Question about Memorex Audio Players & Recorders
Memorex Mi1200 Micro System stereo won't play. Buttons all seem to work but no sound comes out regardless of volume settings. Tried CD player with same results. Any ideas?
  • 130 Answers
SOURCE: CD player
All this cd systems have the same problem. If you're using burned cd's sometimes they don't work so you need to close the session after burning in your burning program. If you're using original cd's it means that the device needs to be cleaned up (especially the lens) because the structure of a 5 cd combo device gets very dusty after a while. Also from my experience after cleaning it put a cd in each deck (even if it's off) so they could prevent it getting dustier again. Hope it helps, good luck!!
Posted on Feb 12, 2006
Cruel dog
  • 8 Answers
SOURCE: system keeps sayin protect
The word PROTECT appears because there is a short. It can be in your speakers, try running it without the speakers plugged, or look if the wires arent shorting. If it stil ldoes that, its cause there is a short in it, from the output section. The system does that to prevent from damaging the electronic components inside.
Posted on Feb 21, 2007
VOTIT
  • 2071 Answers
SOURCE: CD Player Problems
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Aug 17, 2008
shagone
  • 34 Answers
SOURCE: Stereo stopped responding
1. While in Demo mode push and hold the "PUSH-MENU" button until "set" appears on the screen.
2. push "Seek" + or - to select Demo
3. turn "PUSH-MENU" to select "demo off"
Posted on Sep 10, 2008
killer_clown
  • 86 Answers
SOURCE: Memorex Dvd player gets stuck on HELLO screen randomly
well. i had the exact same problem but i unpluged it pluged it back in, same prob hello screen so how i fixed my problem i punched it an it shut off an went on standby an worked ever since..4 any of you with anger probs like me it mite work atleast it did for me lol
Posted on Oct 14, 2008
How do I play iPhone on Memorex m1111
I plug my iPhone into the Memorex Stereo (which has an iPod ...
discussions.apple.com > Support > Apple Support Communities
AppleJun 2, 2012 - I plug my iPhone into the Memorex Stereo (which has an iPod function) and the music is not playing on the speakers. My son's iPod does work ... Memorex recorder-burned DVD's won't play on iMac
Sep 21, 2013
ipod touch will not play through dock speakers
Aug 16, 2010
More results from discussions.apple.com
Amazon.com : Memorex Home Audio System with iPod ...
www.amazon.com/Memorex...Player.../B0017Q6HB...
Amazon.com, Inc.Amazon.com : Memorex Home Audio System with iPod Dock and CD Player ... Sony ZSS3IPN Lightning iPhone/iPod Portable CD Radio Boombox Speaker Dock .... but there is a cord for FM radio reception and I'm sure if I play with it, I can get ...
Amazon.com : Memorex MI3602P PurePlay Portable ...
www.amazon.com/Memorex...PurePlay.../B0040YGJ...
Amazon.com, Inc.
Jan 10, 2016 | Cell Phones
Sony cdx-gt610ui buttons won't work
Guys,
I have a CDX GT610, the issue is that is not possible to change stations, even if I try with the push buttons to record the stations, it remains on the same station (number 3 in my case), besides the volume gets high if I want increase the volume, any suggestion about it??? please let me know
Best Regards,
Marco Hernandez
Feb 26, 2013 | Sony CDX-M630 CD Player
I have a Sony Eplod MEX-BT2800, all of a sudden the buttons/functions won't work, I currently have a CD in the player, the buttons to skip songs won't work and I can't even eject it. Also I...
Hi i removed the positive on the battery terminal and tried the stereo still no buttons work although the source button and volume work but thats it any ideas thank you
Jul 06, 2011 | Sony MEXBT2800 AMFMCD Car Stereo Receiver...
I was given a Memorex CD Micro System (21 Channel) as a present. They no longer have their receipt. I have the box that it was purchased in, but there was no remote control enclosed. Everything works...
In regards to your issue, you can actually increase ordecrease the volume with the volume +/- buttons located on top-right section ofthe unit. If you really want to get a remote you can contact Fox Internationalwhich is the company that handles parts and accessories for Memorex Electronic products. In case they do not have the remoteavailable, there is another company that sells remotes for different products;their web site is www.remotes.com. I hopethis information was helpful.
Nov 18, 2010 | Memorex Dual Alarm Clock Radio for iPhone...
I have tried to record from Tape to CD with No result. I have followed the instructions for this task, to the letter and still nothing on CD.
First make sure yoou are using correct cds. You need CDR Audio discs not blank pc media type (Yes they are different). Once you have the disc type right, make sure you are finalizing the disc as they will not play in other machines until u do this
Oct 30, 2010 | Electro Brand Nostalgic Stereo CD Music...
No sound on Memorex DVD player
This could be caused by loose tape connector or faulty volume adjuster. First try playing a standard cd, then dvd, and finally a bootleg dvd because they create a lot problems for these smaller units. It would seem that you may need to open the unit inorder to find out what the problem is. If you do please becareful and take notes because you will have to put it back together.
Aug 20, 2009 | Memorex MM7000
Hi! My DXZ545MP CD Player had some buttons pushed by my dog in the car and now the volume no longer works. There is no sound at all regardless of the volume levels and it simply stopped playing music once...
first kelly... if you don't already have it .. here's the manual...
http://www.clarion.com/ca/en/MungoBlobs/754/615/DXZ545MP(Manual),1.pdf
you can reset that by unhooking the battery for about 10 minutes and hooking it back up... if that is an anti-theft type radio make sure you know the code and how to enter it. you'll have to set the pre-set stations again too.
Robert
Please take a moment to rate this solution thanks.
p.s. just noticed how long ago you posted this. you probably have it fixed by now... but the manual may come in handy to you
Jan 01, 2009 | Clarion DXZ545MP CD Player
Bass sounds only
That is tricky one. Did you try adjusting the EQ on both the stereo and the amp? Is the Mute turned on because it will act like that? Is both rca jacks plugged in on stereo and amp?
Aug 20, 2008 | Alpine CDA-9856 CD Player
198 people viewed this question
Top Memorex Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Greg Cann
Greg Cann
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
