Question about McCulloch chain saw part / 4092566/40925-66
Trigger/switch on EM300-s broken
Good chain saw but "father-time" has taken its toll on plastic housing of trigger. website says no available/discontinued. Anyone know of a replacement trigger that will work?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Make one out of wood
Posted on Dec 29, 2013
  • Dennis Garcia Jan 08, 2014
    Your ignorant "solution" is a joke, I am looking for a replacement that is compatible with the OEM part. Guess where you can stick the "one out of wood"?
  • Dennis Garcia Jan 09, 2014
    PROBLEM SOLVED!!!! MC-6022-210102P is the "In stock" replacement switch/trigger that fits my McCulloch EM300S. It was under $20 (including S+H) at seears-rowbuck (intented misspelling).
3 Suggested Answers
VtToolMan
  • 704 Answers
SOURCE: I have a MAC 3516 and need a replacement bar and
Hello Eric, You can get an Oregon brand bar and chain that will work perfectly on your Mac 3516. I have this same chainsaw and keep a spare bar and chain, so I can quickly swap them out, should they get damaged, etc.
The Oregon bar and chain part numbers are as follows:
#100457 (Bar & chain combo pack)
You can also find these sold at most Home Depot, Lowe's and other hardware stores that carry chainsaws, as Oregon makes their replacement bar and chains to fit all the major brands available.
Unless your existing bar and chain are completely galled up, scored or bent/busted beyond repair, I would find a small engine repair shop or local hardware store that sharpens chainsaw cutting chains, (True Value and Ace do it in our area) and see if they can sharpen and true up the bar. The price for this is typically about 1/3 to 1/2 the price of a new chain and bar set, and worth having a spare around.
I also like having that extra aleady to use (sharp) chain, so when a neighbor borrows my saw and invariably lets the chainsaw go into the dirt (that'll dull the chain so fast!). I will always be able to use my saw, when I need to, without having to run out and get a replacement, or spend 15 minutes having to sharpen it by hand, etc.
I hope you find this Very Helpful and best regards!
Posted on Nov 24, 2009
Testimonial: "I cannot believe the fast and accurate responce to my question, thanks for your help it is greatly appriciated"
  • 4088 Answers
SOURCE: Throttle linkage
It seems that Mac engineers could have come up with something better than the M.M. kluge that they did. The problem is hooking the wire link to the plastic hook on the trigger plastic casting while juggling the front case and engine body. It appears that it should just snap together, but knowing how plastics get with age, it would appear that the trigger should be replaced every time the case comes off. I had trouble with mine and wound up straightening out the wire link end somewhat to force the parts together--it continues to work though. Hope this helps!
Posted on May 06, 2010
Brand new Huskie 450e used for two days and the throttle is now broken. The actual trigger itself feels like it isn't attached to anything anymore. Is it an easy fix?
In the 400 series of Huskies I have fixed, the handle comes apart with several screws. Sounds like the simple problem might be in the handle/trigger assembly. The more complex problem is if the throttle linkage rod popped out of the throttle. The outside trigger interacts with a black plastic insert and spring that provides pressure outward to keep the throttle low. This assembly connects to a thin metal rod that looks like the path a drunk would take doing a sobriety test after too many martinis. The rod goes into the housing and connects into a hole in the throttle assembly, then is locked in place with a plastic piece that slides down to keep the rod from falling out. In order to see this area, the cover needs to come off. I'll be honest. The last one I had, the rod fell out of both ends. It took me two days of pondering, playing around, cursing, getting up and walking away, then coming back to finally figure out where the ends went. The blue plastic piece had slid down, covering the hole, so I was at a loss as to where it attached to the throttle. NOTE: When removing the handle, try real hard to keep it together until all screws are removed. THEN VERY CAREFULLY begin to take it apart, looking in from the top of the handle. You might get one good glimpse of how the parts fit together before they fall apart on you. Husky does have a good website for exploded view diagrams, but sometimes they leave a little to be desired for 2-Dimensional art vs. 3-D Reality. Good luck.
Sep 13, 2011 | Husqvarna 450 e-series 18" Chain Saw
Trigger assembly is smoking, intermittent starting ? Remington electric chain saw
The switch has either a poor connection to it, or the switch is toast. Good luck on finding a replacement part.
Nov 12, 2010 | Remington Electric Chain Saw
Throttle linkage
May 05, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have a 14 inch WEN/Wagner electric chain saw in good condition with the exception of the trigger switch. I have not been able to find a replacement for that small part. Can you help?
Jim it is so long out of production about the only thing available is the OM. If you can get a pn off the original switch Allied or Newark is an option. Maybe a trigger switch from a saw in current production can be modified to fit.
Different model Poulan electric saws follow:
1. http://www.ordertree.com/modelinfo/PWE/1220-Electric-Saw/75.1220-Electric-Saw.1.59.1.html
2. http://www.ordertree.com/modelinfo/PWE/1420-Electric-Saw-Type-2/75.1420-Electric-Saw-Type-2.1.59.1.html
3. http://www.ordertree.com/modelinfo/PWE/1625-Electric-Saw-Type-2/75.1625-Electric-Saw-Type-2.1.59.1.html
“EL-14“ through “ES400” here (5±):
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
A length of spring steel and almost any micro switch might also be an option. Beyond that I am out of ideas.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 22, 2010 | Remington Electric Chain Saw
Plastic housing broken due to over tightining
I call it a clutch cover, Poulan calls it a "Chain Brake Assembly", pn 545139903 for Type 1 or 2 - 2375 WildThing.
http://www.ordertree.com/modelinfo/PWE/2375LE-Gas-Saw-Type-2/75.2375LE-Gas-Saw-Type-2.1.59.1.html
Poulan.com
Lou
Apr 17, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How do you remove the safety button on a sears electric chain saw switch, so that I can replace the switch?
On most electric saws,you have a lock out button that you need to push in prior to depressing trigger.If this is the case on your model, the lock out button can be removed by pulling directly out of saw housing.It takes a little force but it does snap out
Nov 12, 2009 | Garden
It starts up, but when trigger is pulled, the
Most saws have a safety or anti kickback brake. Yours might have tripped. There is a guard in front of where your left hand holds the saw. With the saw NOT running, pull the guard HARD towards the back of the saw. It should move a bit ant you may hear a click. The chain should now move. If the chain moves easily when the saw is not running, but doesn't move when you rev the saw up, the clutch is broken.
Sep 10, 2009 | Garden
Crafstman chainsaw at full power when started
If you had this apart, a few things may have happened. First the linkage from carb to throttle trigger maybe jammed between plastic housing or linkage may have come apart and throttle is in the full open position. You'll have to take this apart again and follow the linkage between carb and throttle trigger to ensure all is connected and moving freely and properly. Use care when putting housing back together.
May 10, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
McCulloch chain saw part / 4092566/40925-66 Logo
105 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
