Question about Dryers
Electrical/wiring for a pendant fixture
We are replacing an old fan with a pendant light fixture. The fan was wired with a 2way switch and a Hunter Vari-Speed switch. The ceiling box has three wires: red, black, and ground. The 2way switch has a red and black wire, but the Vari-Speed switch has a white and black wire. We attached the indicated fixture wire to the red wire from the ceiling box and the plain black fixture wire to the black wire from the ceiling box. NO LUCK. We tested continuity from the switch to the ceiling box wires and that was positive. We have tried everything we can think of. HELP!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
White - nuetral
black - zap the junk out of you positive
if you can test continuity then test for source power, check both black wires and the red. the white wire better be neutral
set your volt ohm meter to 200 VAC if you have a cheap dial one or if you have a nice auto range one, set it to AC volts and test. red to the three wires, black lead on white...
Posted on Dec 29, 2013
  • 9 more comments
  • Megan Kelley
    Megan Kelley Dec 29, 2013
    We have several switches connected to one another. We are showing continuity from the ceiling box red wire to the red wire on the 2-way switch and from the black wire in the ceiling box to the black wire from the vari-speed switch. When I tested for the source power on the two black and red wires, both black wires read really low voltage.
  • Behind_Blue_Eyes
    Behind_Blue_Eyes Dec 29, 2013
    ok lets step back... you want to install a light fixture correct ? and you just want to be able to turn it on how ??? just a light switch of a dimmer switch ???
  • Behind_Blue_Eyes
    should of read " or a dimmer switch " sorry
  • Megan Kelley
    we were just wanting to install it with a regular switch. If we can use a dimmer switch in place of the vari-speed switch we can do that. Would that work?
  • Behind_Blue_Eyes
    hold on... you need to pull the switch from the wall... black and white wires should go to it... those wires will be the ones that should power your light...
  • Behind_Blue_Eyes
    trying to add a picture but this worthless site wont let me !!!
  • Behind_Blue_Eyes
    google " light switch wiring " look for the drawing basic light switch... that will help you
  • Behind_Blue_Eyes
    oh and please tell me your in the USA because outside of our pathetic electrical grid, everythings different LOL
  • Behind_Blue_Eyes
    the yellow wire in this diagramhttp://www.buildmyowncabin.com/electrica... is green in our wiring. If you have it let me know because its a safety ground that if your house is old enough isn't needed or used kinda sorta
  • Megan Kelley
    Megan Kelley Dec 30, 2013
    So once I pull the wires from the vari-speed (I'm pretty sure this is where the wiring originates from the fuse box) then we will have to rewire the other switches to supply power to them? It looks like a big cluster **** in the switch box.
  • Behind_Blue_Eyes
    Behind_Blue_Eyes Dec 30, 2013
    You shouldn't have to deal with the vari speed unless you want it out of the wall. Then you can cap the wires pull the vari speed and move on. The only wires you need is just like the diagram. Black wire in and out of switch, white wire... As you noted, you only need one black wire from fuse panel which probably happened is they've jumper'd the wires from the switch so they could power the vari speed. Sometimes things are cobbled together... Does this make sense ???
Cerfer39
  • 709 Answers
SOURCE: Wiring a Hampton Bay ceiling fan
Hi Rexter,
I would pull the cover off of the Light switch and look at the color of the wire leaving the Variable speed device. I only assume the red wire is from that. I do not like to assume anything. So you must verify that a red wire leaves the Variable speed device. If it does, then i am assuming you dim the lights with this Variable device. The fan has its own built in Variable speed setup. In the case that the red wire belongs to the variable device, wire the Red to Blue(light), and Black to Black Whites to white. Green to Ground. bare wires to ground.
Posted on Nov 30, 2007
Coldcut
  • 1554 Answers
SOURCE: wiring a ceiling fan with a remote sensor
since you have a remote, you don't need that extra wiring for the light/fan. just wire nut it off.
the switch at wall has 2 switches but only one will work now.
Posted on Mar 31, 2008
worldvet
  • 859 Answers
SOURCE: Trying to replace 3 speed ceiling fan switch
The black goes to the L connection the others are a guess. You can do this two ways. Connect the colored wires in any sequence and then see what switch sequence give you high and lowest, the other one will be medium. Once you determine that, mark the wires with a piece of masking tape as high, medium and low. Otherwise you connect them, turn power on and use a multimeter to see which color gives you the highest voltage and which gives you lowest. Since you aren't comfortable using live wires and a meter, go with the first option and use the process of elimination to find the wires giving you the speeds you need to find the highest and lowest. Next, you need to determine how your switch sequence works. First pull has to give you highest speed. so you may end up wiring them in reverse if your first attempt is backwards. There is a reason the first pull needs to be highest, it powers up the motor so you can then chose a lower setting. A low setting first will over tax your motor and wear it out eventually as it has to work harder at first.
