Question about Samsung Illusion SCH-I110 Verizon Android Smartphone
My phone is locked and cant activate it. how do i unlock it
How do I activate my new phone
hey gary what kind of phone do u have , there are a thousand diffeant phones out here and you want to know how to activate , what
Jan 09, 2015 | Cell Phones
Remove icloud lock
You cant unless you have proof that you bought it, and can take it to the Apple store. Otherwise, it is a cute little brick.
Aug 31, 2014 | Apple iPhone 5S
What is a activation key
HI if you want to activate your phone with your sim then you must first check that whether the phone is locked or unlocked one .If the phone is unlocked one then you can easily activate it with any GSM sim .Else if the phone is locked to some other network provider then until you unlock it you can't freely use it with any GSM sim .You can easily unlock your phone using sites like Unlocking4U.com they are providing unlock code for all mobile models at reliable cost ......
Mar 06, 2014 | Cell Phones
How can i unlock a phone , that was not scaned , four years ago , so i may use it ?
Do you mean the network unlock?I suggest you can approach Prounlocking.com and specify the country,locked network of SamsungE250.Based on the availability you can get the unlock code along with free instructions.
http://www.prounlocking.com/samsung-sgh-e250/rs8wp9/
Feb 13, 2014 | O2 Samsung SGH-E250 Cellular Phone
How can unlock iphone5 app icloud?
Hai, What's your current locked carrier? You can unlock your iPhone 5 by using Remote unlocking method. It's one of the best and safe way to unlock your iPhone 5 .If you are interested in this method visit Theunlockarena.com . Here you can unlock your phone at low cost.
Feb 07, 2014 | Apple iPhone 5
Hi I Cant Find A Free Sim Unlock Code For A Samsung Sgh J700i Could You Help Me?
1- Power on phone, type : *#7465625#
you will identify which code is active , which is inactive
2- Remove battery, Put your sim card, not all of it, just to prepared for it to be full inserted, put your battery back and power on phone, you must see " insert sim" not "invalid sim.."
3- type : *2767*3855#
your phone should restart after 1 min,
now, and before it restarts, push your sim card in, without removing battery.
4- your fone should work and accept the sim card ,, but if you chek locks you will find that your fone is still Loked
5- now type : *7465685*638*00000000*00000000#
your UNLOCK CODE is 00000000 now , Enjoy
6- now , back to Locks table with : *7465625*, and for each active code you can disable it, here details :
* Disables CP lock : #7465625*27*00000000#
* Disables Network lock : #7465625*638*00000000#
* Disables SIM lock : #7465625*746*00000000#
* Disables SP lock : #7465625*77*00000000#
* Disables Subset lock : #7465625*782*00000000#
Dec 15, 2010 | Samsung J700 Cellular Phone
My phone got lock and i cant unlock i forgot the code and i cant call or anything until i unlock it with the code
hi try these codes
*#06# Show IMEI *#9999# Show mobile Software Version *#0837# Show mobile Software Version (instructions) *#0001# Show Serial Parameters *#9125# Activates the smiley when charging *#0523# LCD Contrast
*#9998*228# Battery status (capacity, voltage, temperature) *#9998*246# Program status *#9998*289# Change Alarm Buzzer Frequency *#9998*324# Debug Screens *#9998*364# Watchdog *#9998*377# EEPROM Error Stack - Use side keys to select values *#9998*427# Trace Watchdog *#9998*523# Change LCD contrast *#9998*544# Jig detect *#9998*636# Memory status *#9998*746# SIM File Size *#9998*778# SIM Service Table *#9998*785# RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error *#9998*786# Run, Last UP, Last DOWN *#9998*837# Mobile Software Version *#9998*842# Test ******** - Flash the screenlight during 10 sec and vibration activated *#9998*862# Vocoder Reg - Normal, Earphone or Carkit *#9998*872# Diag *#9998*947# Reset On Fatal Error *#9998*999# Last/Chk *#9998*9266# Yann debug screen (Debug Screens?) *#9998*9999# Software version *0001*s*f*t# Changes serial parameters (s=?, f=0.1, t=0.1) *0002*?# unknown Samsung's comand *0003*?# unknown Samsung's comand For Mobile phones SGH (R210, T100, A300...) if Samsung code is in format *#9998*xxx# try write in this *#0xxx# SGH-600 SGH-2100 *2767*3855# Full EEPROM Reset (THIS CODE REMMOVES SP-LOCK! but also changes IMEI to 447967-89-400044-0 *2767*2878# Custom EEPROM Reset Samsung mobile phone codes: Samsung E700 *2767*688# remove USER CODE and SIMLOCK Samsung mobile phone codes: Samsung V200 Unlocking: Power on the mobile phone without SIM card and type these codes: *2767*63342# and press green button *2767*3855# and press green button *2767*2878# and press green button *2767*927# and press green button *2767*7822573738# press button Phone will be unlocked, but all trims are reseted !!! Mobile phone must be fully charged Samsung mobile phone codes: Samsung S500 Unlocking *2767*MVT# (*2767*688#) E2P MVT Reset *#SIMLOCK# (*#7465625#)
May 12, 2010 | Samsung Smooth SCH-u350 Cell Phone
I found an lg vx9900 but the phone has a locked code and i cant unlock it. can you help me?
Unfortunately the phone will need to be activated and programmed on a number before it can be unlocked. Then the lock code will be the last 4 digits of that cell number. Take it to your local Verizon store and see if they can assist you further.
Oct 09, 2009 | LG enV VX9900 Cellular Phone
Samsung Illusion SCH-I110 Verizon Android Smartphone Logo
22 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
