Question about McCulloch Garden
Trigger/switch on EM300s Electramac chainsaw broken and needs replacement
This saw has been solid as a rock for years but "father-time" has taken its toll on the plastic housing of the trigger/switch. I disintegrated and needs to be replaced. Websites say the part (#40925-66) has been discontinued/not available. Does anyone know of a replacement trigger/switch that will work in this saw?
  • Dennis Garcia Jan 06, 2014
    Make one out of wood??, , Seriously?? Seriously?? What a JOKE you are. I'm trying to find a compatible part with the part number. Quit trying to solve problems thru the bottom of the walker blue bottle.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Posted on Dec 29, 2013
Testimonial: "serously??, , seriously?? you're a joke"
3 Suggested Answers
darjr
  • 378 Answers
SOURCE: McCulloch 14" electric-will NOT run
check the carbon brushes in it. open the cover of motor you can see two pc. of carbon touching the armature. If that become short it need replacement
Posted on Jun 29, 2009
  • 4088 Answers
SOURCE: installing throttle cable on Husqvarna 445 chainsaw
Try blocking the throttle arm on the carburetor in the wide-open position with a small stick, then deal with the trigger mechanism. In order to remove the cable from the carburetor, you need to remove the carburetor itself, then unhook the cable end at the throttle arm. Keep track of which fuel hose goes where if you do this. Hope this helps!
Posted on Apr 01, 2010
How to replace broken trigger on a huskie 162 sg chain saw
Most Husky saws have a small pin to drive out to remove trigger. Often safety lever on top needs to be removed also. Sometimes tank/handle assembly needs to be removed to replace trigger.
Dec 27, 2016 | Garden
Why does my electramac leaks oil
The chain oil feed is a gravity feed and will continue to feed when you put the saw down. Empty the chain oil resoivour when the machine is being stored. or store it in a driptray.
Jul 19, 2014 | McCulloch Electric Chainsaw Final Gear...
Switch/trigger (#40925-66) on McCulloch EM300S 3.0HP replacement?
I recommend contacting your local authorized service center for assistance. They may be able to retro-fit something.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Dec 29, 2013 | McCulloch chain saw part /...
How do you replace the trigger switch? I have a new one and have taken the saw apart but am having problems with how to attach the new switch wires.
I have not disassembled my Remington Pole saw but mine has a two-wire circuit (no ground) so it should not make any difference which wire is connected to which post. Preferably, though, you should match wire colors. There should be some kind of connector block linking the trigger switch to the incoming power wire and the wire that runs to the saw motor. Attaching the new wires should simply be a process of reversing the procedure you used to remove the original trigger switch. If you cut the wires to remove the old switch, hopefully, you left enough wire end to strip them and solder the end of the new switch to the old wire.
Oct 25, 2013 | Remington Electric Pole Saw
McCulloch Electramac 3.0 hp EM300s-16
Please restate your answer in the form of a question.
Contact us
User manuals
McCulloch Service
May 20, 2012 | McCulloch Garden
I need the owners manual for Electramac EM16 ES electric chainsaw
Without test: http://es.gigabytedownloads.com/signup/mcculloch_electramac_em_16_es.rar
Need register.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 11, 2011 | Garden
Electric chain saw - when plugged in it starts to run WITHOUT pressing trigger. SCARY! must be unplugged to stop. Have had chain saw for 10 years and this problems just started.
obviously you need a new trigger switch, after 10 years you cant complain ,try giving it a squirt of crc . it may be just a little sticky ,but at its age put anew switch in if you can get one
Aug 23, 2009 | Garden
Electramac EM300s will not oil
We aren't able to determine the cause of this malfunction with the information we can find. We think you would be better served by contacting a local authorized repair facility.
Closed
Aug 15, 2009 | McCulloch Garden
Jun 29, 2009 | Garden
Garden Logo
259 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
