Question about Frigidaire GLRS234ZA Side by Side Refrigerator
Hot housing housing between freezer and fridge is hot
  • Frigidaire Master
  • 842 Answers
I am going to assume you refer the housing as the cabinet. If this is hot to the touch the condenser is clogged and cause this heat. Remove the toe grill under the doors, and clean/vaccum out all the dust from under the unit. Once cleaned the cabinet temp should drop, if not the condenser fan could not be running causing this heat. Clean it first before replacing anything to save money.
Good Luck
Posted on Dec 30, 2013
Front edge of fridge cabinet gets exceedingly hot...too hot to touch!
condensor coil is clogged up, or condensor fan is not running.
Dec 04, 2012 | Refrigerators
The strip down the middle between the the fidge and freezer doors is getting hot. So hot that it burns when you touch it. The sides of the fridge are also getting pretty not. I have just bought the fridge...
I have exactly the same problem with my Westinghouse side by side! And it only happens when it's hot in the house. Would love to hear what's wrong. And the fridge is 5 years old. Bought new.
Jan 12, 2011 | Westinghouse Refrigerators
My freezer is working fine, but my compressor is hot to the touch. Is the compressor too hot? I have converted my freezer to a kegerator with a temp. regulator. I do not want to burn my house down or...
the compressor will run hot,but you should be able to touch it without burning yourself.(when you compress a gas, heat is generated as it turns to liquid and when it expands back to a gas it absorbs heat,the principal of a fridge...)
Oct 23, 2010 | GE Freezers
Fridge not cooling, freezer not cold enough, ice maker not workin
is there alot of frost in the rear panel of the freezer if not the compressor is not start or getting hot because fan that cools it has failed is the part between the side/side door extremely hot if so check the cooling fan for the compressor
Aug 19, 2009 | Maytag MZD2766GES Side by Side...
Stripe between fridge and freezer is extremely hot to touch
It is 100% the condensor fan motor on the back. Its not two hard to replace. Take the screws off the back panel and remove. Then locate fan. Disconnect the wires going to the motor and then unscrew the scews that mount the motor. Take the part to parts store of look it up online. Then simply remount motor and plug wires in.
Golden.
Jul 29, 2009 | Whirlpool ED2FHEXN Side by Side...
Zanussi ZFC 45/30 SS is hot at front between the doors..
This is normal. This is a defroster to keep moisture from condensation from freezing the doors shut.
Jun 30, 2009 | Refrigerators
The partition between fridge and freezer is boiling hot
some of the hot pipework is routed across the transom between fridge and freezer to prevent condensation.. this will be hotter when you start up a warm appliance.
temp can not go so high as to cause a smell of burning so look elsewhere for that - maybe the compressor electrics
Oct 12, 2008 | Frigidaire FRT15B3A Top Freezer...
Compressor constantly on too hot to touch
hi have you cleaned the matrix best done by blowing with air but a soft brush can work,make sure that all the cooling vanes are clear
hope this helps ian
Jul 21, 2008 | LG LRTN22324 Top Freezer Refrigerator
Fridge - with freezer on top
Check the bottom refrigerator door gasket for any possible spilled food or drink that may have leaked onto it. Clean this area with warm soapy water. It may solve your problem. Also check under the drawers and make sure there is nothing there. If there is a drain under the drawers clean it and put some hot water with bleach into it to flush it out.
May 22, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore fridge exterior is really hot
It is quite normal for fridge freezers to have what is called a door heater circuit around the freezer compartment to prevent any unwanted ice build ups ( a practice used in commercial systems). I would expect a certain amount of heat in the section described as it normally is the first part of the condenser (hot bit) circuit. As for burning the house down I have only heard of two cabinets (both in labs) that have done this and they were due to what was put in the fridges. If you are concerned though I would suggest you get a tech to check it. Hope this helps.
Aug 12, 2007 | Kenmore 57029 Side by Side Refrigerator
Frigidaire GLRS234ZA Side by Side Refrigerator Logo
54 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
