Question about Mysoftware MyMailList & AddressBook (mysoft-maillist) for PC
Problem installing MyMailList
Ver 8010. When attempting to Run/Install (downloaded version from Avanquest), it begins to install but then another window pops up - "Quickbooks Contact Sync Setup", Modify, Repair or Remove. I've tried all three. Then I get a brief message back on the MyMailList installation saying it's removing some files. Then I get a message saying the Program May Not Have Installed Correctly. The end result is MyMailList did not install at all. Does anyone have any suggestions? I've even uninstalled QB Contact Sync and still get the same result. I've downloaded MyMailList three times, thinking I could have had a problem during the download - but it's a problem with the MMLAB_8010_ESD.exe file. Thanks.
    Problem Solver:
  • 5 Answers
IMPORTANT-it could be the"Aluminum -( HEADS!)"!IF they-R-LEAKING at ALL/Warped from Over-heating/Not-Proper temp. read-outs from your T-Stat-OR'Info-Center'-But IF there is ANY-ANY Carbon Monoxide Mixed IN W/Your Coolant-then you have"LEAKING HEAD or HEADS"!U-Can"Check VERY easy Actually with"Chemical that's Bluish&Merely-2- Radiator-( FUMES-from still fairly warm Engine)&CAN Check from Your"Coolant Resivoir"-Easily"!!It turns"Yellow or Brownish-Then-U-Have a HEAD-PROBLEM" -IF Stays BLUE-then ZERO Heads Leakage from Coolant-OK&NO' Blown heads/leak Head gaskets/Warped/NOTHING"!!Costs a HUGE"$32.00-4-SPECIAL-Made Kit for the 4.0L-Baby N-Stars"!!Can easy do-Yourself,OR have mechanic do it!:)This-IS#1Problem w/4.0L-N-Star Engine"Overheating Problems-Over90%++'!!:)Worth-2-Check!
Posted on Dec 29, 2013
3 Suggested Answers
SOURCE: My mailing list
Contact software website they will issue you one after verifying the account.RICGARDM69
Posted on Jan 03, 2009
  • 35 Answers
SOURCE: mymaillist does not open .mml file
stupid question
Posted on Oct 23, 2009
Testimonial: ":( why stupid? my app was lost in a crash, I downloaded the same version into my new HD, I am able to execute it ... but it doen't open the old files"
Tip
HOW TO INSTALL FROM SOURCE IN LINUX
HOW TO INSTALL FROM SOURCE IN UBUNTU 9.10
Installing from source in linux is not very easy...... but once you know what to do, then it becomes a very easy task.
STEP 1 Tar.gz and Tar.bz2 Packages
The installation procedure for software that comes in tar.gz and tar.bz2 packages isn't always the same, but usually it's like this:
1.Download the tar.gz or tar.bz2 package
2.Extract the file
3.Open to the terminal
4.Use the cd command to change to the directory where the package is extracted
5.Use the following:
$ ./configure
$ make
$ make install
Without Using The Extraction Method
Run the following:
$ tar xvzf package.tar.gz (or tar xvjf package.tar.bz2)
$ cd package
$ ./configure
$ make
$ make install
!!!!THIS IS AWESOME!!! …... ISN'T IT?
STEP 2 .Deb Packages
Installation of .deb packages are in different forms or methods depending on the users understanding and how the user is flexible with the terminal.
1.Download the package
2.Extract the package
3.Change to the directory containing the package
4.Run the following
sudo dpkg -i package_file.deb
!!!! AND YOU ARE DONE!!!
LINUX X64 AND X86 BINARY INSTALLATION
2.Open to the terminal
3.Use the cd command to change to the directory containing the package
FOR X86 PACKAGES.........
$ chmod +x filename-ver.*-linux-i686.run
$ sudo ./filename-ver.*-linux-i686.runFOR X64 PACKAGES........
$ chmod +x filename-ver.*-linux-x86_64.run
$ sudo ./filename-ver.*-linux-x86_64.run
where ver is the version number (the whole number before the decimal point... eg; the 4 in 4.103)
!!!!THANKS A LOT!!!!
on Jul 21, 2010 | Computers & Internet
I just bought Avanquest Fix-It Utilities brand new from Wal-Mart and I have installed it and when I try to activate it using an email address it keeps saying that it cannot connect to the server. I have...
Version 8 or 8.2 .......???
Its an old version contact the seller and ask for a refund or help
or download version 8 and install it
http://www.esoft.me/dl.php?file=Avanquest System Suite 8 Professional 8.0.2.2.zip&host=zip
or just use something else
There are lots of freeware alternatives on the internet
You could run the chkdsk disk utility
Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive.
or an easier way to run the chkdsk utility
Windows 7 chkdsk
http://www.w7forums.com/use-chkdsk-check-disk-t448.html
Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
Optimizers and Diagnostics.
http://download.cnet.com/360Amigo-System-Speedup-Pro/3000-18512_4-75332741.html 5E3422139C19CBED35C14826A44D4605
Improve your PC performance and fix errors.
Delete some stubborn files
http://www.malwarebytes.org/fileassassin.php
http://advanced-systemcare.soft32.com/ One-Click Free System tool
Aug 05, 2013 | Avanquest Fix-It Utilities 8 Professional:...
Program
Fix-It Utilities is a program by Avanquest that is marketed as an all-around computer protection and enhancement tool.
