Question about Lenovo IdeaTab A2109
My power button is not working what should i do
My android NuVision tablet is frozen. How to get it to work
power it off if you a reset button next to the usb use that to reset and the power button to reset
if that doesn't work try this
To reset the device, press the power button and the volume down button and hold both of them for 10 seconds. Once the tablet turns on it enters the Reboot screen. Scroll down to "Wipe Data/Reset".
you will your data with this reset
Jul 18, 2015 | Tablets & eReaders
The touch screen in my Ipad stopped working. It works to unlock or to shut a screen but that's all.
Try restarting it: hold power button down until "slide to power off", power off for 10 seconds, press power to restart.
if that doesn't fix it, reset your iPad: hold BOTH power button and Home button until device resets and apple logo appears.
Feb 14, 2015 | Apple iPad Mini
How do I factory reset the trio stealth g4 10.1 tablet
  1. Make sure the tablet is powered off and charged.
  2. Hold down the volume [+] button and the power button at the same time.
  3. When the screen comes on, let go of the power button only.
  4. When the large Android appears on the screen, let go of the [+] button.
Tony
Jan 12, 2015 | Tablets & eReaders
Holding the power and volume button to rest and its not working on the xtreme tablet generation 2. what do I do now
To do a soft reset so you do not lose any data just press power for 15seconds........then it will restart!
Jan 01, 2015 | Tablets & eReaders
Power button doesnt work
Try charging the device. If the battery gets discharged low enough, it may take a few minuter for it to power up once it is on charge.
May 31, 2014 | Irulu 7" 4gb Mid Google Android 2.3...
Computer not turning on
please be more descriptive. The make of the tablet, what exactly lead to the issue,
you may try by leaving the tablet charge overnight but ensure that the charger is working before doing that. If the tablet haves center button you can try to press and hold the power button and keep tapping the center button for about 15 times. It might turn on if no center button try holding power and keep tapping power down. When you are up to it, you may even try the combination with power up button as I don't know the model.
let know if it worked
Mar 25, 2014 | Tablets & eReaders
Maxwest tab-9155 won't load past android screen
Hi, you can try resetting by following the below steps. It works for most tablets.
1 turn off the tablet
2 press and hold the power button and keep tapping the volume down button at the same time.
3 it should take you to recovery screen. Go to factory reset by using volume button and select by using either the center button on the tablet or the power button if there is no center button.
please reply if it helped
Mar 24, 2014 | Tablets & eReaders
Kocaso M1066 won't get past the first blank white startup screen. Suggestions?
Memory could server me wrong, but on some tablets you have to hold down the reset button and the power button at the same time in order to get a complete reset. I think this one might fall into that category. The following sequence works with other models of the same manufacturer, so give these a go if the first suggestion fails.
The button to hold down is the menu button next to the home button. With it powered on hold down tthe menu and power buttons until it goes off, then release the power button and then hold it again while holding the menu button. An android with an exclamation and triangle will appear. Tap the power button and the menu for reset or updates appears. Select factory restore and follow instructions then select reboot at next screen.
Hope they help,
Gill
Jan 28, 2014 | Tablets & eReaders
Kindle fire screen repair
Press and hold the power button for fifteen seconds or so. Does it turn off then? If so, press and hold the power button for a second or two. Does it start to reboot then? Does it work properly now?
May 26, 2013 | Amazon Kindle Fire HD
Lenovo IdeaTab A2109 Logo
Top Lenovo Tablets & eReaders Experts
vojvodabudva
Computer Links
Are you a Lenovo Tablet and eReader Expert? Answer questions, earn points and help others
