Question about RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2
How do u remove rear axle outer seal on mf farm tractor 231s
I have axle shaft and bearing housing removed but lost on how to get that seal removed from bearing housing
3 Suggested Answers
  • 5537 Answers
SOURCE: my to30 P.T.O shaft is
Hello, I have in front of me a catalog for Valu-Bilt.Com, a tractor supply company for all makes. Your Seal can be one of several depending on the Serial number of your tractor. There phone number is 1-888-828-3276.
The Catalog I have shows a Model 35, but I see you have a Model 30. I believe the transmissions were different between the 30 and 35, but see no reason for the rear end to change. The later Model 35 had more gears like a Sherman unit. The Model 35 had a model with 2 extra forward gears and the model used as a Front Loader had 2 extra in both Forward and Reverse.
Now Ferguson and Ford were similar, with the Ferguson having more innovations. Check with a Ford Dealer for PTO seals. The Continental engine was desired as it had Overhead valves and more power over the Ford.
You may also get lucky with Tractor Supply who carry some parts. One additional thing is the number of teeth on the PTO shaft. The book shows a 17 tooth, 25 Spline as 1868528M1 for the Model 30 PTO shaft. The Model 35 has 10 Splines in both a 17 and 19 tooth shaft.
So it is possible you may not even have the original PTO seal if someone put in a part for a Model T35.
I hope this is helpful and would like to know if you found your part. Thanks
Posted on Jul 03, 2011
SOURCE: correct procedure for replacing outer axle seals
Try this diagram http://www.malpasonline.co.uk/CatalogueViewer/PageViewer.aspx?publicationID=138&startPage=300
Posted on Mar 18, 2013
1998 ford explorer 2 wheel drive rear wheel bearing replacement
what about it?
conventional axle or limited slip? Get axle code off door sticker.
SECTION 205-02: Rear Drive Axle/Differential - Ford 8.8-Inch Ring Gear 1998 Explorer/Mountaineer Workshop Manual
IN-VEHICLE REPAIR Rear Wheel Bearing and Axle Shaft Oil Seal -4.0L SOHC and 4.0L EI, Conventional
Special Tool(s) swn~us~en~file=st1514a.gif~gen~ref.gif Axle Seal Replacer
T83T-1175-A swn~us~en~file=st1283a.gif~gen~ref.gif Axle Wheel Bearing Puller
T83T-1225-A swn~us~en~file=st1322a.gif~gen~ref.gif Axle Wheel Bearing Replacer
T83T-1225-B swn~us~en~file=st1326a.gif~gen~ref.gif Driver Handle
T80T-4000-W swn~us~en~file=st1185a.gif~gen~ref.gif Impact Slide Hammer
T50T-100-A
Removal
  1. Remove the axle shaft; refer to Axle Shaft in this section.
Axle Shaft Removal
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not use heat to loosen a seized lug nut. Heat can damage the wheel (1007) and the rear wheel bearings (1225).
    Loosen the lug nuts (1012).
    1. Remove the center cap.
    1. With the weight of the vehicle on the wheels, loosen the lug nuts.
  1. Raise and support the vehicle.
  1. Remove the wheel and tire assembly.
    1. Remove the lug nuts.
  1. Remove the axle housing cover (4033).
    1. Loosen the axle housing cover bolts (4346) and drain the rear axle (4001).
    1. Remove the axle housing cover bolts.
    1. Remove the axle housing cover.
  1. Remove the rear disc brake rotors (2C026); refer to Section 206-04 .
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the differential pinion shaft (4211) has been removed, turning the differential case (4204) or an axle shaft (4234) will cause the differential pinion gears (4215) to fall out of the assembly. This could result in chipped or damaged components.
    Remove the differential pinion shaft.
    1. Remove the differential pinion shaft lock bolt.
    1. Remove the differential pinion shaft.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-rings in the U-washer grooves.
    Remove the U-washers (4N237).
    1. Push the axle shafts inboard.
    1. Remove the U-washers.
  1. Reinstall the differential pinion shaft.
    1. Install the differential pinion shaft.
    1. Install the differential pinion shaft lock bolt finger-tight.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the inner wheel bearing oil seal (1177).
    Remove the two axle shafts.
Installation
  1. Lubricate the lip of the inner wheel bearing oil seal.
    • Use Premium Long-Life Grease XG-1-C or equivalent meeting Ford specification ESA-M1C75-B.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the differential pinion shaft has been removed, turning the differential case or an axle shaft will cause the differential pinion gears to fall out of the assembly. This could result in chipped or damaged components.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the inner wheel bearing oil seal.
    Install the two axle shafts.
