Question about Kohl Ben 10: Ultimate Alien For Cosmic Destruction Playstation 2
Ben 10 cosmic destruction disk says error reading disk
I was playing for 2 hrs
While attempting to install Diablo 2 LoD on my Windows 8.1 laptop, I keep getting this error message: Line # 855, Unrecoverable internal error 6fe22flb Help!
Sounds like you could be having a reading error with the disc, I recommend you try another CD if possible, if not you could download the torrent online, and use your own serial key (that way it isnt illegal, and you are able to play it without the CD)
Nov 09, 2014 | Blizzard DIABLO 2: LORD OF DESTRUCTION...
Hi,I need some help with the game : "Ben 10
Pause the game and enter the following cheats for the desired effect.
  • CASH - 1 Million DNA cash
  • HARD - Deal half damage, take double damage
  • ENERGY - Energy
  • HEALTH - Health
  • LEVELS - Unlock all levels
  • CLASSIC - Unlock Fourarms
  • PRIMUS - Unlock Rath
  • UPGRADE - Upgrade everything to max
Mar 05, 2011 | Video Game Consoles & Games
How to pass in the ledges in paris in ben 10 ultimate allien cosmic destruction
Right off the bat, spin the camera around 180 degrees and you will see a blue glowing object which is the first Sumo Slammer (SS4) of this level. Go over and grab it and destroy the 2 benches nearby. Head to the back wall near the water and you will be prompted to change into Waterhazard. Do so and jump up to the pipe and shimmy your way across. Then cross the second one the same way. Now on the back wall you will see an open window that you can jump to. While hanging you will see another open window to the left. Jump over to it and grab that window ledge next. Then continue to make your way across the next 2 ledges and you will come to a small platform that you can climb up. Once on top you will see another open window above you and to the left. Leap to it to grab it and continue on to the next couple of windows. Once you make it to the 2 large windows then you are safe to drop down. Shimmy across the next pipe and move up the stairs. Kill the 3 guys that pop up and then use Waterhazard to shoot the water symbol on the switch which can be seen on the other side of the gate. Destroy all the benches, plants, crates, barrels and dumpsters before moving on. Now, switch to Swampfire and shoot the green gas coming out of the pipe which will blow a hole in the wall and drop a toxic spill on the ground. Switch to NRG to walk through the spill. Kill all the guys that pop up and move through the doorway that just opened up. You will be introduced to Snipers at this point. First, move to the left and melt the pole with NRG like the girl tells you too. Then head to the left and destroy the truck and toxic barrels. I like to use Swampfire's fireball attack for this but go with whatever makes you happy. The gates will open and a lone enemy will run down any attack. He's nothing special so just kill him and move on up the stairs. By the time you reach the top more enemies will have spawned so take them down however you like. On the right side of the area you will see some pipes on the wall. Using Swampfire, leap up to the first one and grab it. Now continue along these ledges to make it to the upper patio on the right side of this wall. Jump to the patio and head inside the building where you will be introduced to a new ranged enemy. Kill him off and then take out the next couple that pop up. Head through the open doorway, down the stairs and to the save point. Be sure to use it, destroy the suits of armor and continue downstairs.
source: http://www.gamefaqs.com/ps3/995983-ben-10-ultimate-alien-cosmic-destruction/faqs/61008
Feb 28, 2011 | Sony PlayStation Portable (PSP) Console
Ben 10 Alien Force - unable to play 2 players mode. "Press A" does not work.
u have to sync another remote steps:
1- menu button
2-wii remote
3-press both 1,2 simultaniously
4- there u go both are connected
Apr 15, 2010 | D3 Publisher Ben 10: Protector of Earth...
NAD T532 probem
CD and DVD disks use a different set of optics for each type of operation. Some units have a different laser for the different format types.
The fault could be mechanical alignment, calibration, or a failure in the signal and or processor path. These types of faults are impossible to guess at.
If the unit is under warranty, contact the dealer to find out how to get it serviced. If out of warranty it may not be feasible to service.
Jerry G.
Dec 02, 2008 | NAD T532 DVD Player
Ratchet and clank future: tools of destruction game doesnt play
I have read through some forums for you, and it appears that there is a bug that reads your disk as full even if it is not. The fix is to add at least 500MB of game data to your harddrive, then it will work. I think the bug was on the american version of the game. It read an almost empty harddrive as full.
I hope this helps
Nov 27, 2008 | Sony Ratchet & Clank Future: Tools of...
HDD Error
Since my last post, I have rectified the problem.....
1) I opened the unit to find a seagate HDD
2) I downloaded the Seatools in dos format and burned the image on to a cd rom
3)Taking out the HDD from my recorder,I hooked it up to another pc and ran the seatools disk @ bootup.
I tried for 2 hrs to repair the bloody thing ( 160 gb!) so i gave up and tried to erase the full HDD...which worked.
4) on my laptop i navigated to Pioneers site and found my recorder along with instructions and a zip file that contained 2 files.
5)After reading the destructions erm i mean instructions ;) I put the HDD back into the recorder and followed the instructions again..
Crossing my fingers i turned the recorder back on and to my amazement i was able to have more functionality..BUT... it says my HDD name error so I ran the disk again and wallah! all worked XDDDD
Here are the links
http://www.pioneer.co.uk/uk/content/support/support/update/DVR.html check if your model is there.
http://download.seagate.com/seatools/registration.nsf/desktop?openform Just add your email too download.
I hope you fix yours XD
May 05, 2008 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Kohl Ben 10: Ultimate Alien For Cosmic Destruction Playstation 2 Logo
69 people viewed this question
Top Kohl Video Game Consoles & Games Experts
James Wishart
Are you a Kohl Video Game Console and Game Expert? Answer questions, earn points and help others
