This is for those who are struggling to connect rca cables to tv. Cables are normally color coded, yellow is for video (out from dvd snd in to the tv). Red and black sometimes white is for audio (left and right). Same thing here out from dvd in to the tv.
It could be a game console connection problem, make sure that your Yello RCA output is going in your Video input on the monitor or monitor receiver. You might have a power or voltage problem, if the wrong current or voltage is incorrect then errors and freeze ups can happen, the player wont support the wrong voltage going in. Check your power connections, Video out/input connections and check your voltages.
Good luck.
Make sure to vote and rate me if I helped you. thanks
USE RCA CABLE SET IT IS YELLOW/RED/WHITE THE YELLOW SHOULD BE VIDEO IT WILL SHOW THIS ON SET AND PLAYER. I WOULD ALSO RECOMMEND YOU USE THE AUXILIARY PLUG IN ON SET THEN JUST TURN ON SET AND SET TO AUXILIARY IF YOU DON'T HAVE THIS USE DVD FEED IN THEY SHOULD BOTH HAVE RCA PLUG INS FOR RCA CABLE
On my ad212 dvd system by Myron and Davis it has an attached fm radio modulator. It has 4 channels you can use and they corresponed to unused frequencies in the users area of travel . Mine is set to 88.7 fm and all I had to do was set the FM radio to 88.7 to get the audio playing on the dvd movie.