    Install the U-washers.
    1. Position the two U-washers on the button end of the axle shafts.
    1. Pull the axle shafts outward.
    1. Align the hole in the differential pinion shaft with the differential pinion shaft lock bolt hole.
    1. Install the differential pinion shaft lock bolt.
  1. Install the rear disc brake rotors; refer to Section 206-04 .
  1. Install the axle housing cover and fill the rear axle housing (4010) with 2.4 liters (5.5 pints) of specified lubricant; refer to Axle Housing Cover in this section.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Always remove any corrosion, dirt or foreign material that may be present on the mounting surfaces of the wheel or the surface of the wheel hub or rear disc brake rotor that contacts the wheel. Installing wheels without proper metal-to-metal contact at the wheel mounting surfaces can cause the lug nut to loosen and the wheel to come off while the vehicle is in motion, causing loss of control.
    Clean the wheel hub and mounting surfaces.
  1. Install the tire and wheel assembly.
    1. Position the tire and wheel assembly.
    1. Install the lug nuts and lower the vehicle.
    1. Tighten the lug nuts.
    1. Install the center cap.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Never remove the axle shaft oil seal by itself. Always remove the rear wheel bearing and the axle shaft oil seal at the same time.
    NOTE: If the axle shaft oil seal is leaking, the axle housing vent may be plugged with debris.
    Use Impact Slide Hammer and Axle Wheel Bearing Puller to remove the rear wheel bearing and the axle shaft oil seal.
Installation
  1. Lubricate the new rear wheel bearing.
    1. Use Thermally Stable Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
  1. Use Axle Wheel Bearing Replacer with Driver Handle to install the rear wheel bearing.
  1. Lubricate the lip of the new axle shaft oil seal.
  1. Use Axle Seal Replacer with Driver Handle to install the axle shaft oil seal.
  1. Install the axle shaft; refer to Axle Shaft in this section.
May 18, 2011 | Ford Explorer Cars & Trucks
How do i remove my rear axles on my 1977 dodge aspen
Top of Form 1
Raise the vehicle and remove the rear wheels.
Clean all dirt from the housing cover and remove the housing cover to drain the lubricant.
Remove the brake drum.
Rotate the differential case until the differential pinion shaft lockscrew can be removed. Remove the lockscrew and pinion shaft.
Push the axle shafts toward the center of the vehicle and remove the C-locks from the grooves on the axle shafts.
Pull the axle shafts from the housing, being careful not to damage the bearing which remains in the housing.
Inspect the axle shaft bearings and replace any doubtful parts. Whenever the axle shaft is replaced, the bearings should also be replaced.
Remove the axle shaft seal from the bore in the housing, using the button end of the axle shaft.
Remove the axle shaft bearing from the housing. Do not reuse the bearing or the seal.
Check the bearing shoulder in the axle housing for imperfections. These should be corrected with a file or polish.
Apr 24, 2011 | Dodge Diplomat Cars & Trucks
How do you change the rear wheel bearings on a 2004 chevy express 1500 van?
Axle Shaft Bearing & Seal Removal & Installation To Remove:
  1. Raise and safely support the vehicle.
  2. Remove the axle shaft.
  3. If replacing only the seal, remove the seal using a suitable seal removal tool.
  4. If replacing the seal and bearing on the 8.6 inch axle, install the slide hammer and adapter behind the bearing and pull out the bearing and seal together.
  5. If replacing the rear axle shaft seal and the bearing on the 9.75 inch axle, install the J 29712 or equivalent bearing puller into the axle housing behind the axle bearing.
  6. Remove the axle shaft seal and the bearing by tightening the nut on the J 29712 bearing puller.
Use a slide hammer, bearing puller and adapter to remove the old axle bearing 88457g81.gif
To Install:
  1. Install the axle shaft bearing using a suitable size driver. Drive the bearing into the housing until the tool bottoms against the tube.
  2. Lubricate the seal lip and install the seal with a suitable seal driver. Make sure the seal is fully seated in the axle tube.
