Question about Apple iPod nano
Dead, Locked Ipod
Hey, I accidentally hit the "lock" button on my Ipod Nano and I never set the combination, so I didn't know what it was. I decided I would eventually figure it out by going through all the digits in numerical order. Well, this killed my battery so now it won't turn on (like, it won't show the locked symbol or anything). I tried to plug it into my computer but it didn't do anything. I tried resetting it (while I had it plugged in), but this didn't do anything either. Now when I plug it in it just flashes the Apple sign and it doesnt do anything else. Please help!
  • 342 Answers
I would leave the iPod connected to power for at least two hours before attempting to reset again. Also this web site I have posted below may be of assistance to you. If you can get the iPod to power on after charging for a while, You will need to attempt to force the iPod into disc mode and restore. This is the ONLY way to get the iPod unlocked with out the code. :( I wish there was another way but as of yet this is it. Below is also a step by step on disc mode and restoring just in case you need the information. Please do let me know if this does not resolve your issue
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
How to restore iPod (ARTICLE NUMBER HT1339)
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time
Posted on May 18, 2009
Locked screen
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
Nov 02, 2009 | Apple iPod nano
Ipod 4gb
If you have all your music on your computer just plug in the ipod and hit restore in iTunes and it will remove the code. Hope this helps!
Feb 02, 2009 | Apple iPod nano
Ipod screen is locked can't remeber the combination!
Hey there Potterfan,
Weep no more, I'm here to dry those tears:
The combination is hold Menu and Select until the apple logo appears. You'll probably need to charge it first though as it's been a while.
All the best
Sean
PiDigital.co.uk
Dec 13, 2008 | Apple iPod nano
How do I Unlock Ipod screen if I forgot the 4 digit password?
no no no no no no no!!!!!!!!!!!!!!!!!!!!!!
When connect ipod to computer, go to my computer. Click on ipod:-
-click on tools, go to folder options
-go to view tab
-check show hidden files
-a ghost like folder will apear: ipod control
-click on it and go to device
-there will be a locked file
-click and delete it
Your ipod is unlocked!!!!!!!!!!!!
JOHN
If you don't understand, go to this website on you tube!
http://www.youtube.com/watch?v=Au6H_u-q434
Sep 30, 2008 | Apple iPod classic MP3 Player
Locked iPod
You can unlock your iPod nano in two ways:
A Enter the combination on iPod nano by using the Click Wheel to select the numbers
and pressing the Center button to confirm them. If you enter the wrong
combination, it flashes red. Try again.
A Connect iPod nano to the primary computer you use it with, and iPod nano
automatically unlocks.
Note: If you try these solutions and you still can’t unlock iPod nano, you can restore
iPod nano. See “Updating and Restoring iPod Software” on page 50 for more
information.
Sep 03, 2008 | Apple iPod nano
Locked ipod
information.
Aug 23, 2008 | Apple iPod nano
How do I prevent my ipod volume from getting too loud?
First off, use the "MENU" button to navigate to the very top of your iPod menu, then choose "Settings":Within settings, you'll find "Volume Limit": Choose that and you can now specify the maximum allowable volume that the iPod will play by simply spinning the wheel clockwise or counterclockwise:Like your new setting? Push the button in the middle of the wheel to set it, then enter a four-digit combination to lock it in place:"Set Combination" looks pretty cool, actually, kinda like some safe cracking game or something:
If your ipod is in your pocket, you can use the hold button at the top of the ipod
Jul 20, 2008 | Apple iPod nano
Ipod nano lock forgot password
-go to view tab
JOHN
Jul 19, 2008 | Apple iPod nano
Unlocking my ipod nano
There is only one way - and it will erase all your songs:
If you lock your iPod nano screen and can’t unlock it
Normally, if you can connect your iPod nano to the computer it is authorized to work
with, your iPod nano automatically unlocks. If the computer authorized to work with
your iPod nano is unavailable, you can connect iPod nano to another computer and
use iPod Updater to restore your iPod software. See the next section for more
information.
If you want to change the screen lock combination and you can’t remember the
current combination, you must restore the iPod software, and then set a new
combination.
You can use iPod Updater to update or restore your iPod software. Apple periodically
updates iPod software to improve performance or add features. It is recommended that
you update your iPod nano to use the latest software. You can also restore the software,
which puts iPod nano back in its original state.
â If you choose to update, the software is updated, but your settings and songs are not
affected.
â If you choose to restore, all data is erased from your iPod nano, including songs, files,
contacts, photos, calendar information, and any other data. All iPod nano settings are
restored to their original state.
To update or restore iPod nano with the latest software:
1 Go to www.apple.com/support/ipod and download the latest iPod Update. The update
has the latest software for all models of iPod.
2 Double-click the software installation file and follow the onscreen instructions to install
the iPod update.
3 Connect iPod nano to your computer and open iTunes. The iPod Updater application
opens.
If you’re using a Windows PC and the iPod Updater application doesn’t open
automatically, you can find the updater by choosing Start > All Programs > iPod.
4 Follow the onscreen instructions to update or restore iPod software.
If you use the iPod Updater application and it doesn’t recognize that iPod nano is
connected to your computer, reset iPod nano (see page 45).
If you want to restore iPod software and you don’t have an Internet connection, you
can use the iPod Updater application that was installed on your computer when you
installed the software from the iPod CD.
-Tha Mp3 Doctor
May 28, 2008 | Apple iPod nano
Apple iPod nano Logo
128 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
