Question about Philips 40pfl7705dv/f7 40 Hz 120 Led Tv - Philips
Programming rc66rx manually 40PFL7705DV/F7 - Philips 40pfl7705dv/f7 40 Hz 120 Led Tv - Philips
I have a Denon AVR-1600 receiver and just installed a DirectTV receiver, RC66RX remote. How do I program the DirectTV remote to run my Denon receiver?
I don't think the codes are available online?
although if you call the directTV 1 800 # they can give you the program code, really hope this helps?
Feb 27, 2015 | Denon AVR-1601 Receiver
Okay I've purchased a 40 inch tv today and how do I reset everything?
From the User Manual, page 35 (page 36 in the .pdf file):
Return your settings to default values When you return picture and sound settings to their default values the
channel installation settings are not affected.
1 Press MENU on the remote control and then use [the arrow buttons] to select [Setup] > [Installation] > [Reset AV settings] > [Start now].
2 Press OK to reset the picture and sound settings.
3 Press MENU to exit.
You can download a copy of the manual from 40pfl7705dv_f7_dfu_aen.pdf http://download.p4c.philips.com/files/4/40pfl7705dv_f7/40pfl7705dv_f7_dfu_aen.pdf
You may also want to look at "Update your TV software" on the following page of the manual. Updating is not always necessary, unless the update fixes something that bothers you or provides an improvement you want (if it isn't broken, don't fix it). As of this writing, there are two sets of fixes (copied from the "Firmware Upgrade Readme File" at Software & drivers):
Software history:
Version: Problems solved.
PHL-0DA_710_0 - Momentarily looses audio after channel change.
- Time shifts one hour when changing from "Auto Clock" to
"Manual".
- Enables Philips Wireless Media Connect.
PHL-0DA_713_0 - Clock does not keep accurate time.
You do not have to apply both updates; everything is included in the latest one.
Jul 24, 2014 | Philips 40Pfl7705dv/f7 40-inch Smart...
Upside down
Your Horizontal and Vertical Flip is reversed for some reason. This will be a little difficult to do/see, but turn on the TV and Press the Menu Key. Goto "Lock" and press OK. Once you see the Lock Code Box come up, press and hold the Volume down on the TV and the OK Button on the Remote for 5 seconds or more until the TV shuts off. This resets the Memory.
If that doesn't work unplug the power from the TV now for 60 seconds then plug it back in. It should power up at that point.
If that doesn't work it is probably an issue with the Logic Board and a Re-flash of the Logic Board from a Company who has the Equipment to do so will fix it. This shouldn't cost anymore that $150. Goodluck!
May 20, 2013 | Philips Televison & Video
PHILIPS 40PFL7705DV/F7 keeps shutting off
If it is a new TV and under warranty, return it. There is an internal fault and it needs to be serviced.
Oct 25, 2012 | Philips 40pfl7705dv/f7 40 Hz 120 Led Tv -...
What do auto fill and auto zoom do on the picture format settings?
You have to enter its service mode options, and make necessary data adjustments there. Just remember, this is a very skilled work. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 580 posts to different brand TVs.
Aug 13, 2012 | Philips 7000 40" 1080p 120Hz LED-LCD HDTV...
Will not connect to wireless network
I suspect Mac Filtering is the problem
see page 37 and 38 of Cisco administration Guide on Mac Filtering.
https://www.cisco.com/c/dam/en/us/td/docs/wireless/access_point/csbap/wap4410n/administration/guide/WAP4410N_Admin_Guide.pdf
page 37 and page 38
"Connection Control The Wireless > Connection Control page is used to exclude or allow only listed client stations to authenticate with the access point. Depending on how the WAP is configured, the WAP device may refer to a MAC filter list stored on an external RADlUS server, or may refer a MAC filter list stored locally on the WAP device. Enabling Local Connection Control To refer to a MAC filter list stored locally, follow these steps: "
see link above page 37 for the steps -
I Do not want to be accused of breaching Cisco Copy Right
Oct 30, 2017 | Philips 40PFL7705DV/F7 - 40 LED HDTV with...
I need a manual & a remote for model #22PFL4505D/F7
Philips has the manual on their site: http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=mx&ctn=22PFL4505D/F7 . The direct link to the PDF of the manual is http://download.p4c.philips.com/files/2/22pfl4505d_f7/22pfl4505d_f7_dfu_aen.pdf .
A replacement remote that will need to be coded for the TV is available here: http://www.emtcompany.com/philips-22pfl4505df7-remote/rc64.html . An exact replacement remote can be ordered from http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13064588862470&smodel=22PFL4505DF7&brand_pn=PHILIPS_22PFL4505DF7 . However any universal remote should control the basic functions of the TV if they were programmed 6 months or more after the TV was released. Low end remotes may not replace all of the features of the remote. If you have a remote that matches all of the features, you may need to try all of the codes for the Philips TV to get all of the features to work. Those remotes that can be programmed via a USB connection with a computer will be the fastest to set up.
I hope this helps.
May 27, 2011 | Philips Televison & Video
HI.... WOULD YOU PLEASE HELP ME TO RESET P/M ON PANASONIC COPIER 7728 . I DONT KNOW HOW TO ACCES THE SERVICE PROGRAM..... THANK YOU .
just press "user preset" "original size A3" and "3" simultaneously to enter service mode and the display will be "F1"
to reset the p/m, you should change the value of F7-c22 and F7-c26
go to F7 mode(press 7 to move to F7, then press start)
press "2" "2", then start
press "0" to reset the value of F7-c22, then press start
now press "2" "6", then start
press "120000" to reset the value of F7-c26 (this counter is countdown so it starts with highest count)
press start
press stop to exit F7 mode
press "user preset" and "stop" simultaneously to exit service mode
that's it
May 21, 2010 | Panasonic Office Equipment & Supplies
Philips 40pfl7705dv/f7 40 Hz 120 Led Tv - Philips Logo
73 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
