Question about HealthSmart DigiScan Multi-Function Infrared Thermometer DigiScan Multi-Function Infrared Thermometer
What 'buttons' are used to change date, time, etc.?
On firefox can't open my email it says untrusted
Pls.check your system date & time is correct ???
Pls Try to correct your systems Date & time on the extreme right corner of your screen.
after change date & time it corrected.
if Problem comes again with Date & Time you need to replace BIOS / Motherboard Battery.
How to change date & time
Option 1>>>
Open the command prompt:
  • Click Start.
  • Type "command prompt."
  • In the results, click on Command Prompt
  • Type the word "time". Type a space, and enter the new time in the following format:
    • HH:MM:SS AM/PM. For example, time 5:34:00 PM, time 12:15:00 AM, etc.
    • Press enter or return.
Type the word "date". Type a space, then enter the new date in the following format:
  • MM/DD/YYYY. For example, date 5/15/2009, date 2/14/1999, etc.
Option 2>>>
  1. 1Open the command prompt:
    • Click the Start button.
    • Click on All Programs.
    • Click Accessories.
    • Click Command Prompt.
  2. 2Type the word "time". Type a space, and enter the new time in the following format:
  3. 3Type the word "date". Type a space, then enter the new date in the following format:
  4. 4Check the clock in the bottom-right hand corner. The time should be successfully change.
Sep 02, 2014 | Google Computers & Internet
How do I change the time and date on the driver information center on my 1988 cadillac eldorado?
There is a little pin that u push in with a paper clip or a needle. It is located below fuel used and fuel reset buttons. U can hardly see it if theres dirt in it.But you press it in and it will advance u through the time date etc and u change the time etc. with the up and down arrows on the first 2 buttons.
Apr 04, 2011 | 1988 Cadillac Eldorado
How do I set the time and date on my 1440
hi,
You can try this by:
Press and hold the "MODE" button (top left) until the alarm time begins to blink. Use top right button to change from minute to hour etc, and change the value for the setting that is flashing by pressing the bottom right button "SET". Change from alarm to date to time by pressing the upper left button again.
Hope this will help you.
Thank you for choosing fixya
Feb 27, 2011 | Timex 1440 Nylon watch
How do I adjust the time and date etc.
IN THE OUTER PROFILE YOU HAVE FOUR BUTTONS,JUST PRESS THE TIME/DATE BUTTON AND IN THE CENTRE OF THE WATCH YOU FIND THE DAY(EG:SUNDAY)IS BLINKING,JUST PRESS THE OPPOSITE SIDE BUTTONS TO CHANGE THEDATE,AFTER CHANGING DAY,AGAIN PRESS THE DATE/TIME BUTTON NOW APPEARS THE TIME BUTTON(EG:11.00 HRS),NOW PRESS THE OPPOSITE SIDE BUTTON FOR CHANGING ......
THANKING YOU.........GOOD DAY
Sep 22, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
Configuring time, date etc for my O.T.S watch
http://www.worldofsportwatch.com/en/product-3315.html
This is a link to a website that has OTS watches on it. Click on the OTS watch you have and there is a manual selection. The instructions are a bit hazy but basically you have to press the mode button 3 times, the reset button to get to what you want to change, and then the start button as many times as needed to change it to what you want. I finally corrected my watch time and date using it. Thankfully!
Jan 01, 2010 | JCPenney Armitron Sport Watch
Time & Date
1. To open the USER SETTINGS MENU. Open all three of the One-touch speed dialing panels. Then press the button labeled "Data Registration".
2. Press the "SET" button 2 times until you see:
USER SETTINGS - 1. DATE & TIME.
3. To open the DATE & TIME Menu. Press SET.
Use the buttons on the numeric keypad to enter the current month, day, year and current time. Just enter the new numbers over the old numbers.
To set the year, enter 08, 09, etc.
Use the 24-hours format to enter the time (e.g. 1:00 p.m. would be entered as 13:00)
You can also use the cursor buttons to move the cursor without changing a number entry.
To restore previous entry, press CLEAR.
Press SET to "lock in" the Date and Time.
Jul 10, 2009 | Canon LaserCLASS Fax 710 Printer
I cant reset the time on my watch it is a stark -1082
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
Oct 28, 2008 | Fossil Philippe Starck PH1026 Wrist Watch
MY TIME DATE ARE BLINKING WILL NOT STOP CANT RESET
Wouldn't bother me, been nuts forever -
If yours is equipped with the center screen containing date/time etc., press, no jab repeatedly the 'Select' button, maybe you can get through the crud on the contacts to get started. If this is successful, you should have something blinking. You can change it then by pressing (yeah, JABBING) the 'Set'  button until you have the date etc. you want. The switches behind those buttons are the ones they should have used for the Big Red Button in DC so no one can accidentally start a war.
BTW, if yours is like ours, the time (just to be completely moronic) is set via the radio with two tiny (also unreliable) switches you must access through tiny holes with your best ballpoint to set the time that will appear on that annoying panel.
Sep 29, 2008 | 1995 Jeep Grand Cherokee
Setting Bench Watch
Reset Instructions Bench. (BC0013BR)
Time and Location
If you hold in the light, start and the reset button for a few seconds a screen will appear with the 12h or 24 h clock setting and also the date and country.
Once you have that screen if you press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time.
Once you have changed the date and time to the correct date press the light button, start button and reset button and it will save the settings.
Alarm
Hold in the light, start and the reset button for a few seconds a screen will appear
press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time. Use the light button to set the screen.
Feb 27, 2008 | Watches
Philippe starck ph-1071
Dec 26, 2007 | Fossil Philippe Starck PH1026 Wrist Watch
HealthSmart DigiScan Multi-Function Infrared Thermometer DigiScan Multi-Function Infrared Thermometer Logo
32 people viewed this question
Top HealthSmart Home Experts
Donni Steen
Tom Chichester
Are you a HealthSmart Home Expert? Answer questions, earn points and help others