  3. Install the axle shaft.
  4. Fill the rear axle with the correct lubricant.
  5. Lower the vehicle.
Oct 18, 2010 | 2004 Chevrolet Express
How to change the rear bearings in my 1997 grand cherokee limited
YOU HAVE TO SAFELY RAISE SUPPORT VECHICLE MAKE SURE ITS ON A SOLID LEVEL GROUND.THEN YOU REMOVE THE WHEELS THE BRAKE DRUM OR DISC.THEN YOU REMOVE THE NUTS THAT ATTACH THE OUTER SEAL RETAINER AND BRAKE BACKING PLATETO THE AXLE SHAFT TUBE.DISCARD THE NUTS.REMOVE AXLE SHAFT FROM HOUSING.WITH AN AXLE PULLER ATTACHED TO A SLIDE HAMMER.DISCARD INNER AXLE SEALPOSITION THE AXLE SHAFT IN A VISE.REMOVE THE RETAINING RING BY DRILLING A 1/4 HOLE ABOUT 3/4 OF THE WAY THROUGH THE RING. THEN USING A COLD CHISEL OVER THE HOLE.SPLIT THE RING.REMOVE THE BEARING WITH A ARBOR PRESS DISCARD THE SEAL AND REMOVE THE RETAINER PLATE.TO INSTALL - CLEAN THEN APPLY A THIN COATING OF WHEEL BEARING LUBRICANT TO THE BEARING AND SEAL CONTACT SURFACES APPLY WHEEL BEARING LUBRICANT TO THE LIPS OF THE REPLACEMENT INNER AND OUTER SEALS.INSTALL THE INNER SEAL WITH THE OPEN END OF THE SEAL FACING INWARD ENSURE IT IS COMPLETELY SEATED.INSTALL THE RETAINER PLATE AND THE OUTER SEAL ON THE SHAFT.ENSURE THE OPEN END OF THE SEAL FACES TOWARD THE AXLE SHAFT BEARING.PACK THE REPLACEMENT BEARING WITH WHEEL BEARING LUBRICANT AND POSITION ON THE AXLE SHAFT PRESS INTO PLACE.PRESS A REPLACEMENT BEARING RETAINER ON THE AXLE SHAFT AGAINST THE BEARING.INSTALL THE AXLE INTO THE AXLE TUBE.POSITION AND ALIGN THE SEAL RETAINER AND BRAKE SUPPORT PLATE AND INSTALL REPLACEMENT ATTACHING NUTS.TIGHTEN NUTS TO 32 FT LBS.INSTALL BRAKE ASSEMBLY WHEELS LOWER VECHICLE. YOU SAID REAR BEARINGS IF THIS WHAT YOU MEANT.I HOPE THIS CAN HELP.
Apr 12, 2010 | 1997 Jeep Grand Cherokee
How to remove rear axle?
Removal
  2. Remove the wheel and tire assembly.
  3. Remove the differential housing cover and drain the lubricant.
  4. Remove the rear brake drums.
Remove and discard the differential pinion shaft lock bolt.
  1. CAUTION: Do not damage the rubber O-rings in the axle shaft grooves.
Push the axle shafts.
  1. CAUTION: Do not damage the inner wheel bearing oil seal.
Installation
  1. CAUTION: Do not damage the rubber O-rings in the U-washer grooves
Apr 08, 2010 | 1999 Ford Econoline
How do you remove right rear axle on a 2004 ford crown vic to replace seal on wheel?
Section 05-02A: Axle, Integral Carrier — 8.8-Inch Ring Gear 1994 Town Car, Crown Victoria/Grand Marquis. Workshop Manual REMOVAL AND INSTALLATION Axle Shaft NOTE: Whenever replacing the rear axle lubricant, use Rear Axle Lubricant XY-90-QL (ESP-M2C154-A) or equivalent.
Removal
sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The rear brake anti-lock sensor must be removed before the axle shafts are removed. The rear brake anti-lock sensor is bolted on the rear disc brake caliper anchor plate.
  1. Raise vehicle to desired working height. Refer to Section 00-02 . Remove rear wheel (1007) and tire assembly. Remove rear disc brake calipers (2552) and rear disc brake rotors (2C026) .
  1. Clean all dirt from area of axle housing cover with a wire brush and/or cloth.
  1. Drain rear axle lubricant by removing the axle housing cover .
  1. Remove differential pinion shaft lock pin and differential pinion shaft .
  1. Push flanged end of the axle shafts toward the center of the vehicle and remove the rear axle shaft retaining u-washer from the button end of the axle shaft .
  1. Remove axle shaft from the rear axle housing , being careful not to damage the inner wheel bearing oil seal (1177) and rear brake anti-lock sensor ring.
Installation
NOTE: Check for presence of rear axle shaft o-ring (4A332) on the spline end of the shaft and install if not present.
sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Care must be taken not to let axle shaft splines damage oil seal or bearing assembly.
  1. Carefully slide axle shaft into rear axle housing without damaging rear wheel bearing (1225) or rear brake anti-lock sensor indicator (2C189) . Start splines into side gear and push firmly until the button end of axle shaft can be seen in the differential case .