Let me know if you need further clarification and perhaps this is all you need to get fixed.
Regards,
Worldvet
ps I checked on the Internet of a wiring diagram and I bet you did tok all to no avail.
Posted on May 27, 2008
SOURCE: Replace three-speed box fan switch
I have the same problem.
Posted on Sep 21, 2009
extreme7528
  • 108 Answers
SOURCE: Hunter fan wiring
sounds like one of your connections is loose. Im not sure if i completely understand your description of how you re-hoked up your fan. Please tell me how many wires your fan has and colors and how many wires you have on the sensor remote. (lots of times if you draw a wiring diagram on paper you can figure it out) Basically you should have power coming from ceiling to remote sensor. Then the remote sensor should throw the power to either the fan or the light, so there should be two seperate leads coming out of the remote sensor to control either the fan or the light independantly.
Posted on Oct 07, 2009
Hunter ceiling fan/light unit install with 3 pole switches. there are 2 white, 2 black and one orange wires coming out of the electrical box. How do i handle the installation?
Not understanding, three pole switch is a wrong switch, wires in the ceiling or wall electric box.
Needed: What switch is existing and what wires are in the switch box and runs or groups in each run coming in as wire groups. Same for ceiling box, colors and wires in each run coming in.
Basically, remove the existing ceiling fixture and connect the ceiling fan replacing the fixture to the same wires the fixture was connected to. White to white, green or bare to green or bare, colored wire to fan's blue and black. Wired like this one switch controls both fan and light, on and off at same time. Use fan pull chain switch for individual fan or light control.
Oct 22, 2017 | Hunter Dryers
Our hunter fan is less than 2 years old. the fan works fine but suddenly the light fixture will not work. changing the bulbs did not help
Do you have a separate wall switch controlling the lights that may be turned off and possibly not realize it? If all lights just stoped working and you are sure that their is no switch turned off controlling the lights, then you likely have a bad fan controller inside the fan housing, or a wire has come loose. If you are electrically handy, open the fan housing and check to see if you have power to the fan light wire. All of the lights going out at once sounds like a wire possibly a neutral (white) wire may have a bad connection.
Feb 07, 2017 | Hunter Dryers
Bad hunter ceiling fan light pull switch
I don't know what you mean, longer stem/chain housing to hold light fixture. You should be replacing a two wire switch only.
Feb 15, 2014 | Hunter Dryers
Replacing a light fixture
This is much simpler than it sounds, but if you're a total novice you'll need to read it all.
First, make sure power to fixture is off. Best method is to locate circuit breaker or fuse that controls that fixture's power. At minimum shut off the wall switch to it if there is one.
Next, remove the old fixture. Usually there are two screws or decorative nuts holding the base cover (canopy) on. On ceiling pendant fixtures there may be a retaining ring holding up the canopy, unscrew this ring counterclockwise and the canopy will drop over the support chain, exposing the junction box where the wires are connected.
It is critical at this point that the power is off.
Modern house wiring and fixtures are connected with three wires.
Green or bare copper = ground (earth)
White or grey = neutral
Black, Red, Blue or any other solid color other than green, white or grey = power or hot wire (this is the wire that is controlled by a switch.
For simplicity I will call the three: Green, White and Black.
The next step requires you to carefully pull the wires out of the junction box and isolate the black, white and green wire connections from each other. Make sure the connectors (wire nuts) for each connection are accessible.
Warning: With old or over heated wiring, take extra care not to crack or disturb the insulation(wire covering) on any of the wires. If insulation is crumbling away exposing bare wire, stop and call an electrician! Do not turn the power back on until he has repaired those damaged wires, they could start a fire.
Isolate the connection between the black house wire and black fixture wire. Remove this wire nut. At this point I usually use an electrical tester to double check that the power is off by touching one side to the newly exposed black connection and any grounded metal part nearby.
(Note: some multiple switched (three way) circuits may use a white wire as a power wire. If the black fixture wire is connected to a white house wire, mark that white house wire with black electrical tape for future identification.)
Once you are positive there is no power at the fixture junction box remove the connectors from the white and green wires.
Detach the old fixture and it's mounting bracket.
Re-attach the new fixture using bracket and new connectors that are usually provided. Some brackets have a green ground screw. Wrap the bare ground wire clockwise around that screw and tighten it down leaving enough remaining ground wire to attach to the fixture ground.
If the wires to the new fixtures do not have a 1/2 inch of exposed bare wire at the ends (stripped) you must do so. I use a wire stripping tool but you can do it with a sharp knife being careful not to nick the metal wire.
Once the wire tips are stripped, hold the tips of each color pair together side by side, slip the wire nut over them and twist clockwise until snug. (White to white, black to black etc.)
