Battery dead & BIOS reset. CD & DVD drives lost.
IBM Desktop w/ Windows ZP. We were having some power outages, so I turned off the pwer bar. When the power was restored and stable, I booted the machine and the BIOS appears to have reset. Also, the CD & DVD drives were not visible. I also noticed that clock had reset to Jan 1, 2001, 12:00 am. I then realized the clock wasn't "ticking" while the machine was off and losing time even when running. Likely a dead battery - perhaps just a coincidence re the power fluctuations. I can't figure out how to get my system to recognize the DVD or CD drives. Suggestions ?
    New Friend:
  • 62 Answers
Ok what it sounds like is the CMOS (3v watch battery) on the motherboard has gone flat. they are not rechargeable batterys as people seem to think. replace this & them go into the bios, usulay the escape key or F1 on some & reset the pc settings. batterys are about $3, hope it helps
Posted on Dec 29, 2013
    New Friend:
  • 15 Answers
First you will need to replace the cmos on the system board(or have a qualified computer service tech. do it). then you will need to access the bios settings by Pressing F1 immediately after powering on the computer. once in the bios, you can set the correct date and time. Also, you will need to check the drive settings to verify that the hard drive and any CD/DVD drives are recognized. once done, then exit the BIOS being sure to chose "save and exit", then allow your PC to boot normally. this should fix your date and drive issues. if not then the motherboard may be defective.
SOURCE: Emachines T3882 desktop w/one cd-dvd combo drive[no floppy]
Download the drive test for the hard drive. Put the drive in your other computer and run the test. If it test good on simple test do the long test. IF IT COMES OUT FINE, Run the Zero program and then try to install the O.S. Check your BIOS settings and make sure everything is set right. You are on the right track. You just did not know how to test the drive. If it is a Toshiba you will not find a hard drive test. You might be able to use the Maxtor or Seagate drive test. Use the windows version if you can. If you can't do any of the test, right click on the drive and check for errors.
Rate me if this helped.
Posted on May 29, 2008
Saigua
  • 981 Answers
SOURCE: Toshiba A305-6825 laptop prolem (no
You seem to be onto things (though your problem classification was generic instead of for your Toshiba model A305.) Install all the updated drivers for your laptop from the laptop's support site (Toshiba's, that is) so you can use your drive. Drives fail sometimes, and you could try sticking an old movie or something in there instead of nothing, but it is likely it is just the missing driver.
Posted on Jul 19, 2008
mumma_1
  • 903 Answers
SOURCE: BIOS failure ??? DEll Systems OptiPlex GX270 Series
this may or may not help, try taking out the cmos battery out (looks like a watch battery) and leave for a few minutes then replace, this will reset the bios.
Posted on Nov 17, 2008
teknowolf
  • 207 Answers
SOURCE: restoring dimension 9150
Yvon,
It sounds as if your restore partition has become corrupted. You vcan Contact Dell and order a restore disk
As far as trying to Install from Install CD goes. Well Win XP does NOT recognize SATA drives natively. You have to install the sata drivers to get them to appear. You can download them from the link below.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=XPS/DIMENSION%20400/9150&os=WW1&osl=en&catid=&impid=
If you have a floppy drive, this is easy just copy to a floppy. Then during the install WinXP says something to the effect of "Press F6 to install 3rd party or RAID drivers" hit <F6> and direct it to the drivers on the floppy.
You should now be able to complete your WinXP install.
If you don't have a floppy drive post back here and we'll try to see if we can get the drivers in there another way.
Thanks
Dave
Posted on Nov 21, 2008
SOURCE: PXE-E53 and 1962 No operating system found error messages
On the NetVista S40 you can get to the boot order thru the BIOS menu (press F1 at power-on).
In the BIOS menu select Start Options (hit Enter), the next menu has Startup Sequence selected, hit Enter. You should now see the boot order change page.
The NetVista 6341 BIOS should be similar to the NetVista S40.
Hope this helps.
Posted on Dec 31, 2008
Dell inspiron 560 won't recognize network adapter
if there is no netework adapter in device manager or any device that is not instaled try checking in BIOS if it is enabled. sometimes after power loss bios is reset. if it is enabled in BIOS that short power outage probably killed your network adapter. you can add some PCI network adapter and solve your problem.
Nov 04, 2012 | Dell Inspiron 560 MT Celeron 450@ 2.2GHz...
