Question about 2900 Fuel Injection System
Engine quits when down shifting - 2900 Fuel Injection System
  • 351 Answers
Possible vacuum leak at inlet manifold
Posted on Jan 25, 2014
Why does the daewoo shuts down when transmission is shifted to drive
you may have a faulty torque converter and it is loading down the engine to much to keep enough rpms to stay running or it could be and issue with the engine. more info is required. RPMs in park, does it do it if you use the throttle while shifting to drive, does it do it in reverse as well?
Jul 14, 2014 | 2001 Daewoo Lanos
Speed Control Problems - Cruise Dropout, Rough Shifting, Engine Cutoff
maybe start with the fuel filter or pump. possible screen collapsed or plugged.
Jul 18, 2013 | 2003 Buick Park Avenue
Transmission/97/toyota/camery
Refill as fluid level drops as torque converter refills.
Jun 12, 2017 | 1997 Toyota Camry
Why does my car Quit runnin when i put it into gear ? my car is full of gas but when i shift into drive my car shuts down and quits runnin.
ok try this put it in park and reeve the engine see if it has a miss or bogs down see if a fuel problem/airproblem or tranny problem thencome back and post again letting me know
Sep 24, 2010 | 1991 Cadillac DeVille
My bike wont change out of secound gear
This usually means a bent shift fork. Quite likely the shift lever is hard as a rock. The engine will need to be torn down to get to the bent fork or forks. Bummer. Please rate my answer. Thanks.
Aug 24, 2010 | 2002 Honda CR 250 R
Transmision quit shifting spedomitor quit working
The transmission quit shifting, and the speedometer quit working.
When you say the transmission quit shifting, do you mean you backed out of your driveway, started driving down the street, no speedometer, and you just stayed in 1st as the engine RPM's got higher and higher ?
Please explain what has happened. You should also have a check engine light on in your dash. You will have to plug a OBD II reader in to pull any codes, so we can help you find the problem. Please let us know.
Feb 10, 2010 | 1999 Chevrolet Cavalier
1990 montero, engine light comes on and i can here just one click noise, sounds like a relay?, and then it acts like it wants to down shift or stall but doesn't quite shift all the way, and then the light...
Either a relay or a sensor. If check engine light is on, then the best thing to do is to have a diagnostic scan done to read the engine codes. Many part stores will do it for free. This will pinpoint the exact problem location
Nov 12, 2009 | 1990 Mitsubishi Montero
Engine Quits when I shift from P to R or D.
Suspect faulty torque converter or TCC solenoid. Most people think this is an engine issue, but most often when an engine stalls when shifting from Park to Reverse or Drive it is in fact a torque converter failure.
May 22, 2009 | 1989 Lincoln Continental
1989 celebrity check engine light on
sounds like the (VSS)vehicle speed sensor is bad causing the speedo not to work and the transmission is not shifting properly because the computer can not tell how fast the car is going,have your local mechanic fix it asap so toy do not do any engine or transmission problems.as far as the heater stopping,I dont thing they are related.I will get back to you on the blower have a good day DB
Feb 01, 2009 | 1989 Chevrolet Celebrity
1993 Ford Thunderbird w/5.0L engine transmission shift problem
hey check your tv cable adjustment type it in in google its hard to explain where it is but google will tell you where it is and how to adjust it
Jan 18, 2009 | 1993 Ford Thunderbird
2900 Fuel Injection System Logo
Top MSD Vehicle Parts & Accessories Experts
xkikbxr
spy1309
randy yarpos
randy yarpos
Are you a MSD Vehicle Part and Accessory Expert? Answer questions, earn points and help others
