Question about Irons
Stuck steam button on black and decker iron - Irons
  • 4 Answers
SOURCE: Iron Cleaning
If steam iron clogs from minerals in water, follow use-guide directions for cleaning, or use a commercial iron cleaner. A fine needle in the nozzle hole may open it again. Sometimes "steaming" will remove lint clogging the iron; fill with at least 1/4 cup water, set it to "steam", and hold in the air or set flat on wire rack over heat and moisture resistant surface like counter protective mat. Let steam until empty. Using only distilled water in steam irons helps avoid mineral buildup. Or if you have burned stains or darkness on the bottom you can Heat equal parts of vinegar and salt in small pan rub solution on cooled iron surface to remove dark or burned stains
Posted on Feb 18, 2008
VOTIT
  • 2071 Answers
SOURCE: Black & Decker Iron - Steam Advantage - won't turn on
Just open your flat iron and locate the face plate contactor that has a soot burn causing the filament not to heat,use a sand paper to clean the contact from soot burnt,this the common problem of a flat iron...
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 10, 2008
electrodynam
  • 35 Answers
SOURCE: the black and decker iron wont heat up
It probably has a high temp overload opened up inside or the thermostat control has gone bad.You can only tell for sure by taking the unit apart and testing the circuit for continuity.The steam feature on the iron is heated by the same element that heats the iron so it wont work.the element itself could also be bad,but I have never seen one go bad.You will have to check each component seperately to find the damaged part.or you can test the whole circuit at the plugs end,and use a jumper across each part until you have continuity through the unit.Make sure the thermostat is turned all the way up.the part that you are bypassing when you get continuity is the bad part.
You can buy a cheap continuity checker at any lowes,or even wallmart for that matter.
Posted on Mar 16, 2009
heatman101
  • 43501 Answers
SOURCE: Black 7 Decker Steam Express AS250 Iron
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
  • 10 Answers
SOURCE: instructions for steam clean on B&D iron
http://useandcaremanuals.com/pdf/D1200,D1500,D1600,D1650997.pdf
Or http://useandcaremanuals.com/SearchManuals.aspx?SiteID=4
Hope this helps you.
Posted on Aug 02, 2010
Just plugged in brand new iron and the variable steam dial won't move
please take it back, it will only give you more problems. irons are not made as well as they use to be.
Jan 24, 2015 | Black and Decker USA Applica Black &...
How do i prevent my black and decker classic iron from spitting out how water after I have used it for a while?
Cheaper irons may steam better using distilled water. Minerals in water can cause this due to build up inside.
Oct 01, 2014 | Applica Black And Decker Classic Iron With...
The steam wheel on black and decker digital advantage is stuck in the no steam position
This problem developed with our iron within the last week. Playing around with it today, I discovered that the dial WOULD respond to "persuasion". I forced it, and it cooperated. Find somebody with a stronger grip and try it.
Aug 03, 2013 | Black & Decker D2020 Iron
Steam button stuck
put some vinegar in your iron and swash it around. It will remove the calcium or lime that is making your button stuck. Be sure to run a lot of water through the iron after or your clothes will stink.
Apr 24, 2013 | Black & Decker Irons
Black rubber burned onto plate of iron
Here is a tip that will help you with that problem...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Apr 12, 2010 | Black & Decker ProFinish X750 Iron
I have bought a swan s15040n steam generator iron and it does turn on but I can't get to generate any steam. I have tried holding the steam button down for 20 seconds ( and more) but still nothing. Any...
Try holding the iron well below the base with the cord straight and pressing the steam button, this will release any airlock caused by a changing the filter
Jul 13, 2009 | Black & Decker Steam Generator SG200 Iron
Hope this may help;
Regards,
VOTIT
Aug 10, 2008 | Black & Decker Steam Xpress AS250 Iron...
Irons Logo
35 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