Tip
Solutions on IBM Password Reset
We, IBM users, often meet problem with power on password, need IBM password reset or recovery for the OS like Windows 7, Windows XP, Windows Server, etc. What's the most efficient way to reset IBM password for our IBM laptop or desktop computer owners? Whatever the PC is IBM ThinkPad, IBM ThinkCentre IBM NetVista, IBM IdeaCentre or not, we can choose anyone to solve password problem:<br /><br />1. DIY your own IBM password recovery disk <br />It is the most efficient and easiest way to help you reset IBM password without reinstalling the system. Take one of the most popular password reset tool - Ainorsoft Windows Password Recovery software as example, 3 quick steps to help us get out of problem:<br />a. Download <a href="http://windowspasswordrecovery.net">Ainorsoft Windows Password Recovery </a>software and burn an .iso image file to a blank CD/DVD/USB Flash Drive from an available PC;<br />b. Set your target computer to boot from the burned CD/DVD/USB Flash Drive;<br />c. Remove forgotten IBM password with the burned CD/DVD/USB Flash Drive.<br /><br />2. Try default Administrator account<br />We can use default administrator account for IBM password recovery. In IBM Windows XP, 2000, Vista, there is a built-in Administrator user account that is auto generated when we install and without password protected. If we didn't change this Administrator's password, then boot system from Safe mode and login in with the accounts to reset IBM windows password.<br /><br />3. Access IBM password from other user accounts with administrator rights<br />If we have another user account which owns administrative privileges, follow the steps below to reset IBM password (take IBM Windows 7 as example): <br />a. Start computer by pressing F8 key to enter Advanced Boot Options before Windows 7 loading screen appears.<br />b. Choose Safe Mode at the Advanced Boot Options screen and Enter to login with the accessible admin account.<br />c. Click Start and input lusrmgr.msc into the Search box.<br />d. Double-click Local Users and Groups, and then click Users in the Local Users and Groups screen<br />e. Right-click the account that we will reset its password, and then click Set Password.<br />f. Input and confirm the new password.<br /><br />4. Use Ophcrack and Offline NT Password & Registry Editor<br />They are two common free password recovery tools. We just can have a try with them. Ophcrack can reset passwords no longer than 14 characters using only alphanumeric characters.<br /><br />With the above four methods on IBM password reset, we, IBM computer users, will be ease once IBM reset password happens to us and needs IBM password removal . Even the IBM rescue and recovery password problem, we can refer to the first solution to help us whatever the OS is Win XP, 7 or others.<br /><br />Source:<br />http://windowspasswordrecovery.net/article/ibm-password-reset.html
on Mar 29, 2011 | Computers & Internet
I forgot my computer password
Is this BIOS password or Windows Password?
BIOS Password can be cleared by CMOS reset, but you would have to crack it open to get to CMOS battery.
Link below is a tutorial for Bios
Top 3 methods to crack bios password!
Windows Password can be force changed with a bootable USB thumb drive with a Windows Password Recovery Tool using a Linux Distro. I am guessing you dont have a CD or DVD drive, so you will have to create a bootable USB drive with the password reset tool. OR reinstall Windows via External CD or DVD Drive and software or create a bootable thumb drive of say 8GB in size with the OEM disk copied to that drive if it allows with piracy protection maybe not allowing OEM CD or DVD to be copied to another drive.
Link below is a reset tool for Windows Password Recovery
May 05, 2011 | HP Computers & Internet
I lost my password my screen is locked how can I reset or bypass?
This is about topic bypass Windows logon screen. Command Prompt or recovery utility is effective ways for reset or bypass lost Windows password.
First, run command prompt with administrator. And you can reset Windows lost password with this command. Net user <new user> <new password>
Second, take recovery utility to burn a password reset disk. And this reset disk is the key to remove or reset Windows password, applied for standard or admin account. When your computer is installed with Windows 8/7/Vista, forgotten user password would be removed. If it is Windows server 2012/2008 etc, password would be reset as "iSunshare@2012".
Mar 18, 2011 | Sylvania G-Netbook
Pc password does not work can"t access pc. can"t get into safe mode to change password. please help!
Need to download pc lo-gin and create under image burning option, from any nerro,
boot from cd ,http://www.windowsreinstall.com/articles/bios/
start pc >press F10/F 2/Dell setup bios for boot pioroty.
Insert cd in your cd tray and it will automatically reset password ,
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya
Jan 20, 2011 | Dell Inspiron 530 Desktop Computer
Reset emachine bios password
this is very simple to reset emachine bios password
simple open cabinet of cpu then remove litheum battery of emachie. restart the machiche with battery the password will reset.
Enjoy..
May 06, 2010 | Computers & Internet
I forgot the admin password. i'm using IBM computer windows xp. I have the CD for the password unlocker but when i go to BIOS it asks me for a setup utility password....Help! Thanks!
You need to turn off your computer and unplug the power cord. open up the box and find on the motherboard the jumper for the battery. Cut off the power from the battery for 30 seconds. The BIOS will reset to the default values.
Now, when you turn on your computer, will be able to access the BIOS, no password requested (default value for password). You also need to reset all your parameters as required by your specific setup.
Advice: if you don't have a strong reason to password the BIOS, don't do it.
Oct 10, 2009 | IBM NetVista PC Desktop
Dead thinkpad by ibm
The CMOS battery supplies energy to the Real Time Clock when the computer is not connected to the electrical socket, and does not have the battery inserted. It should not prevent the computer from starting up. You will however be asked to reset the time and date of the computer.
Hope it helps.
Oct 03, 2009 | IBM ThinkPad R50e Notebook
T60 not powering up
the battery might be so dead that it's faulting the charging system, remove the battery, remove the power then plug it back in (with out the battery) and try turning it on,.. if that doesn't work try looking up how to reset the bios (or remove the bios battery) for a BIOS reset.
Mar 27, 2009 | IBM Lenovo ThinkPad T60
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