  1. Install the rear axle shaft retaining u-washer on the button end of the axle shaft splines, then pull the shaft outboard until the shaft splines engage and the rear axle shaft retaining u-washer seats in the counterbore of the differential side gear .
  1. Position the differential pinion shaft through the differential case and differential pinion gears , aligning the hole in the differential pinion shaft with the lock bolt hole. Apply Rear Axle Lubricant to differential pinion shaft lock pin . Install differential pinion shaft lock pin and tighten to 20-41 Nm (15-30 lb-ft). sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Differential pinion shaft lock pin must be tightened to specification using Stud and Bearing Mount E0AZ-19554-BA (WSK-M2G349-A1) or equivalent.
    NOTE: Axle housing cover must be installed within 15 minutes of application of the silicone rubber or new silicone rubber must be applied.
    sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Make sure machined surfaces on both axle housing cover and rear axle housing are clean before installing the new silicone sealant. Inside of axle must be covered when cleaning the machined surface to prevent axle contamination. Tighten the cover bolts in a crosswise pattern to ensure uniform draw on axle housing cover .
  1. Apply Silicone Rubber D6AZ-19562-AA or BA (ESB-M4G92-A or ESE-M4G195-A) or equivalent. Install axle housing cover and tighten retaining bolts to 28-38 Nm (38-52 lb-ft).
  1. Add Motorcraft Rear Axle Lubricant XY-90-QL or KL (ESP-M2C154-A) or equivalent until it is 6-14mm (1/4-9/16 inch) below bottom of fill hole. Add 118.3 mL (4 oz) of Ford Additive Friction Modifier C8AZ-19B546-A (EST-M2C118-A) or equivalent to Traction-Lok axles. Install fill plug and tighten to 20-41 Nm (15-30 lb-ft).
  1. Install rear brake anti-lock sensor indicator . Tighten retaining bolt to 4.5-6.8 Nm (40-60 lb-in).
  1. Install rear disc brake caliper and rear disc brake rotor .
  1. Install wheels and tires.
  1. Insert Rear Bearing Remover T85L-1225-AH in bore and position it behind bearing so tangs on tool engage bearing outer race. Remove rear wheel bearing and inner wheel bearing oil seal as a unit, using Impact Slide Hammer T50T-100-A.
    Rear Disc Brake Caliper Anchor Plate
  1. Lubricate the rear wheel bearing with Rear Axle Lubricant.
  1. Install rear wheel bearing into the housing bore using Axle Tube Bearing Replacer T78P-1225-A.
    sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Installation of rear wheel bearing or inner wheel bearing oil seal assembly without proper tool may result in an early bearing or seal failure. If inner wheel bearing oil seal becomes cocked in bore during installation, remove it and install a new one.
  1. Install the inner wheel bearing oil seal using Axle Tube Seal Replacer T78P-1177-A. Use Premium Long-Life Grease XG-1-C or K (ESA-M1C75-B) or equivalent between the lips of the inner wheel bearing oil seal .
  1. Install axle shafts as outlined.
May 13, 2009 | 2004 Ford Crown Victoria
Rear Axle Seal Replacement
remove rear tires, then remove brake calipers and rotors, then remove the 4 nuts (each side) that hold the axle shafts to the axle tube (located around the axle tube behind the backing plate) then using a slide hammer pull the axle shafts out, next using a die grinder and an air hammer get he retainer collar and the bearing off (without damaging the axle shaft) then remove the seal and the outer race which will still be in the housing. next put it all back together, make sure the plate with the studs is still on then slide the seal, bearing, then retainer on (all new parts) and using a press push them all the way back on. then is simple reassembly.
Apr 21, 2009 | 2004 Jeep Grand Cherokee
Rear wheel bearing
SECTION 205-02B: Rear Drive Axle/Differential — Ford 8.8-Inch Ring Gear 2003 Mustang Workshop Manual IN-VEHICLE REPAIR Axle Shaft Removal
  1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
  1. Remove the wheel and tire assembly. For additional information, refer to Section 204-04 .
  1. Remove the rear brake disc (2C026). For additional information, refer to Section 206-04 .
  1. Remove the differential housing cover (4033) and drain the lubricant. For additional information, refer to Differential Housing Cover in this section.
  1. Remove the differential pinion shaft (4211).
    1. Remove the differential pinion shaft lock bolt (4241).
  1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-ring in the axle shaft groove.
    Remove the U-washer (4N237).
    1. Push the axle shafts (4234) inboard.
    1. Remove the U-washer.
  1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Damage to the rear brake anti-lock sensor (2C190) may occur if it is not removed before the axle shaft.
    Carefully remove the rear brake anti-lock sensor. For additional information, refer to Section 206-09A .
