Question about Microsoft Windows XP Home Edition for PC
Can't burn CD on Windows XP - Microsoft Windows XP Home Edition for PC
  • 1 more comment
  • borntobyrne May 19, 2009
    Yes, we do have a CD burner installed.
    We are using CD-Rs to burn onto (has worked previously)
    Yes, using Windows XP
    Built-in burner
    Burning music and images. (music worked previously)
    No error message, just continuously told to insert a blank disk, even when a blank disc has been inserted.
  • Kevin Kraft
    Kevin Kraft May 11, 2010
    Do you have a CD-Burner installed? Are you using a CD-R or CD-RW disk? Are you using Windows XP's built-in burning function or a third-party application? Are you trying to burn files, music, movies, or an image?
  • ikkenom May 11, 2010
    What error-message do you get?
    What CD-writer (or DVD-writer) manfacturer & model?
    What type of writable disks are you using?
    What software (AShampoo, Nero, et cetera) are you using to create/burn the disks?
  • 51 Answers
Yes u can burn cd on windows xp but u should have Cd burner by which u can burn cds by right clicking the data and send to .. select your cd-rw and send it after on left side click on write this on cd someting like this will show u in cd-rw window
Posted on May 19, 2009
Tip
Burn quicker in windows xp
 windows xp has burning software built in which can cause problems sometimes when burning with other programs.
you can turn windows xp burning tool off like this.
Go to "administrative tools" in the control panel.
In the "services" list, disable the IMAPI CD-Burning COM service.
on Dec 10, 2009 | Computers & Internet
I have a dell laptop windows xp, 2nd hand. I cannot get past the passwork...microsoft sent a installation disc but I'm still unable to move forward. I need to bring the computer back to factory s
Well, reset windows password is very easy.
If you do not mind lost data, you can re-install windows.
If you do not want to lose data, you can follow the instructions below to recover it.
Step 1: Download and install Windows Password Reset from http://www.windowspasswordreset.net
Step 2: Burn Windows Password Reset Std ISO file to CD/DVD
Step 3: Put in your newly created CD and remove your Windows Password.
The method above is adopt a tool, very easy, right?
Jul 19, 2012 | Dell Computers & Internet
Would like to know if Roxio Easy CD & DVD Burning is compatible with Windows xp
Platform: Windows Vista / 2000 / XP Professional / XP
Please rate my solution :D
Jun 12, 2011 | Roxio Easy CD & DVD Burning
How to create a bootable Windows XP SP1 CD
Using nero .
Step 1
Create 3 folders - C:\WINXPSP1, C:\SP1106 and C:\XPBOOT
Step 2
Copy the entire Windows XP CD into folder C:\WINXPSP1
Step 3
You will have to download the SP1 Update, which is 133MB.
Rename the Service Pack file to XP-SP1.EXE
Extract the Service Pack from the Run Dialog using the command:
C:\XP-SP1.EXE -U -X:C:\SP1106
Step 4
Open Start/Run... and type the command:
C:\SP1106\update\update.exe -s:C:\WINXPSP1
Click OK
Folder C:\WINXPSP1 contains: Windows XP SP1
How to Create a Windows XP SP1 CD Bootable
Step 1
Download xpboot.zip
Code:
Code:
http://thro.port5.com/xpboot.zip
( no download manager !! )
Extract xpboot.zip file (xpboot.bin) in to the folder C:\XPBOOT
Step 2
Start Nero - Burning Rom.
Select File > New... from the menu.
1.) Select CD-ROM (Boot)
2.) Select Image file from Source of boot image data
3.) Set Kind of emulation: to No Emulation
4.) Set Load segment of sectors (hex!): to 07C0
5.) Set Number of loaded sectors: to 4
6.) Press the Browse... button
Step 3
Select All Files (*.*) from File of type:
Locate boot.bin in the folder C:\XPBOOT
Step 4
Click ISO tab
Set File-/Directory length to ISO Level 1 (Max. of 11 = 8 + 3 chars)
Set Format to Mode 1
Set Character Set to ISO 9660
Check all Relax ISO Restrictions
Step 5
Click Label Tab
Select ISO9660 from the drop down box.
Enter the Volume Label as WB2PFRE_EN
Enter the System Identifier as WB2PFRE_EN
Enter the Volume Set as WB2PFRE_EN
Enter the Publisher as MICROSOFT CORPORATION
Enter the Data Preparer as MICROSOFT CORPORATION
Enter the Application as WB2PFRE_EN
* For Windows XP Professional OEM substitute WB2PFRE_EN with WXPOEM_EN
* For Windows XP Home OEM substitute WB2PFRE_EN with WXHOEM_EN
Step 6
Click Burn tab
Check Write
Check Finalize CD (No further writing possible!)
Set Write Method to Disk-At-Once
Press New button
Step 7
Locate the folder C:\WINXPSP1
Select everything in the folder and drag it to the ISO compilation panel.
Click the Write CD Dialog button.
Oct 11, 2010 | Microsoft Computers & Internet
Computer doesn't let me use CD or DVD Burner. No firewall or default problem. windows XP home
i think the administrator has blocked or disable the cd rom. for burning you must have a previlage to burn. that is known as burn right.
Feb 18, 2010 | Computers & Internet
I need to burn a DVD, a CD, How do I have a copy of Nero smart?
Windows XP supports CD burning.
All you have to do is drag the files to the CD and it will ask you if you want to burn them. Tell it yes.
You don't need special software. If you want CD burning software, you will have to buy it--probably Amazon.com is the best bet.
Nov 22, 2009 | Microsoft Windows Xp Home Edition Sp2...
I get unknown error code 4260 when trying to burn cd
This is a disk error issue make sure if on windows you have the drivers for your CD drive(start>right click computer>click device manager) and also try an different make of blank disk.
TDK maxel and sony disks are notoriously bad on burning..
verbatin and imation disks burn without this error, stick to CD-R or CD+R disks the re-writables are notrious for not writing properly
this may solve your problem hope it helps
Oct 03, 2009 | Microsoft Windows XP Home Edition
My windows xp dvd/cd burner wont burn
Hello
Does your DVD drive detect data dvd's or cd dvd's?
if not, it seems like a hardware problem and needs to be replaced...
Feb 21, 2009 | Microsoft Windows XP Home Edition
How to use my cd burner
Windows XP has built-in CD/DVD burning support, but it is very basic. Simply right-click on any file you wish to burn and choose "Send To" then select your DVD drive. Doing this will add the files to your "burn queue". At any time after that, you can click "File" then choose "Write Files..."
Or, you can use a better program like Nero or Alcohol 120 ...or about 1000 other CD/DVD burning programs on the internet. It's really a matter of personal preference, and price :)
Hope this helps - remember to rate :)
Scott
Oct 05, 2008 | Computers & Internet
Microsoft Windows XP Home Edition for PC Logo
119 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
