Question about Sabrent Vga To Hdmi Converter
No sound Have connected the converter properly but there is no sound coming from the tv.
    New Friend:
  • 62 Answers
Vga does not have audio in it you need to take the audio out put and plug it into the box or you tv.
Posted on Dec 29, 2013
  • Laney
    Laney Dec 29, 2013
    The audio cable is plugged into the converter box and the computer in the port with the headphone symbol.
Bought 24 inch gpx tv this past december, there is no sound on tv at all, what could be the problem?
Press the MUTE button.
If the audio is coming from an external source, check that the cable
is corrected to this device properly.
Check if sound terminal of external input is connected properly.
Check if audio cables are connected properly
May 09, 2014 | GPX TV
Don't have cable. Have the digital converter box and a indoor antenna...it's hooked up and TV is playing fine. After hours of changing every cable the VCR will not play. I get the sound of the movie but no...
You can connect VCR, TV and converter box using coaxial cables OR you can connect using RCA cables. See this web page:
http://columbiaisax.googlepages.com/diagram_dtv_tv_vcr.htm
Using RCA cables, make sure you connect the yellow video cable. Select the proper input on the TV.
Aug 12, 2010 | Televison & Video
How to Connect Converter to TV, DVD/VCR and a Stereo?
Connect converter box to your DVD/VCR player at the ant in. Depending on your location you might need a new ant for UHF.
Jun 15, 2009 | Philips DVDR3435V/37 DVD Recorder/VCR
Sound problems with recording to vcr using converter box
If your TV has no scart connection, no HDMI connection, then to be honest I would get a new set. There are plenty of good second hand models around, which will be better than your old set and come with a digital tuner built in.
As for the VCR, that should have a scart socket and so should the converter box. Once connected via the scart socket you should be be able to record the shows easily. If the converter box comes with a volume control, you might need to set that up to get it right. If the VCR has two scart sockets use the second one to connect the box. Use the first to connect to the TV for viewing your recordings only.
If it has only one scart, then look around on Amazon for one of these scart switching boxers.
Mar 19, 2017 | Insignia Digital-to-Analog Converter for...
Tv + converter box = no sound
Try these steps: Turn the volume on your converter box all the way down. Turn the volume on your TV up to ½ way. Now turn up the volume on your converter box until it is at a comfortable level. More information at http://www.ezdigitaltv.com/index.html
Mar 31, 2009 | Sansui CDVD1310 13" TV/DVD
I have old tv with rf connection need to adapt to rca plugs
Simply insert the converter between the curent cable and the TV. The converter should have come with a short RF cable that you can use between teh converter and the TV. I have incluede a before and after line diagran below.
Dan
BEFORE: cable==> TV
AFTER: Cable==> converter ==>TV
Feb 25, 2009 | Insignia Digital-to-Analog Converter for...
No sound on TV
If the TV programs come's up with sound, then is possible that the TV set could be problem free. then cheek the system frequency if it need to be adjust from NTCS, PAL, AUTO MESECAM and so on. Cheek the DVD and VCR if they are in one of the following system settings and adjust the TV set to the settings at which the DVD or VCR is set to. Then you can also cheek if the cable is properly inserted, that is audio to audio and video to video. Nevertheless, if you have properlly connected your cables and set the system frequency to match with each other, and still no sound, then the TV could have sound problem.
Possible courses of sound failure in TV are as follows:-
1 RF stage
2 sound Ics or transistors
3 broken speakers
4 a break down resistor which supplie positive voltage to the sound curcult
Dec 09, 2008 | Televison & Video
Sony KF50we60 hdmi-dvi sound cuts when plugging into a ht-sf2300
DVI = HDMI without the audio connectors. So basically you need to connect your audio in some different way, PS3s allow you to keep your video signal as HDMI and change the Audio signal to component, so that is one way or doing it, not sure if the blue ray players allow you to do this though.
Nov 22, 2008 | Sony Grand WEGA KF-50WE620 Television
Lip sync playing ordinary tv
you need to have a sound speed equalization higher frequencies travel slow,
if you can buy a AV/RF CONVERTER the problem can finish
AV be connected to devices and RF to tv
this can over come that problem
Oct 07, 2008 | Philips Cineos HTS9800W System
Toshiba 36AFX61
Just Connect signal to tv and run autoprogram. Or use video input jacks from converter to tv ( yellow,white and red video in ) and select tv/video on tv pannel front ( don't need remote control) I hope this work for you.
May 11, 2008 | Toshiba 36AFX61 36" TV
Sabrent Vga To Hdmi Converter Logo
18 people viewed this question
Top Sabrent Computers & Internet Experts
Martin Murray
Colin Stickland
Colin Stickland
Steve
Are you a Sabrent Computer and Internet Expert? Answer questions, earn points and help others
