Question about 3M MP-410 Pocket Mobile Projector
How do i hook up my tablet to a 3m mobile projector mp410
I have a Zeki tablet model# TBDC1093B with a mini hdmi connector and a usb micro connector on it. My 3M Mobile Projector model# MP410 has several different connections that can be used. I purchased a high speed mini hdmi to hdmi with Ethernet cable at the advice of a tech advisor at Staples. It briefly show the screen on displayed on my tablet then lost signal. I have not been able to get to that point again. Any suggestions? Thanks.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Yes, you need to look at the projector and see if it likes the Android operating system as it might not ... now you might also check into google play and see if anything is there to help with this fiasco... or look into the projector options/operators manual to see what it can read... once again, google might help
Posted on Dec 29, 2013
3 Suggested Answers
SOURCE: Where can I get a replacement lamp for my 3M
You should buy at Walmart or ask the electrical supply shop
Posted on Mar 07, 2011
  • 51 Answers
SOURCE: 3M 1700 overhead projector I have a 3M 1700
The button is probably worn out. You will need to get a new button for it.
Posted on Mar 12, 2011
8 Zeki tablet please I need to know what the Hdmi on the tablet is for.....
You can hook it up to any Device that uses HDMI input.
Jul 25, 2017 | Tablets & eReaders
I want to hook my tablet to my tv, how can I do this?
Use an HDMI cable between your tablet and your TV. On my tablet, the HDMI port is near the micro USB power port.
Jun 03, 2017 | Tablets & eReaders
Ematic lp2p tablet doesn't recognize usb or pc
1 port is a mini hdmi port to connect to a tv via a hdmi mini to hdmi cable,the other is a mini usb port,with the data cable that you can buy for it,you can connect to a computer,not just any usb cable will work,there is 1 for charging and 1 for data Ematic Edan XL EGS109 9 Inch Tablet 5 ft USB 2 0 Mini Micro Cable
Apr 27, 2015 | Tablets & eReaders
I replaced the front screen. Bottom 2/3 of screen is now scrambled. Can't do a reset as I can't read screen. What do I do?
Try to re insert the connector to the screen. Resetting won't do anything about hardware issues including the screen. Worst comes to worst, you can by a micro/mini(depending on port type)usb to hdmi and hook it up to a TV or other external hdmi display
Mar 06, 2015 | Tablets & eReaders
Why wont my new Zeki tablet show it's charging, it stays at 14%?
It sounds like either the the charging device is bad or not compatible; if it's a dedicated one, i.e. not having a micro USB connector, then it's likely defective. If it charges using a micro USB connector or cable then it may be that the tablet just doesn't "like" that cable. Try using a different one. If that doesn't work then the last, and most unpleasant, possibility is that there is something wrong with the charging circuit it the tablet itself. If it's new then take back to where you bought it, it should still be under warranty.
Jul 15, 2014 | Tablets & eReaders
What cables are needed for a tablet to tv connection
Depends on the tablet. Many have a micro hdmi connector so a micro hdmi to standard hdmi cable will do the trick. Some have a mini hdmi so mini to standard. There are some that only have a 1/8th inch jack so you would need a 1/8 inch video adapter that splits off a right and left audio and a video RCA cable.
May 29, 2014 | Sanyo DP39842B 39" 1080p LCD TV...
Can i connect my archos 97 cobalt to tv
• Micro USB 2.0: Mobile Transfer Protocol (MTP)
• USB host via OTG
• microSD (compatible with 64 GB cards)
• HDMI output (Mini HDMI / HDMI cable sold separately) If you have the Mini HDMI to HDMI cable you may be able to connect to HDMI input of TV, or try USB out of the device to Computer input on the TV....
Apr 30, 2014 | Audio Players & Recorders
How to take a part Motorola Universal Dock csd-8109?
Motorola doesn't endorse/support this type of modification.
Mark
Motorola Support
Apr 24, 2014 | Motorola Mobility 89512N Platform...
How to connect an asus transformer to a phillips picopix 2055 projector ?
you cant, directly at least... there are no drivers for android to run this projector. since it is only USB, you cannot convert the hdmi to usb...
you could use your computer as a middle man, without hdmi input on your pc there would be video lag and your better off just using your pc.
you could return the picopix you have and get the PPX2480 version, that is brighter and also has hdmi input which you could get a mini-hdmi to hdmi cable and use it directly.
hope that helps
Feb 28, 2013 | ASUS Tablets & eReaders
3M MP-410 Pocket Mobile Projector Logo
563 people viewed this question
Top 3M Office Equipment & Supplies Experts
jasbo
jasbo
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
