Question about Pool & Spa
Polaris problems Hi I have a 2002 polaris virage txi 1200 it's lost power and it says to check engine
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Interesting... did you check it, is it still there ???
more info would make a world of difference
Posted on Dec 29, 2013
2002 virage txi 1200 direct injection plugs oiled and fouled
Does the ski still have the oil pump? Has the ski been sitting up for a while? When was the last time you changed the spark plugs?
...Without knowing more, I would take it to a qualified professional and have the carbs cleaned/the diaphragms checked/and set.. then synchronized.. Replace the spark plugs AFTER you have the carbs done...(NGK BR9ES)... A BR9ES needs clean jetting to last... these are "cooler" running plugs.. DO NOT go to a BR8ES. (hotter plug) unless you are told to by a PROFESSIONAL mechanic...
Jul 02, 2017 | Boating
I have a 2009 Polaris Sportsman 500EFI 4 wheeler. Recently, the number 1200 started flashing under the speedo. What does this indicate?
that sounds like your clock. engine codes don't go that high.and if it was your clock you must of lost 12 volt power at some point.
Jan 29, 2016 | Polaris 2009 Sportsman 500 EFI Touring
I have a 2009 Polaris 500 Sportsman. A number 1200 flashes on the Speedometer. What does that indicate?
that sounds like your clock you must of lost 12 volt connection at some point engine codes dont go that high
Jan 27, 2016 | Polaris 2009 Sportsman 500 EFI
Why wont my polaris 2002 polaris sportsman
the engine may be seized, take the spark plug out and see if that helps to crank it over
Aug 08, 2014 | Polaris 2002-2010 Sportsman 500 600 700...
I have a 2001 polaris virage tx iv replaced all electronics still won't start it also has good.compression does anyone have any suggestions for me I'm going crazy with it
This is a pretty well known issue. Check this out: https://sites.google.com/site/polarispwcknowedge/Home/electrical/ignition-system-1
Jun 05, 2014 | Garden
Hi, i have a 2002 Polaris Sportsman 4X4 400 liquid cooled, which just recently started leaking loads of coolant and also oil, it only leaks when it's stopped and cooled down... and now it's lost...
Sounds like two diffrent problems ,but the leaking of the coolent could be radiator ,bad hose or thermostat .If the oil is leaking it might have a sensor so you dont blow the motor ..I hope this helps ..If any thing please call local Polaris dealer so no futher damage ..Have a great xmas !
Dec 04, 2017 | Polaris ATV
My 2006 polaris sportsman 500H.O.x2 is idling too fast .how can i fix the problem?
sense this is a carb model it is easy to adjust. There is a black screw under the carb (hopefully you know where the carb is) turn this OUT (counterclockwise) with every half turn revv the engine up and let it idle back down until it idles around 1200 RPMs
Mar 11, 2010 | Polaris ATV
Problems with my txi 6006 amp
check all connections then check the subs voice coils to make sure there not burnt smelling, or burnt looking.then check the cars charging system you might have to add an extra battery,and or cap.
Jan 09, 2009 | Hifonics Titan TXi 6006 Car Audio...
Pool & Spa Logo
77 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
