Question about Canon EOS 500D / Digital Rebel T1i Digital Camera
Will using a SD card from another camera mess up my Canon? Seems ever since I borrowed a SD card my camera has been totally messed up.
Flash goes off several times upon turning camera on, the MENU button won't function and more.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 13 Answers
As long as it is the right card for your camera you shouldn't have a problem. Try removing it and installing a smaller card, (make sure you power down the Camera 1st).
Posted on Dec 29, 2013
SOURCE: Canon S70 does not work
I was experiencing the same problem - I think the Button and Zoom had become jammed down slightly. I simply lightly applied pressure lifting the surround of the button up! My camera is now working perfectly.
Posted on Jul 13, 2007
old marine
  • 1985 Answers
SOURCE: Canon Power Shot A400 will only work with original Canon SD card
Make sure you are using an SD card and not an SDHC card. The SDHC protocol is newer than your camera, and your camera does not support it. SD cards have capacities up to 2 GB. Your camera should work properly with any SD or MMC card.
Posted on Apr 22, 2009
SOURCE: Canon Powershot SD1000: LCD screen display
Hopefully you resolved this already. If not, push the "DISP." button left of the MENU button. Pushing it gives you three options: black (for discreet shooting so your LCD doesn't give garner dirty looks from fellow concert goers), liveview, and liveview with info overlayed (shooting mode, ISO, etc.). Good luck!
Posted on Aug 18, 2009
  • 68 Answers
SOURCE: How to format an SD card on a Canon SD600 camera
Could be that you have the wrong memory card.
SD600 will only work with the old SD cards, but the SD780 will take the SDHC cards.
SDHC was intended to give 4gb or more of storage, while the old SD started as 16 mb.  Different cameras have different limits, but it is always best to assume that the practical limit on an SD card is 2mb.  Even if the SD780 will take the SDHC cards, it can be more practical to only carry 2GB SD cards and know that they will fit either camera
Posted on Feb 22, 2010
  • 102366 Answers
SOURCE: Can I use 8GB SD cards in my Canon Powershot A620
The A620 uses MMC and SD cards. SD cards max out at 2GB in size. Larger cards are actually SDHC or SDXC cards and will not work in the A620.
Posted on Jan 11, 2011
Why is it displaying "no SD" message?
yes, unless two different sd cards could go bad at same time. Bummer.
Aug 30, 2015 | Cameras
My old memory card was busted, so I ordered a new one and a couple backups of different memory cards. It says that I need to format the cards, which is what I was expecting, but it keeps saying that it...
If your old memory card was "busted" is it possible youhave damaged the memory card holder/reader in the camera?
Anyway, seems memory card problems are not uncommon with this camera.
It might be worth your while to have a look at http://web.canon.jp/imaging/eosd/firm-e/eos
This enables a firmware update which may (or may not) fix your problem.
Sep 08, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
My Nikon d80 shows the msg as card is locked,how ever i tried to solve the problem by sliding it to write position.Can someone can help me rite now?
Here is a diagram to show the correct position of the switch.
Diagram
Good big picture and it doesn't matter that it has Canon written on the SD card in the picture the SD card is interchangeable between the two makes.
Now one other thing that may also be the problem is that the SD card needs to be formatted to the camera. Formatting should be done on new memory cards and after you have downloaded pictures to the computer. That's format not delete, delete leaves a mess on the card Formatting cleans the card and provides proper communications between the camera and the memory card
Jan 21, 2011 | Nikon D80 Digital Camera with 18-135mm...
Have canon powershot what is best to use a 2gb
Hi and welcome to Fixyah,
I believe that canon can only use SD card you can used 2gb sd card.
Mar 18, 2010 | Canon PowerShot S2 IS Digital Camera
Card locked!
Remove the SD card from the camera. Slide the tiny switch on the side of the card to its other "unlocked" position. Reinsert the card in the camera. But if you've already tried this, see this link for additional things that you can try.
Jan 19, 2010 | Canon Cameras
Older Vivitar Flash for new Canon SX10
Not compatible.
Get slave triggers and use them as remote flashes, or buy another film camera.
It seems Vivitar no longer is in the flash business. Get a Sigma or Sunpak digital flash for your SX10
Aug 28, 2009 | Vivitar 285HV Flash
Downloading
This camera uses SD cards if I remember correctly, and most laptops have an SD card slot. Try taking the SD card out of the camera and popping it into the SD card slot on your laptop to see if you can get your pictures that way. Much quicker and easier than messing about with USB cables...
Feb 05, 2009 | Konica Minolta DiMAGE Xt Digital Camera
Powershot A640 Buttons not responding
I would call Canon tech support and set it up for service. They will let you know what your options are. 1-800-828-4040.
Hope this helps!
Jun 02, 2008 | Canon PowerShot A640 Digital Camera
S2 is camera
no i cant ..but i can on another camera...
Apr 11, 2008 | Canon PowerShot S2 IS Digital Camera
Canon EOS 500D / Digital Rebel T1i Digital Camera Logo
20 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