Take care that the new wire nuts are secure at each connection. Do not over tighten them but insure that they are correctly attached by gently tugging on each wire. When completed the black and white connections should have no exposed bare wire showing.
The Green (bare copper) wire is there for safety and never carries current, hence exposed wire is not an issue on ground wires.
Assemble and attach the new fixture according to instructions in the box.
Pendant ceiling fixtures usually require additional assembly steps including adjusting chain height, looping wires through the chain and slipping retaining nut and canopy over chain prior to connecting. Always follow directions that come with the fixtures.
When in doubt, call a professional. Electricity is dangerous.
Apr 06, 2013 | Dryers
How to wire this fan
The wiring on most paddle / ceiling fans id such:
White = Fan and Light neutral or "common"
Black = Fan line voltage or "hot"
Blue = Light line voltage or "hot"
Green = safety ground
If you are replacing an existing light fixture - be sure to replace the ceiling box with one designed for use with a fan - as per electrical code. If the existing box had only 2 wires (or 3 counting the ground) that connected to the old light fixture and it was controlled from a wall switch, the wiring would be fixture white to ceiling white, fixture black and fixture blue to ceiling black (or red) and fixture green to ceiling bare ground or connected to the metal box. This would power both the fan and light whenever the wall switch was on and the pull chains for each were also on. This is also the preferred wiring for replacement of a pull chain type light fixture (no wall switch present).
If there are other wires in the box that previously were not connected to the old light fixture, using a meter or tester - determine if there is constant power between the ceiling white wire and any of the these other wires (test with the wall switch on and off to be sure). If you do have constant power available, you might consider using the wall switch to control only the light, and using the pull chain to operate the fan (or vice-versa). Simply connect the black (for fan) or the blue (for light) to the "constant power on" wire and that part of the fixture will work by pull chain only - regardless of the wall switch position. If the fan can be shut off by the wall switch, it is very important that the wall switch remain a toggle (or on / off switch), do NOT replace with a dimmer type switch.
If you'd prefer to operate the fan and light completely independently of each other - you can purchase a 3rd party fan & light remote control device for between $30 - $50.
I hope this helps and good luck! Please rate my reply. Thanks!
Apr 22, 2011 | Aloha Housewares (93645) Ceiling Fan
I am attempting to install my Hunter 21095 Westcott fan and am unsure of the wiring. Power is at the ceiling fixture which in turn feeds the next rooms fixture and the switch wire is also in the ceiling...
Black is for the fan motor which you connect to black(hot), black/white is for the light which you connect to the switched lead in the ceiling, the white lead from the fan goes to the neutral lead in ceiling, and tjhe green wire is earth ground and goes to the box screw in the ceiling
Jan 20, 2011 | Hunter (25417) Ceiling Fan
I am trying to install a Tiffany-style 6-light Flush Rail Fixture, but th wiring in the apartment is old, but th problem is that in the ceiling is a solid round looking ''outlet box'' but in th instruction...
An octagon box should have the same screw spacing as a round box, however, with very old electrical fixtures, all bets are off when it comes to standard sizes. More important than that though is this: Was there a fan there before or are you replacing a light fixture? If it is a light fixture, you need to make sure that the box is sufficient to hold a fan. The weight is significantly higher than most lights and the movement makes it worse. If it was a light, there are fan boxes you can get to retrofit it so that it will be safe.
Mar 23, 2010 | Hunter Sontera 52" Ceiling Fan with...
In changing out an incandescent light bulb in a ceiling mounted light fixture, the glass hanging pendant was loose, so I removed the fixture from the ceiling, leaving the wiring connected, and tightened...
Many times with very old wiring the wire can break inside the coating and not be visible. To check for sure what has happened you will need an electric tester. You will need to check for 120 volts acros the two wires with the switch on. If there is no power, then check at the switch. If there is power there then the wire is broken.
Replacement of the old wires in an old house is very difficult and you will probably want to hire a professional to do that.
Heatman101
Feb 28, 2010 | Hampton Bay 24002 Ceiling Fan
Hunter ceiling fan type 3 not responding to remote
Sounds like the black wire from the fan is not properly connect(lose)
Here is an example wiring diagram
Mar 15, 2009 | Hunter Low Profile III 20807 Ceiling Fan
Hunter Fan # 20723 The Westminster - lights delayed when turn on
Here is the answer I received from Hunter Technical Support.
"The light fixtures are manufactured with a limiter that prevents a higher than recommended wattage bulb from working. The limiter causes the slight delay even when the correct bulbs are is in use."
Pretty annoying if you ask me.
Jan 25, 2009 | Hunter 28096 Westminster 52" Ceiling Fan...
Dryers Logo
Top Dryers Experts