  1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the wheel bearing oil seal.
Rear Wheel Bearing and Axle Shaft Oil Seal Removal
  1. Remove the axle shaft (4234). For additional information, refer to Axle Shaft in this section.
  1. NOTE: If the wheel bearing oil seal is leaking, the axle housing vent may be plugged.
    Using the special tools, remove the rear wheel bearing and wheel bearing oil seal.
Installation
  1. Lubricate the new rear wheel bearing with the specified lubricant.
  1. Using the special tools, install the new rear wheel bearing.
  1. Lubricate the lip of the new wheel bearing oil seal.
  1. Using the special tools, install the new wheel bearing oil seal.
  1. Install the axle shaft. For additional information, refer to Axle Shaft in this section.
Installation
  1. Lubricate the lip of the wheel bearing oil seal
    Install the U-washer.
    1. Position the two U-washers on the button end of the axle shaft.
    1. Pull the axle shaft outward.
  1. NOTE: If a new pinion shaft lock bolt is unavailable, coat the threads with Threadlock and Sealer EOAZ-19554-AA or equivalent meeting Ford specification WSK-M2G351-A5 prior to installation.
    1. Align the hole in the differential pinion shaft with the case lock bolt hole.
    1. Install a new differential pinion shaft lock bolt.
  1. Install the differential housing cover and fill the rear axle with the specified lubrication. For additional information, refer to Differential Housing Cover in this section.
  1. Install the rear brake anti-lock sensor. For additional information, refer to Section 206-09A .
  1. Install the rear brakes. For additional information, refer to Section 206-04 .
  1. Install the tire and wheel assembly. For additional information, refer to Section 204-04 .
  1. Lower the vehicle.
Apr 10, 2009 | 2004 Ford GT
Replace left rear axle seal 1999 ford explorer
Axle Shaft Removal
  1. Remove the differential housing cover (4033).
    1. Loosen the bolts and drain the lubricant from the rear axle housing (4010).
    1. Remove the bolts.
    1. Remove the differential housing cover.
  1. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Turning the differential case (4204) or an axle shaft (4234) with the differential pinion shaft (4211) removed will cause the differential pinion gears (4215) to fall out of the assembly and damage the components.
  2. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-ring in the U-washer groove.
  3. Remove the U-washer (4N237).
  4. Push the axle shaft inboard.
  5. Remove the U-washer.
  2. Install the differential pinion shaft lock bolt finger-tight.
  3. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the wheel bearing oil seal (1177).
Seal Removal
  1. Remove the axle shaft (4334). For additional information, refer to Axle Shaft in this section.
  1. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Never remove the wheel bearing oil seal (1177) by itself. Always remove the rear wheel bearing (1225) and the inner wheel bearing oil seal at the same time.
    NOTE: If the wheel bearing oil seal is leaking, the axle housing vent may be plugged with foreign material.
    Using the special tools, remove the rear wheel bearing and wheel bearing oil seal together.
6c7eb46.gif Installation
    • For 4.0L SOHC and 4.0L EI with limited slip rear axles and 5.0L vehicles, use SAE 75W-140 High Performance Rear Axle Lubricant F1TZ-19580-B or equivalent meeting Ford specification WSL-M2C192-A.
    • For 4.0L SOHC and 4.0L EI with conventional rear axles, use SAE 80W-90 Premium Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
  1. Using the special tools, install the rear wheel bearing.
  1. Using the special tools, install the wheel bearing oil seal.
Feb 22, 2009 | 1999 Isuzu Rodeo
Getting rear gears out of the difential case 1999 dodge durango
  1. Raise and support vehicle. Ensure that the transmission is in neutral.
  2. Remove wheel and tire assembly.
  3. Remove brake drum. Refer toBrakes, for proper procedure.
  4. Clean all foreign material from housing cover area.
  5. Loosen housing cover bolts. Drain lubricant from the housing and axle shaft tubes. Remove housing cover.
  6. Rotate differential case so that pinion mate gear shaft lock screw is accessible. Remove lock screw and pinion mate gear shaft from differential case
  7. Push axle shaft inward and remove axle shaft C - clip lock from the axle shaft
  8. Remove axle shaft. Use care to prevent damage to axle shaft bearing and seal, which will remain in axle shaft tube.
  9. Inspect axle shaft seal for leakage or damage.
  10. Inspect roller bearing contact surface on axle shaft for signs of brinelling, galling and pitting. If any of these conditions exist, the axle shaft and/or bearing and seal must be replaced
Feb 07, 2009 | 1999 Dodge Durango
RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2 Logo
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
