Question about Samsung Bp96-00674a Dlp Tv Color Wheel Bp9600674a
Samsung dlp the picture is all shadows with dark green/black colors after replacing with new color wheel..what is wrong? Is it a bad color wheel?
I had a beautiful picture with old wheel, but the old wheel was noisy..now noise is gone, but I have bad color,,so bad that I can't watch this tv
  • 38 Answers
No you need to adjust the color wheel to factory specs by getting into the service software. The color wheel has to be timed to the engine.
Posted on Jan 01, 2014
  • 208 Answers
SOURCE: samsung hlp4663wx/xaa (after replacing the color wheel)shadowing
If the color wheel you replaced was the BP96-00674A, it would have come with the proper cca adjustments for that particular wheel. You must enter the service menu and reset the cca's for proper color.
Posted on Feb 21, 2008
Slinteriors
  • 8617 Answers
SOURCE: Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Posted on Mar 26, 2008
  • 208 Answers
SOURCE: Color is bad after installing color wheel in samsung dlp tv
Most times color does not to be reset. If you have a very ugly green or blue picture, then you did not pull the jumper on the dm board. This jumper must be removed when a bering type color wheel has be replaced with a new airless bering color wheel.
Posted on Apr 07, 2008
SOURCE: Fading picture that looks dark and dull on a 42" Samsung DLP tv.
You need a new lamp...
Posted on Feb 27, 2009
  • 336 Answers
SOURCE: TV SAmsung, the picture is bad after color wheel changed
Hi,it's possible they gave you a different color wheel,there's a silver version and a gold version they spin at different speed,so mostlikely they gace you the wrong version check what this website says about the 2 versions : http://www.discount-merchant.com/product-p/samsung_bp96-00674a_colorwheel.htm God bless you ask for a refund.
Posted on Oct 06, 2009
I have a Samsung DLP HLR5067 modeel tv, recently we have replaced the lamp, ballast and color wheel. The color is ok but when we watch dark (color)movies the black and browns look shadowed and irdescent. ...
You probhably have the wrong color wheel. There are several different ones and its imparitive that you replace it with the correct one. If you search here theres someone else that had the same issue and when they put thier old noisy color wheel back in the problem went away.
Nov 15, 2010 | Televison & Video
We have 50" Samsung DLP
Yes,the tv have a colors wheel and it is the cause of these problems.Humming noises,motor noises,picture flashes black&white or colors pictures within the pictures.The colors wheel,is dying or already dead.Hire a tv tech. replaced the colors wheel,will solved ur tv problems.
Nov 06, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung DLP TV shows green color where color should be black
This could be your video board going bad where your input cables are connected --OR-- the color wheel going bad. Hard to tell without a photo or reference though. Try swapping the cables first... and listen for any winding or whirring sounds.
Feb 04, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP HLP-4663WX/XAA. Colors green after wheel replacement.
I have Samsung DLP HLP-5063WX/XAA. I have the same problem. I did change another color wheel, but not any help. Please help! I appreciate
Sep 10, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Dark shadow about 4'' at top of screen of 56'' dlp samsung hlr5667
There is a piece connected to the color wheel assembly called a light tunnel. It is between the color wheel and optic assembly. There is 4 mirrors inside. One of them probably got dislodged when the wheel shattered. Sometimes they can be repaired using high temp glue or you may have to replace the tunnel.
May 18, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Dark greys appear a dull green.
could be a jumper that needs to be removed on the DMD board, or a setting in the factory mode, mute-182-power will get you in there
Jul 11, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Color wheel replacement
With the back off of the unit, you are looking at a silver can on the light engine. The is the board where the DLP IC is located. There is a large heat sink right in the middle. Near that heat sink you will find a small square cut out where two pins protrude from the inner bd. There is a small black piece across those two pins, that is the jumper. With a needle nose slide that black jumper off of the two pins. Normally if the color wheel is changed and the jumper not remove the picture is very poor with ugly green and purple negative look.
Jun 15, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Mar 31, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung hlp4663wx/xaa (after replacing the color wheel)shadowing
Feb 20, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung Bp96-00674a Dlp Tv Color Wheel Bp9600674a Logo
147 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
