Question about FUJIFILM X-M1 with 16-50mm lens, Brown
Silent mode not working - FUJIFILM X-M1 with 16-50mm lens, Brown
How do I get my uniden dect 6.0 off of silent mode?
This works for the Uniden D1660 and similar dect 6.0 models:
On the lower right corner of the keypad, press the # [silent] key.
One press put it into 'silent mode', another press takes it out.
Oct 10, 2016 | Uniden DECT 6.0 Cordless Phone ID
How do I get out of silent mode on uniden dect 6.0
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1760om.pdf
1. With the phone in standby, press and hold # on any handset. The phone prompts you to select the number of hours (1 - 9 or Always On) that you want it to stay in silent mode.
2. To confirm, press # or just wait about 5 seconds. The phone turns on the answering system and displays Silent Mode On on each handset.
3. After the selected number of hours, the phone automatically exits silent mode. To exit silent mode manually, press and hold # again.
Feb 18, 2015 | Uniden Cordless Phone
Silent mode on fugifilm x-M1 digital camera not working
For silent mode the manual says o page 84: In the Setup Menu Options: Select ON to disable the speaker, flash, and illuminator in situations in which camera sounds or lights may be unwelcome (note that silent mode can not be enabled or disabled during movie playback). Silent mode can also be turned on or off using the DISP/BACK button as described on page 4.
Perhaps you try this one?
Dec 29, 2013 | Fuji Cameras
How do i take my d1660 phone off silent mode
With the phone in Standby hold the # for about 5 seconds on any handset it should then Display 'Silent Mode off'
Hope that Helps
Jaysan
Jun 16, 2012 | Uniden D1660 Cordless Phone
Phone is stuck in silent mode
Press and hold the pound key (#) until it exits silent mode.
Here is the original text from the manual of the phone:
"Quickly Switching to Silent Mode
Silent mode is convenient when you wish to stop the
phone from making noise, in a theater for example.
In Idle mode, press and hold the "#" key until the “Silent
Mode” message and the Vibration icon display...
To exit and reactivate the previous sound settings, press
and hold the # key again until “Exit Silent Mode” appears.
The Vibration icon no longer displays."
You can also download the pdf file for the phone's manual online by simply googling "Samsung x427m pdf manual."
Hope this helps!
Mar 13, 2010 | Samsung X427M Cellular Phone
How do i turn my phone to silent mode?
To place the handset in Silent / Vibrate Mode
Step 1
To place the handset in Silent / Vibrate Only Mode, hold down the pound key (#) for about 2 seconds. To exit Silent / Vibrate Mode, perform the same action while in Silent / Vibrate Only Mode. You will see a confirmation message for Silent / Vibrate Only Mode, each time you enter or exit Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent Vibrate Only Mode.
Step 2
While in standby mode, press the volume key, located on the left side of the handset, then select either “Vibrate Only", “Alarm Only” or “All Sounds Off”. To disable perform the same action while in Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent / Vibrate Only Mode.
Jun 08, 2009 | Samsung SCH-U470 Juke Cellular Phone
Somehow i have turned the silent mode off on my phone, and i have tried everthing to activate the silent mode back on and it doesn't work. can anybody please help me.
or by holding down the # key :) you may have changed the profile itself, so check under profiles > Silent check the settings in there are actually set to silent...
May 08, 2009 | Nokia 6500 Slide Cellular Phone
SILENT MODE
hi! goto profile change your mode option!
Jul 10, 2008 | Samsung SGH-t629 Cellular Phone
Silent mode been activated and cant turn it off
To Enter/Exit Silent Mode
Silence the tones your keypad makes when you press a key.
• In standby mode, press and hold # key. Entering Silent Mode briefly appears in the display and your phone returns to standby mode.
peace!
Dec 08, 2007 | Samsung SCH-a870 Cellular Phone
Samsung d900
To place the handset in silent / vibrate mode follow the steps below: To place the handset in Silent Mode, hold down the pound key (#) for about 2 seconds. To exit Silent Mode, perform the same action while in Silent Mode. You will see a confirmation message for Silent Mode, each time you enter or exit Silent Mode. The phone will vibrate rather than ring when you receive a phone call, message or alert while in silent / vibrate mode.
Aug 23, 2007 | Samsung SGH-D900 Cellular Phone
FUJIFILM X-M1 with 16-50mm lens, Brown Logo
590 people viewed this question
Top FUJIFILM Work Safety Experts
Bobby Lewis
Bobby Lewis
Domenico Grillo
matt
matt
Are you a FUJIFILM Work Safety Expert? Answer questions, earn points and help others
