Question about Acer Computers & Internet
Screen says no signal
Computer has been in the shop there is nothing wrong with it I got it back and the screen still says no signal
  • 62 Answers
It will be the screen or cable.. if you power on screen unpluged from pc do you get same message?? if so it could be screen faulty. try booting pc in safe mode to see if you get a screen image. if so its the resilution to high
Posted on Dec 29, 2013
Need to find jumper to reset bios on joshua h61uatx board
That is because you have not downloaded the manufacturers drivers for your new OS.
Nothing wrong with the BIOS as the motherboard is running. Try loading safe mode to return to Win7.
Feb 24, 2017 | Vga Computers & Internet
Gateway a computer desktop has power but nothing on screen the computer doesn't have a tower
1) Computer doesn't have a tower? Means it is a 'pancake style' of desktop computer. A flat model.
2) No signal on monitor screen?
Good.
At least we know the monitor is good.
Problem is monitor cable, IF separate cable; or computer.
Computer isn't sending a video signal.
No Signal, Power Saver Mode, etc.
If an older CRT type monitor, (Looks like a small TV), and monitor cable is not detachable; use a known to be working monitor, and monitor cable.
If a separate monitor cable, use a monitor cable from a working computer, for a temporary test unit.
Put it back when deemed monitor cable is the problem.
Logic at this point, would deem something is wrong with the graphics chipset.
Whether mounted directly to motherboard, (Integrated), or a separate graphics adapter card. (Graphics/Video Card)
However, computer could be dirty inside, or have a bad Power Supply.
LED's (lights) light up? Maybe fans spin?
Means nothing.
1) If ALL of the Light Emitting Diodes were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use from 51 to 130 Watts of power.
Just depends on what Processor it is.
Older desktop computer?
Ummm, 35 to 40 Watts.
That is why LED's can light, and maybe fans spin, but no computer.
NOT enough power to turn the Processor on.
Computer needs to be CLEAN on the inside. Inside of Power Supply too, as well as possible.
Proper method to do this procedure, post back in Comment if you need guidance.
Also remove ALL Ram Memory modules, and clean gold plated contact pins on bottom; with pencil eraser.
Reinstall. Make SURE they are seated in tight, and Lock 'ears' are locked in place.
Post in a Comment, as to the model number.
Example, DX4300-05. Should be on back of computer.
Regards,
joecoolvette
Mar 22, 2013 | Gateway Computers & Internet
As the computer boots. The screen goes black. Nothing happens
When you mention boots, Is the computer able to POST a message to the screen or do you mean switching the computer on and there nothing POST to the screen. If your computer is able to post and then you get a black screen after that with possibly a flashing underscore symbol, then you are missing a O.s or your harddrive is currupted. If nothing is POST to the screen once the computer is turned on, then there could be couple of culprit that is causing this defect to RAM memory error, VGA, CPU, or the Motherboard itself..... The only way to test what is actually wrong is to have other hardware compatiable to test the computer itself.... would reccommend you taking it in to a computer shop since they have diagnositc tools, unless you have other computer hardware to test this with.
Jan 15, 2011 | Computers & Internet
Since the new mother board was installed into our new studio desktop computer, we frequently lose the internet screen or the screen which we are looking at even when the diagnostics tell us that their is...
Hi, try to get the latest updated driver for your LAN adapter this may fix the problem.
hope that it will help and don't forget to rate
kind regards
Mar 20, 2010 | Dell XPS 200 PC Desktop
Gateway fpd1760 lcd monitor no power at all the blue led clicks on for 5 seconds the screen flashes for a milla second then nothing
check if the signal cable has been plugged in properly at the back of the screen and at the back of the computer.
if you have another computer or laptop,.check if the screen works fine with it.as this could even be a boot up problem with the computer
Feb 04, 2010 | Gateway FPD1760 17" LCD Monitor
Flat screen tv stopped working suddenly hooked up thru HK230
Hi there bud , Are you sure you are using the RCA cables correctly? and not just connecting the speakers into the T.V?
Jan 04, 2010 | Harman Kardon Harmon Kardon SoundStick II...
Laptop screen went black
When I opened my laptop this morning my computer won't come on. The screen is totally black. I took out the battery and put it back in ---- still nothing. I plugged it in with the power cord --- nothing! What is wrong with my HP Compaq Presario CQ60?
Jan 04, 2010 | Compaq Presario CQ60-220US PC Laptop
JM777 no receiving signal from CPU
when u power up the computer press F* key then go to enable vga mode then set disaply resolutin incotrol panel to 800*600 or 1024 *768
Nov 24, 2008 | Relisys TL 766 Monitor
No display
When you get the red and green leds lit it means the screen doesn't see an input signal and has gone to stand-by. That the red led goes off when you reconnect suggests a signal has been recognised by the screen but be very aware that it may not be a good signal. As you are using a PC input I will assume the signal is RGBHV, maybe you have the H and V swapped around? I would try another computer source into the screen.
You say you are using the digital harness, please explain exactly what this is.
Feb 18, 2008 | NEC MultiSync LCD4010 40 in. Television
Montier is blank when i stat up
Your monitor should have a light on it that indicates if it has signal, if the light stays yellow(or blinks) as the computer boots it is not getting the signal from the pc. Check the VGA cable on the back of your computer, it a big blue connecter, it has to be unscrewed and and disconnect it to verify that none of the pins are bent, plug it back in snugly and see what happens.
Sep 16, 2007 | Computers & Internet
Computers & Internet Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
