Question about Dryers
Whirlpool help freezer works but fridge is hot
  • Dryers Master
  • 9,742 Answers
Thermostat on refrigerator side needs to be checked.
Posted on Jan 05, 2014
  • Whirlpool
    Whirlpool Feb 07, 2014
    Hi, there. While we cannot assist with repairs I can offer links to our troubleshooting, use and care guides, replacment parts, parts lists, and service line should that be necessary. We hope this helps. http://bit.ly/zkfnZdhttp://bit.ly/112Lu7qhttp://bit.ly/LrNZiShttp://bit.ly/yLv4Z5
I have a Whirlpool wbm46mw Fridge, the freezer is working ok but fridge not getting cold, any suggestions,Thanks
Empty fridge and if possible put steam down vent behind the cover in the freezer section. or hot water. it will com out in the fridge so be carefull. this unblocks the aif feed from the freezer to the fridge section. also make sure the fan is working.
Oct 04, 2013 | Engel Freezer 22 Qt. Fridge/Freezer
Freezer cold fridge isnt
freezer working,fridge not working,condenser fan ok, compressor running very hot.
Dec 14, 2011 | Whirlpool GS6NBEXR Side by Side...
Freezer is working fridge is not
Hello Carmenbonds,
I understand that you are having a problem with your refrigerator not working, the freezer side is working but the fridge side is not cooling. This is a common problem that happens when your evaperator fan is not working. I have wrote a tip that will help you with this here is a link to it.
Freezer freezing but Fridge is Hot.
Thank you for choosing FixYa.com
Justin
May 10, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool sise by side fridge mod # ED5FHEX5SNOO Whirlpool side by side: --------------Fan running -------------------------Compressor not running (not clicking) --------------------Freezer ok, FRIDGE NOT...
YOUR SAFETY SWITCH IS CUTING OF. THIS SWITCH IS NEAR THE COMPRESOR. SHOULD COMPRESOR GET VERY HOT IT IS INDICATION THAT IT NEEDS TO BE REPLEACED. IN THIS CASE SOMETIMES IS BETTER TO GET NEW FRIDGE AS REPAIRES MIGHT COST TO MUCH
Mar 02, 2011 | Whirlpool Refrigerators
The strip between freezer and fridge is very hot
sounds as if you either need to clean the coils under the unit,they are clogged and unable to disapate correct amount of heat, or your fan mounted behind the unit, next tothe compressor has failed..YOUR UNIT IS WORKING EXTRA HARD TO GET RID OF HEAT.check those 2 places
Jun 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Panel between fridge and freezer very hot and no sound at all
Hi: Its just a coincidence you noticed it then. It is usually hot. It's the reverse side of the refrigerant (the hot side.) If you lived in a humid area the fridge would sweat. Water would run down between the doors. I live in a dry climate so no worries. Older fridges used an electric heating element to keep them dry. They also had an energy saver switch to turn it off. As Whirlpool uses the hot side of the refrigerant they don't use additional power to run the heater. Actually the heater is called a mullion heater. Nothing is wrong with your fridge. I'll look over my shoulder for angry retailers. Hope this helps, Jeff.
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Fridge and Freezer quit cooling properly at the same time.
You likely have a defrost system problem.....call a service company to look at it.
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge Freezer is blowing out hot air, is this fixable and cheap to fix?
is this under warranty? not a year old? thermostat or low refrigierent in compressor.thermo replace price ok.comp refrig can be expensive. hope this helps
May 21, 2009 | Whirlpool Freezers
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Jan 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Dryers Logo
Top Dryers Experts
