Question about Malibu Hardware & Accessories
Malibu ml200tw no output voltage
  • Malibu Master
  • 5,245 Answers
Posted on Dec 31, 2013
Testimonial: "According to the troubleshooting guide, I guess it's just gone bad. It hums like it is working, but no output voltage...."
Schematic malibu 8100-9120-01
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
I don't think they post schematic for the transformer
But generally, the primary coil receives 120Volt AC input from household electrical outlet
And the secondary coil produces 12Volt AC output for the low voltage lights.
The 'coil' is a coil of insulated wire wrapped around a metal core. Two coils set side by side create a transformer... when primary is energized, the secondary responds to the magnetic field caused by primary core... resulting in a current that flows on the secondary coil.
Output voltage on secondary coil is determined by the number of wraps and diameter of wire.
Some transformers offer a choice of secondary output... Kichler for example... you can select 12-13-14-15 Volt AC output
This is achieved by the way the secondary coil is wrapped.... for less voltage a wire is tapped at one point on the coil... for more voltage, a wire is tapped at another point on coil. This gives the user several wire choices to connect the lights.
Gene
May 09, 2014 | Intermatic Malibu 300W Power Pack...
Malibu transformer
Unplug transformer, change bulbs with low voltage bulbs from local hardware or home center. There are two screws on back of each bulb.
Copy following link for tips to get power pack to last longer, replacement trippers, warranty, troubleshoot. etc
Reason for unplugging transformer: because product manual lists that as best way to change bulbs. The low voltage transformer output is 12Volts and does not carry enough power to cause you harm if you touch bare wire.
Add a comment and attach photo as needed.
May 25, 2013 | Malibu ML600TW - Low Voltage Power Pack -...
I SCANNED MY MALIBU & GOT A P0108 WHAT CAN I DO TO RESOLVE THIS PROBLEM
It could just be a bad signal from the MAP sensor or a poor connection at the sensor. Or a bad MAP sensor itself. Maybe the vacuum line is off or broken.
Manifold Absolute Pressure (MAP) sensor measures the changes in the intake manifold pressure which result from engine load and speed changes, and converts this measurement into a voltage output.
A closed throttle on when the engine is decelerating would produce a relatively low MAP output, while a wide open throttle would produce a high output. Manifold absolute pressure is the opposite of what you would measure on a vacuum gage. When manifold pressure is high, vacuum is low. The MAP sensor is also used to measure barometric pressure under certain conditions, which allows the PCM to automatically adjust for different altitudes.
The PCM sends a 5 volt reference signal to the MAP sensor. As the manifold pressure changes, the electrical resistance of the sensor also changes. By monitoring the sensor output voltage, the PCM can determine the manifold pressure. A higher pressure, low vacuum (high voltage) requires more fuel, while a lower pressure, higher vacuum (low voltage) requires less fuel.
A high or low voltage fault in the MAP sensor circuit should set a DTC P0107 or DTC P0108. If the MAP sensor sends an intermittent zero voltage signal to the PCM, a DTC P0106 will set.
Oct 13, 2010 | 1998 Chevrolet Malibu
I have a two wire to connect to output A B C on a malibu ml600tw low voltage transformer. Which two output do I use?
Use "A" and "B" terminals. The "C" terminal is a "dummy" terminal - it isn't connected to anything inside the transformer. It is used as a splice point in the event you decide to connect a photo cell (dawn to dusk) controller.
Aug 22, 2010 | Intermatic ML600TW MALIBU POWER PACK 600W...
Malibu Model: ML200TW Transformer Automatic timer not working
You can buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
I wrote power pack troubleshoot checklist:
http://www.fixya.com/support/r8391011-power_pack_not_working
Jul 23, 2010 | Intermatic Malibu 300W Power Pack...
I have an intermatic/malibu low voltage outdoor timer. I wish to add lights, but the only number I can find is 154LV24409
I think you can add any Malibu 12V lights rated for the 300 W power pack. Make sure that the total output stays below the 300W limit.
http://www.malibulights.com/ and click on Products and the different available lights will be detailed with the voltage and wattage.
You just have to click on the category, then the specific light and Product details.
This tier light would be acceptable http://www.malibulights.com/Products/Detail.aspx?category=Low+Voltage+Lighting&subcategory=Tier+Lights&sku=8301-9200-01&series=TIR-2009-1&seriesname=Cast%20Metal%20Tier%20Light&id=195
This flood light can also be put on the system
http://www.malibulights.com/Products/Detail.aspx?category=Low+Voltage+Lighting&subcategory=Flood+Lights&sku=8301-9602-01&series=FLD-2009-2&seriesname=20W%20Cast%20Metal%20Flood&id=206
I hope this helps.
May 10, 2010 | Intermatic & Malibu& 300 Watt Power/Pack...
Malibu ml200rt internal wiring schematics
If you have a meter you can test for 12 volts AC on the output of the transformer. They go to terminals
A & B
Jun 22, 2009 | Malibu ML200RT - Low Voltage Power Pack...
Hardware & Accessories Logo
37 people viewed this question
Top Malibu Hardware & Accessories Experts
Gene Haynes
Scott Jelt
Scott Jelt
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