Fix-It Utilities scans your computer for potential problems and fixes them automatically. Additionally, it monitors your computer in real time to alert you about hardware and software issues before they can cripple your computer.
If you are looking for a utility to handle your computer maintenance for you, Fix-It Utilities is one program that you might consider selecting.
Double-click the downloaded program file if you purchased the digital version of Fix-It Utilities directly from Avanquest.
If you purchased the boxed retail edition, insert the installation disc and allow a moment for the Fix-It Utilities installation program to load.
Click "Next" when the Fix-It Utilities Installation Wizard appears.
Read the terms of the Avanquest license agreement carefully before continuing.
If you are willing to abide by the terms, click the "Accept" button to continue.
Enter the name that you would like to register Fix-It Utilities under, and then type your 24-character product key exactly as it is shown in the product packaging or the email sent by Avanquest when you purchased Fix-It Utilities online.
Click "Next."
Select the radio button labeled "Complete" to install all of the features of Fix-It Utilities, and then click "Next" twice.
The installation utility begins copying the files for Fix-It Utilities to the hard drive.
When this process is complete, the installation utility displays a screen with four check boxes.
Use the four check boxes on the screen to indicate whether you would like Fix-It Utilities to check for and install updates automatically, whether you would like the program to make snapshots of your system for recovery in the event of a problem, whether you would like the program to monitor your computer for malware and viruses and whether you would like the program to scan your email.
Click "Next," and then click "OK" and "Finish."
Fix-It Utilities is installed.
If you used the check box to configure Fix-It Utilities to check for updates automatically, the program begins scanning the Internet for updates immediately.
http://www.avanquest.com/USA/software/fixit-utilities-9-professional-114420?gclid=COGnn7CYvZ0CFQgtawodB3Hjpw
if you still have no luck there are freeware alternatives on the internet as well as the chkdsk utility.
Windows 7 chkdsk
http://download.cnet.com/360amigo-system-speedup-free/3000-18512_4-75206713.html Improve your PC performance and fix errors.
May 25, 2013 | Avanquest Fix-It Utilities 9 Professional...
Fixit utilities pro on line will not down load
There are lots of freeware alternatives on the internet You could run the chkdsk disk utility Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive. or an easier way to run the chkdsk utility Windows 7 chkdsk http://www.w7forums.com/use-chkdsk-check-disk-t448.html Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive http://download.cnet.com/jetclean/3000-18512_4-75627788.html JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again. Optimisers and Diagnostics. http://download.cnet.com/360amigo-system-speedup-free/3000-18512_4-75206713.html Improve your PC performance and fix errors. http://advanced-systemcare.soft32.com/ One-Click Free System tool for PC tune-up and maintenance.
Feb 26, 2013 | Avanquest Software Avanquest FixIt...
I am using windows xp. I recently loaded office 2007, and now my internet explorer (Ver 8) hangs up when attempting to load active x. All the internal settings are correct. HELP!
Install DirectX 9.0c, that should fix your problem. Find DirectX 9 at www.filehippo.com > scroll down to Drivers on the lower right of screen > double-click on DirectX > Download Latest Version > double-click on download to install. The other thing you should do about installing Office 2007 > go back and install it again to get features not installed the first time.
Oct 31, 2010 | Microsoft Internet Explorer 8
Installing new version of Flash Player on Firefox ver 2 - Win98se
You have to make sure your Firefox is closed first, otherwise it won't work or installed. Install the Flash Player. And then only start your Firefox.
Dec 08, 2009 | Computers & Internet
I am using Windows CP Pro - SP2. I am not using auto update. I have OEM version installed over old Windows XP Pro. I have a serious problem reg Windows Installer 3.1 and also Adobe Flash ver 10. I always...
(plse note) auto update off firewall on after internet your pc virues plse install nod32 antivirus lattest software plse collect all software download secure website www.download.com plse visit it now all the best
Aug 01, 2009 | Microsoft Windows XP Professional SP2 Full...
Error message: "The file wmploc.dll has a version number of 11.0.6000.6344 where 11.6001.7004 was expected. Windows media player was not installed properly and must be reinstalled. Do you want to inst
This is not a very common problem, but in all likelihood your Avanquest software has altered your Windows files in such a way that you cannot install your media player.
Most fix-it utilities make back-ups of your system files as they were BEFORE running the utility.
Check in your Avanquest application to see if you can restore your system to the way it was before running the application, then try reinstalling Windows media player.
Let me know if you need any further assistance regarding the above.
Best wishes,
Graemevm
May 21, 2009 | Microsoft Windows Media Player
Will MyMaillist & addressbook work with Vista 64-bit
Go straight to the source and ask them.
Phone: (800) 325-0834
7:00 am to 5:00 pm, Mon-Fri, PST
Or since the vista version is only available through download, you could go to this link and download the trial and see if it works.
http://www.avanquest.com/USA/trialDownload.html?pid=8-77563-64
Let me know :)
Dec 24, 2008 | Mysoftware MyMailList & AddressBook...
Mysoftware MyMailList & AddressBook (mysoft-maillist) for PC Logo
81 people viewed this question
Top Mysoftware Computers & Internet Experts
Danny Kuhlmann
john smith
Are you a Mysoftware Computer and Internet Expert? Answer questions, earn points and help others
