Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
F2 error drawer will turn on by itself
Sluggish performance
  • Fisher and P... Master
  • 3,247 Answers
Most likely cause is the rotor at the base of the drawer is stuck or there is some foreign object in the drain sump. You will have to pull out the rotor and check for any obstructions - broken glass or pieces of bone or dry seed.
Posted on Jan 19, 2014
2 Suggested Answers
SOURCE: DD603 upper drawer pump rotor will not turn - F2
Maybe you dont have to remove anything else.. try the rotor from the bottom drawer first. If this works just buy a new rotor..
Posted on Aug 05, 2009
F2 error code won't drain
The problem is with rotor assembly of the drawer that is causing the F2 error. Turn power off. Empty water using a small container and towel to dry base.
Remove the washer arm and drain filter sump cover. Twist the rotor at the base out from the socket gently but firmly.
Clean the cavity and check the rotor for damage. Put everthing back in and turn power on.If F2 does not go away then replace rotor.
Aug 21, 2012 | Fisher and Paykel 24 in. DD603H W Built-in...
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
F2 &F3 error codes, oven keeps beeping, I already tried turning off circuit breaker did not solve problem
F2
- E0 Shorted keypad (also called touch
pad) 1. Check keypad connector for firm
connection (keypad connects to control board).
2. Press CANCEL. If error code
returns after 60 seconds, replace keypad (also called touch pad or membrane
switch). Some models incorporate keypad in to control board as one unit. In this
case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open F3 - E0 Oven temperature sensor (RTD) opened (upper oven,
if double oven) Replace Oven temperature
sensor (RTD)
Note: Applies to all F3-E...
codes. F3 - E1 Oven temperature sensor (RTD) shorted (upper
oven, if double oven) F3 - E2 Oven temperature is too high (Cook
mode) F3 - E3 Oven temperature is too high (Clean
mode) F3 - E4 Oven temperature sensor (RTD) opened (lower oven,
if double oven) F3 - E5 Oven temperature sensor (RTD) shorted (lower
oven, if double oven) F3 - E6 Warming drawer sensor open F3 - E7 Warming drawer sensor
shorted
Dec 20, 2010 | Whirlpool Accubake RF362LXTT Electric...
We have the error F2 showing on our dish drawers
normally the F2 showing on both drawers is unusual.
It is a rotor fault. Which means either the rotor that drives the wash arm and also works as a pump is either faulty or there is some rubbish stuck in the rotor cavity.
Lift the fiter plate out and open the rotor ring. Get the rotor out and inspect. If it looks ok or there was no noise when the F2 error showed up then the hall sensor mounted on the underside of the drawer is faulty.
The hall sensor can be hard to replace unless one has good experience in repairing dishwasher.
Nov 27, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
About one minute after pressing start, all stops and F2 flashes. Need a solution before tearing into it.
Please provide model no. of your fisher and paykel dishwasher.
The F2 error usually means the rotor at the base of the dishwasher is either faulty or is unable to move due to food particles getting caught.
Happy to help further if you can provide model no. and if double drawer then in which drawer this is happening?
Aug 17, 2010 | Fisher and Paykel Dishwashers
Fisher & Paykel dishwasher drawer won't run, beeps F2 error code
Craig, we had virtually the same situation.  The repair man  came and it took 2 minutes to fix.  The problem was that the bottom drawer had not been used for a couple of years and thus the impellor had jammed.  to fix it take out the basket, lift off the rotor arm and unscrew the knob.  Then just work the impellor around with your fingers until it frees.  It then worked perfectly.  We will use the bottom often from now on to prevent this happening again. By now the left over pumpkin pie will be a bit green!!
Nov 29, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher & Paykel Dishwasher
f2 refers to a motor error, you have the manual??? if not hereit is, try taking apart( its mean t for you to be able to service your self, its explained in the manual as to hoe to gfe down ther, the motor/ also called rotor is located within the drawer itself and under the silver screen every compponent twist out to reveal the next look for something under there somewhere preventin the rotor from spinning freely
http://www.fp.co.nz/admin/pdfs/pdf_usecares/527972D_DD_UserGuide_NZw.pdf
Apr 08, 2008 | Dishwashers
Oven trouble
Do Not try to perform the below if: Oven is under warranty,You are not handy with a soldering gun, or Are afraid to do this.
The below solution applies only to my in-wall oven with F2 and F3 codes randomly, but presumably will work with other GE models.
I had the same trouble with a GE in-wall oven. The problem was on the electrical board behind the keypad. A pin that was soldered to the board, that was the input for the oven temp sensor, had cracked solder. So I re-soldered the pin and hopefully it will continue working.
If this fixes your oven please post back!
Dec 16, 2007 | GE Spectra JBP78 Electric Kitchen Range
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
