Question about Lenovo G585 Laptop
File types notebook
What programs can i uninstall
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Every manufacturer installs loads of junk that they shouldn\'t. Fortunately, there are ways to determine what\'s good and what\'s garbage! This site helps do just that: http://pcdecrapifier.com/
Posted on Dec 29, 2013
How do I completely uninstall "OUTFOX TV" from my pc?
Click
Start
Type regedit into run bar
goto file top left
select search
type outfox
remove all listings
Jan 20, 2014 | Acer Aspire Computers & Internet
I tried to uninstal a program, but it didn't let me
You should always remove and uninstall programs from your PC that you are not using.
It could be beneficial to your computer's productivity and functioning to free up space.
You run the risk of running out of space on your computer if you add too many programs without uninstalling some.
It is a relatively easy process, but you should be sure you are not removing a program that is necessary to the operation of your computer.
Click "Start" and select "Programs."
Click "Control Panel" and "Programs" and "Programs and Features."
Browse the list of programs on your computer and select one that you want to remove.
Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary.
Check the properties of the program if it is not listed in "Programs."
You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using.
Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program.
Type "Regedt32" in the box and click "OK."
Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab.
Click "Desktop" on the "Export Registry File" dialog box.
Type "Uninstall" in the "File Name" box and select "Save."
The left panel of the Registry Editor will display the programs that are currently installed.
Right-click the key in the left panel of the Registry Editor window.
Click "Delete."
Click "Yes" when you are asked to confirm deletion of the program.
Click the "File" menu and select "Exit."
This will exit the Registry Editor.
Click "Start" and "Control Panel" and click "Add or Remove Programs."
Confirm that the program is no longer listed here.
and you might have other web search toolbars interfering
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Click on the tools at the bottom of the drop down list will be internet options or
Click start control panel internet options you will see a home page box To Create Page Tabs type
each adress on its own line (type in google.com) or your preferred home page and browser
below that will be change search defaults click on settings you will see all search Providers
Toolbar extensions and Accelerators you have
have if don't need any of them you can disable or remove them
Apr 21, 2013 | Acer Windows Vista TL-562G Notebook
Removing searchnu from my computer
You should always remove and uninstall programs from your PC that you are not using. It could be beneficial to your computer's productivity and functioning to free up space. You run the risk of running out of space on your computer if you add too many programs without uninstalling some. It is a relatively easy process, but you should be sure you are not removing a program that is necessary to the operation of your computer.
Click "Start" and select "Programs." Click "Control Panel" and "Programs" and "Programs and Features." Browse the list of programs on your computer and select one that you want to remove. Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary. Check the properties of the program if it is not listed in "Programs." You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using. Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program. Type "Regedt32" in the box and click "OK." Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab. Click "Desktop" on the "Export Registry File" dialog box. Type "Uninstall" in the "File Name" box and select "Save." The left panel of the Registry Editor will display the programs that are currently installed. Right-click the key in the left panel of the Registry Editor window. Click "Delete." Click "Yes" when you are asked to confirm deletion of the program. Click the "File" menu and select "Exit." This will exit the Registry Editor. Click "Start" and "Control Panel" and click "Add or Remove Programs." Confirm that the program is no longer listed here. and you might have to remove or disable it
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help Click on the tools at the bottom of the drop down list will be internet options or Click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in google.com) or your preferred home page and browser below that will be change search defaults click on settings you will see all search Providers Toolbar extensions and Accelerators you have have if don't need any of them you can disable or remove them
Hope this helps.
Jan 16, 2013 | HEWLETT-PACKARD HP G62223CL Notebook PC
Uninstall searchnu is a search engine showing up outa nowhere, how to uninstall
Force Uninstall Software b> You should always remove and uninstall programs from your PC that you are not using. It could be beneficial to your computer's productivity and functioning to free up space. You run the risk of running out of space on your computer if you add too many programs without uninstalling some. It is a relatively easy process, but you should be sure you are not removing a program that is necessary to the operation of your computer.
Click "Start" and select "Programs." Click "Control Panel" and "Programs" and "Programs and Features." Browse the list of programs on your computer and select one that you want to remove. Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary. Check the properties of the program if it is not listed in "Programs." You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using. Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program. Type "Regedt32" in the box and click "OK." Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab. Click "Desktop" on the "Export Registry File" dialog box. Type "Uninstall" in the "File Name" box and select "Save." The left panel of the Registry Editor will display the programs that are currently installed. Right-click the key in the left panel of the Registry Editor window. Click "Delete." Click "Yes" when you are asked to confirm deletion of the program. Click the "File" menu and select "Exit." This will exit the Registry Editor. Click "Start" and "Control Panel" and click "Add or Remove Programs." Confirm that the program is no longer listed here. you might also need to remove or disable them
Hope this helps.
Jan 11, 2013 | Computers & Internet
How can I uninstall eType software from my system. I can' t see it in the program list when I list the programs in install/uninstall window
Hi, We hate to see you leave but uninstalling eType is simple -
1. go into program files -> eType folder
2. Click the uninstall icon
Jul 19, 2011 | Microsoft Office Standard for PC
How do i uninstall warcraft III the frozen throne in my computer? i cannot find the said program in the control panel particularly the add/remove program.can i use the command prompt for uninstalling...
Find the files for the program somewhere in the "Program Files" directory. If you have a shortcut to the program, you can get to the files by right-clicking the program icon and selecting properties. From the properties window, push the "Find Target" button. Look in that directory for an Uninstall executable or maybe a setup file. If there isn't one, you will have to manually uninstall. You can delete all the files there, but the program info will remain in the registry. You can then find a freeware registry cleaner if you want to fix the registry (not necessary). OK?
Nov 25, 2010 | HP OmniBook 500 Notebook
I can not download or open PDF files online. Only existing files in my notebook can be opened. Also I can not uninstall the adobe 9.3.1 that I currently have. It is saying that I should contact my...
to uninstall adobe9.3.1 there is a program unlocker it is free
go to google type in unlocker this will take you to the site download
install it will open automatic to force the pro gram to to uninstall.
Aug 15, 2010 | Adobe Computers & Internet
My computer needs check up because very slow and lot of programs are in trouble during when i open my computer?
hi, the best thing to do is to uninstall the programs that consume more RAM memory and then to perform disk clean up with disk defragmenter on the harddisk
Jun 20, 2010 | ASUS Eee PC 900 PC Notebook
Uninstalling problems
if you have the original program, try re-installing it, then uninstall it.
Aug 31, 2008 | Compaq Armada M700 Notebook
Microsoft silverlight wont download after i uninstalled it in april it keeps saying i to uninstall it
With some uninstalls, pert of the program is left behind. You will need to go into the program files in the C drive and manually delete the file.
Jul 01, 2008 | HP Pavilion dv1000 Notebook
Lenovo G585 Laptop Logo
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
