Question about Tools & Hardware - Others
Atro nailer parts
It is blowing air, I need the gasket repair kit
    Sergeant:
  • 206 Answers
Unfortunately, there have been no parts available for Atro for over 12 years. You can match up generic O-rings, but the most common issue is the piston stop in the head disintegrating - this part is no longer available and you won't find a generic replacement to my knowledge.
Posted on Jun 16, 2014
3 Suggested Answers
H2_Brad
  • 425 Answers
SOURCE: Parts and manual for CHS933 Atro nailer
Atro is out of business. I do have some parts left in stock and parts diagrams for them. You can contact us if you want. Just use Google to find Twin City Supply in Loves Park, IL.
Posted on Mar 07, 2012
  • 142 Answers
SOURCE: Where can I find the parts I need
need to check with Harbor Freight about parts
they are the distributors for that brand gun
Posted on Nov 22, 2009
Atro roofing gun leaking air out the top vent continually how do i know which o ring to replace to stop the leak
a good tip with O rings is just too replace them all
you can get a kit of them on ebay for about £5 or so....all different sizes
Dec 04, 2014 | Air Tools & Compressors
I need a breakdown for my ISM RC 234b coil nailer
I dealt is ISM, Atro, and CCC (all the same company) years ago but after looking through my old books of parts breakdowns I can not find anything on that model number. Try contacting Allied. They can still furnish some ISM/Atro parts and I deal with them often.
Allied Packaging
Aug 06, 2012 | Air Tools & Compressors
Where can i get the gasket for the cylinder of a framing nailer model ns2890
The seals and o-rings for this nail gun, made in the late 1990s, were only available in rebuild kits. I am a C-H service center and none of kits for this gun are available any more and I could not find them on any of my aftermarket parts sites either. If you would like to look into it further you need either the cylinder o-ring kit, part number SV289026AV, or the complete o-ring replacement kit, part number SV506900AV.
May 18, 2012 | Campbell Hausfeld Air Tools & Compressors
Jan 27, 2012 | Tools & Hardware - Others
I have an air leak, where can I purchase a gasket set for my framing nailer
Best place for parts is www.toolpartsdirect.com. They do not sell a gasket kit. The parts are listed individually. oring kits are available on ebay for about 20.dollars. Use key search "hitachi oring kit". If you have question about your leak and specific cause of leak post again with exact area of leak. Good luck with your repair
May 30, 2011 | Hitachi 3 - 1/4" Framing Strip Nailer
GOT BAD AIR LEAK WEN I PLUG IT IN.
Under the cap there are several o-rings, seals, gaskets and seats that have to be in good shape to hold air in so the nailer can work properly. If any of them are worn, broke or dried up the nailer won't function and can leak. First try tightening the cap screws. If that doesn't do it, take the cover off and check the parts inside. Stanley doesn't make repair kits for this nailer so you'll have to identify what parts need replacing and order them seperately. I recommend replacing all o-rings and any damaged seals or seats that need it. You can go to www.bostitch.com or www.ereplacementparts.com to find parts among many other aftermarket parts dealers.
Jan 20, 2011 | Stanley Bostitch PN100 Palm Nailer
Nail gun doesn't shoot and air blowing out vent constant.
We used nail guns for years. I still own 6 guns, but they aren't used much anymore.
You have a 'blown head gasket.'
Or there is debris from the air hose that got lodged into the gun.
There is a head gasket and a trigger gasket.
Both can blow out any time from use, lack of oil, or they can stick open from debris.
You can take apart the head and clean it up and add oil to see if that solves problem.
You can order a gun re-build kit for your model and put in the parts yourself.
You can have a nail gun repair shop do the job.
Nail guns require gun oil.
If you don't use gun for a while, oil should be put into air hose opening and then left to run down into gun. More oil is better.
If you use 3-in-1 oil or some oil besides gun oil, then it will corrode the gaskets.
When storing air hose and guns, put tape over openings so they stay clean.
Before hooking air hose to a gun, you can also put a blower on hose and blow out the line first
Oct 21, 2010 | Dewalt Round Head Framing Nailer D51845
I have an old Atro roofing nailer, when I hook the air to it, it blows air out the top non stop. This company doesn't exist anymore. Any idea how to fix?
if you just serviced it, and it is all back together,take a rubber hammer and give it a hit on the cap,this will give it a seal, and you should be good to go.
Apr 20, 2010 | Air Tools & Compressors
Porter cable bn200 nailer
Get a gasket kit---sounds like top seal around barrel
Feb 21, 2010 | Porter Cable-Cable BN200B 5/8-inch to...
Dewalt compressor not filling with air drained tank closed valve
Some dewalt air compressors with single cylinder are known to develop trouble with reed valves and /or failed gaskets in head. Parts lists and parts are available at WWW.toolpartsdirect.com Simple test is to remove air filter and check for suction at intake. Bad reeds will tend to blow air out intake as pressure increases. Failed gaskets in head will cause very high temp at discharge hose. Parts are not too expensive. Enjoy
Dec 05, 2008 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Tools & Hardware - Others Logo
171 people viewed this question
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
