE?
Try some baking soda with a few drops of water, it should loosen it up.
Oct 08, 2014 | Mag Instrument AAA Mini Maglite...
I have a 3AA LED mini maglite with stuck batteries. The best I can tell they have not leaked. I tried freezing the unit as well as heating the barrel to no avail. Is there a way of removing the bulb...
well, I have a 3 cell mini maglite AA with a corroded battery stuck up next to the LED. I have searched but not found a way to remove the LED to push out the battery with a dowel. The best solution I read about was to drill a hole in the battery and insert a large screw and pull it all out.
(My Maglite is from 2009 or 2010, but I think they made this model in 2011, 2012 and 2013- this is for SEO!)
Sep 13, 2010 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
I have a mini maglite - and I cannot remove the batteries. For the price, these certainly can't be disposable lights! Only the narrow end of the light can be removed, the bulb end does not enable you to...
Try tapping the base of the torch gently on a table, this may dislodge the batteries . Possibly the batteries leaked and corroded and became wedged in the torch ?
Aug 05, 2010 | Garden
Is there a rear cap on a mini maglite. I am
Yes there is a cap. I had the same problem most likely the battery inside has corroded and leaked fusing the cap shut, contact MagLite at www.maglite.com if there were either Duracell, Eveready or Ray-O-Vac batteries in there they will replace it for free under warranty.
May 26, 2010 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
HOW DO YOU PUT A BULB IN A MINI-MAGLITE?
Unscrew the lense, pull bulb out replace with new one. Normally an extra one is in the end cap in a plastic tube. be sure not to touch new bulb with hands use a tissue.
Oct 09, 2009 | MagLite Camping, Backpacking & Hiking
How do you change the bulb in a mini maglite?
Carefully.....
Check in the base of the torch and you will see the spare bulb. you need to pull the spring out to get at it.
Next unscrew the top off the torch to expose the bulb.
The bulb is easily removed by gently pulling straight out. Replace the new bulb in the same way, lining the two pins up with the holes (doesn't matter which way round) and wipe the bulb clean of any finger grease etc.
Screw the top back on and replace the spring in the base before screwing the base back on..
Replacement bulbs, and all other parts for that matter, are easily sourced at any good outdoor store that stocks MAG.
Hope this helps..
Jul 05, 2009 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
Corroded batteries stuck in a mini AA maglite
yes the bulb assy can be removed as it's basically the switch you need like a special tool for removing it. but first which brand of battery is in it. both energizer and Duracell have warranty about replacing item that the battery has damaged. try that route is my suggestion before trying to remove batteries and possibly breaking the switch. you can get one sent to you by calling up customer service as i replaced one before mini mag lite also.
Oct 04, 2008 | MagLite Camping, Backpacking & Hiking
Mag lite
I have a regular AA Mag light that had industrial strength batteries which corroded.I did get them out but the bulb holder on the light broke.(The main bulb holder where the twist on switch is.)
Jun 12, 2008 | MagLite - Mag Charger System 110v (M)...
Rayovac Highbeam Flashlight 1 Watt Luxeon Led Flashlight with Batteries Logo
106 people viewed this question
Top Rayovac Camping, Backpacking & Hiking Experts
jmcpoyle
Level 1 Expert
Dave Reilly
Level 1 Expert
Are you a Rayovac Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
