Question about KitchenAid KHMS155L Microwave Oven
Mic works but does not heat
Works fine but does not heat anything. Worked fine earlier today. Internal fuse issue? Where is fuse located if so? Thanks
Microwave will not heat
The problem is the magnetron, "heart of the microwave oven" or the inverter board if 7 years old or less.
Apr 19, 2012 | GE Spacemaker Over-the-Range Microwave
Rudy0819: My GE Microwave Spacemaker model JVM1440WH01 just stopped heating. I used it earlier and it worked fine. When I went to use it again, it won't heat. Everthing else works, the light, fan, etc,...
The most likely thing is the magnetron has 'died' but there is a high voltage fuse between the capacitor and the magnetron which may blow. Either way, repairs to microwaves are dangerous and should only be undertaken by a qualified repairer. PS I have seen a mouse cause this problem!
Sep 22, 2009 | GE JE1640 Microwave Oven
Doesn't heat anything
HI, there is only one in-line fuse link that is designated for the power board. this is concerning the Magnetron. this heating device has failed. replacing the Magnetron will fix this issue.
Jun 17, 2009 | Emerson Black Microwave Oven
Whirlpool Gold Accuwave wont heat
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
May 19, 2009 | Whirlpool MH7140XF Microwave Oven
Under cabinet microwave went cold today. Other electrical accessories okay
Most microwaves have an internal fuse. There is a good chance it is blown. Check your manual see if this is easily replaced. The other issue is of course why it blew the fuse in the beginning.
May 04, 2009 | Microwave Ovens
Ge spacemaker runs but wont heat
Jan 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
WONT HEAT
I AM LOOKING FOR A SOLUTION I DON'T HAVE ONE
Dec 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave just went dead
If there is no display and nothing works it may be as simple as a blown fuse. Try that first but unplug the unit before you do anything.
Oct 02, 2007 | Goldstar MA-7100 Microwave Oven
KitchenAid KHMS155L Microwave Oven Logo
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
