Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Manual for cfef388jeb1
It says self cleaning but we don't see the cleaning mode on the panel. we are trying to find an owners manual. ty
The LOC on messsage appears on the screen when we go toturn the oven on. NEED the OVEN. What could we do to fi it?
The control lock has been activated. This feature is useful when you are cleaning the panel so that you don't accidently start the oven or the self-cleaning cycle. Try pressing Bake and Broil Hi/Lo together for 2 seconds (or a bit longer). SF should appear in the display. Then press Self Clean and Start. (When you press Self Clean the LOC message should disappear.)
Manuals for most GE appliances are available here: http://www.geappliances.com/service_and_support/literature/ . Enter the model number and click Submit. The direct link to the manual for the JTP18WWWW is: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=981140017.PDF .
I hope this helps.
Jun 02, 2011 | GE Profile JTP18 Electric Single Oven
Owner's manual re self clean feature Kithcen aid Superba27 self clean double oven purchased 1988 Cannot get it to turn on and heat. The Lock light does not go on and no heat is generated.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 17, 2011 | KitchenAid Ovens
I cannot find my owner's manual. I need to clean my oven, but I don't have the instructions and the lights have gone off on my panel.
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Jan 05, 2011 | Jenn-Air Ovens
I bought a used 27" Thermadore double oven off Craigslist. (Loves me some Craigslist.) SS, convection, electric. Sticker on side indicates it was manufactured in 2001. I can't find the tag with model...
If Thermador kept the tag information in the same place, look at the bottom of or just below the control panel (front left hand side of the control panel (when facing the oven) where the cabinet curves).
The oven cleaners can damage the finish and parts of the self-clean oven. The damage may cause the oven to fail sooner than it would otherwise.
If you have a small spill that you want to clean without using the self-clean cycle, on a painted surface, use soapy water or Fantastick or Formula 409 applied to a clean sponge or paper towel and then wipe clean. If the spill is on a porcelain surface, wait until the oven is cool and use Bon-Ami or Soft Scrub on a clean sponge. Then rinse clean. For stubborn dirt, use a soap filled pad.
I hope this helps.
(Thermador has manuals on their website: http://www.thermador.com/SupportCenter/DocumentDisplay.aspx?menu_id=27&menulevel=0302&cat_id=687 )
Aug 05, 2010 | Ovens
I have an older model double oven by Kenmore - probably 15-18 years old. I was baking bread in foil three days ago and the oven set on bake 325 degrees. (I had been cooking a roast in it for several hours...
Hi.
the oven may have locked in consequence of the self cleaning cycle.
After unplugging, allow the oven cooling down for few hours.
If the is still locked, then the high temperature generated in self cleaning cycle may have damaged temp probe, door latch, or electronic control.
Parts must be tested to discover the fault.
Call Kenmore at the number listed on the owners manual.
Regards.
Mar 03, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Cannot unlock oven frigidaire electrolux gallery series
hello. this is a common problem. here is a link to provide you with an owner manual which explains how to use the self-clean function
http://www.frigidaire.com/manuals.aspx
and here is a link to speak directly to the folks at frigidaire who will talk you through the solution to your problem
http://www.frigidaire.com/contactus.aspx
let me know how u make out with this as I can offer additional help if needed.
May 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I am not sure if I am setting the clean mode correctly.
Most self cleaning ovens that I have been around clean in 1-1/2 to 2 hours. See you Owner Manual to be sure.
If you can't find your Owner Manual, let me know, I'll see what I can dig up.
Jan 14, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
146 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
