Question about Music
G & l serial trb-lgcy-lh-3ts/rw - Music
Fender serial number search 47547
"Fender" what? For all this says, it could be a car fender. FMC, Fender Music Corp.'s website lists serial numbers for guitars and amps. Doing a Google search also reveals other listings for guitars' serial numbers, but I've never looked for amp numbers.
Jul 14, 2014 | Fender Music
Upright piano serial number
Here is a good place to look for your piano by make & serial number.
There are times when your piano name or number is not listed. They can help you find the year your piano was manufactured in most cases. Since you have the name & serial they should be able to answer your question.
http://www.bluebookofpianos.com/serial1.htm
Best of Luck
Apr 17, 2014 | Music
Where is the serial number on a crate amplifier
Real basic owners manual is here:
http://www.crateamps.com/pdf/manuals/CA6110DG_OM.pdf
Look at the chassis, or pull a part number off the original speaker to match speaker and back cross reference to the amp versions that used it. The OM is at least good enough with the block diagram to allow it to be serviced easily enough.
Feb 21, 2012 | Crate CA6110DG Gunnison Acoustic Guitar...
I need to purchase a yamaha trb 5p but i can't find it anywhere. Anyone knows where i can get it?
try here -> http://www.gbase.com/gear/yamaha-trb-5p-5-string-bass-green
Mar 05, 2011 | Yamaha Music
Where is the serial number on my marshall amp mg15fx
Behind the amp, right around where the power-supply is. Usually the right hand side at back of amp. Serial numbers are labeled as: S/N########
Mar 14, 2010 | Marshall Mg15dfx 15-Watt Combo Guitar...
Music Logo
27 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
