SOURCE: No sound from digital cable thru AVR3200 after adding HDTV - DVD plays fine
you need a digital coax cable and then connect it to 6.1 also the digital cable type is not a coomon type so check that also
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
SOURCE: Connecting a Dish 622 Receiver to the HTR500 and a Sony HDTV TV
Have a Vip-722 Dish HD receiver with a Sony receiver w/0 HDMI input and use the optical for audio for the 5.1. Using the HDMI and digital optical at the same time works fine for me.
SOURCE: sa-dx1040 dvd optical input works, tv and cd do not.
You have to manually select digital input on the receiver.
SOURCE: 8' Optical Cable from TV to Receiver and Signal is Breaking Up
Before you buy anything try checking the AUDIO Settings in the Menu of Each Device (Mostly TV) and see if they are set to PCM or BITSTREAM. HDMI is mostly set to PCM while Optical is generally Bitstream. The TV may be set to the opposite of what it needs to be. I would try to get PCM to work first cause it is Better, If not then set what you can to Bitstream and it should pass. Also check in TV Menu for SOUND OUT or AUDIO OUT or SPEAKERS. Some TV's have a problem passing Audio through when they are already Outputting them to it's own Speakers! I Hope this Helps out!
