Question about Dynex Televison & Video
Dark shawdow 37 inch lcd
The picture has a dark color in the middle like a dirty wipe job
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Not good, you are loosing your display
Posted on Dec 29, 2013
  • 71 Answers
SOURCE: I have no color on my 37 aquos sharp lcd
Give more info. In tuner mode, in component,rca or s-video input?
Posted on Dec 09, 2007
  • 458 Answers
SOURCE: 37 inch LG LCD won't turn on due to power failure
Power failures can cause all types of problems, have you firstly checked the fuse in the mains plug? If that is ok then it may have blown an internal fuse in the power supply board, these are there to protect the rest of the circuit from power surges.
Posted on Mar 24, 2009
SOURCE: 37 INCH LCD HD NO PICTURE GREEN LIGHT ON, BUT NO SOUND
Unplug and replug it...it should work eventually.
I have the same problem with my 32".
But it eventually goes on when i try it a couple of times (the number of times is completely random...sometimes none, and sometimes like, 3).
Posted on Jul 07, 2009
  • 541 Answers
SOURCE: I have a 10 to 12 inch dark area in the middle of
It sounds like a bad panel or possibly a bad digital board. This board is mounted on the back of the LCD panel. Have it checked by a repair shop.
Posted on Oct 14, 2009
monfilsd
  • 3 Answers
SOURCE: my Viewsonic N3751W 37-Inch LCD HDTV always shows 480p
your dvd is set to 480p. if it is a convertable dvd player set it to 1080i. the tv sets itsef to whatever the dvd player displays. if not all dvd is 480 to 720 p. blu ray will get you top notch 1080 display.
Posted on Oct 22, 2009
I have a proview lcd screen and it palys the tv shows in back ground but it's a dark screen like dark blue no picture. Volume and everything working but just no picture. What can i do.
Show a torch light on the screen for a distance, and if you can see the picture, the backlight is not lighting up. Check for its settings on the remote, if you have that option. Check also the settings of brightness/contrast/sharpness/color. If you still have problems, please call in a qualified service technician.
Jul 25, 2012 | Proview PA-37JK1A 37 in. LCD Television
Can't get picture screen clean
If the dark streak is static, then is liquid in lcd panel.
Oct 24, 2008 | Polaroid Televison & Video
Why do i have to have the brightness set at 100% or you cant see the picture
Hello
If baklight CCFL tubes become weak, the brightness will be very weak. Now you can see the picture with least brighness. So it is sure that, the backlight inverter board is working well. Just check the CCFL lamps. For a 37 inch LCD tv may have atleast 14 CCFL lamps. When replacing, do replace all at one time. OK.
Dec 18, 2011 | LG 37LH3000 37" HDTV LCD TV
The colors on the television seem to be going, all colors are fuzzy and screen is dark
picture tube got affected so take the lcd to television service center
Dec 25, 2010 | Vizio VW37L 37 in. LCD HDTV
I have verticle lines on my Mitsubishi LT-52133. the lines are perfectly up and down and the picture in the middle is good but about 4 inches on the left is dark and miscolored and 4 inches on the left are...
That is not good, it can be as bad the LCD panel is bad which is more likely or the LCD panel inteface board betwwen the screen panel circuit and the main video processor board.
Nov 03, 2009 | Mitsubishi LT-52133 52 in. LCD HDTV
LCD is dark, can only see shawdows
press and hold the Fn key down
while holding it down press the up arrow key to increase the brightness.
key combination
Fn + up arrow key
Jun 12, 2008 | Dell Inspiron 1200 Notebook
Dec 07, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Rca home theatre big screen tv
# 1 above you have covergence problems ,there is a service flash from rca to fix your fault,ask your tv shop. fault # 2 above turn off the color and adjust your screen settings for a grey picture,set brightness and contrast to middle settings. # 3 fault read #1 cause if your auto focus will not correct you require service there is a harness connector that looses connection and causes several fualts on the 52" rca's you can repair the fault but if you miss the harness replacement you will do it again.
Dec 01, 2007 | RCA 32F531T 32" TV
Televison & Video Logo
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
