Question about Xerox Office Equipment & Supplies
How to set the 2 sided copy on the printer - Xerox Office Equipment & Supplies
    Problem Solver:
  • 9 Answers
You should be able to download manual. Otherwise it is usually under user settings, set default.
Posted on Dec 29, 2013
Double sided copies
Your printer has Duplex printing Capabilities. However when you are ready to send the print job, open the Printer Properties and select Double Sided.
To copy a Double sided document, insert it in the ADF (Automatic Document Feeder) and open the copy settings on the machine and select Double sided.
Jan 07, 2014 | Office Equipment & Supplies
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Jan 30, 2013 | Konica Minolta Bizhub C364 Color Copier /...
Interact s605 printing upside down
You can change the settings under printing preferences, just follow the steps below:
1 With a document open, click File > Print.
2 Click Properties, Preferences, Options, or Setup.
3 Navigate to:
Advanced tab > 2-Sided Printing area > select On
Note: To use the settings defined in the printer, select Use Printer Settings.
4 Select either the Side Flip or Top Flip option. Side Flip is the setting most often used.
5 Click OK to close any printer software dialogs.
6 Click OK or Print.
To return to single-sided printing, navigate to:
Advanced tab > 2-Sided Printing area > select Off
Sep 01, 2012 | Lexmark Interact S605 Wireless All-in-One...
Canon imagerunner 3235i. When it goes to print out the copy it instantly pulls it back into the machine and causes a jam. Any ideas as to what would be causing this or how to fix it/
you have opted for a 2 sided profile in the printer driver.change it to default settings.the copier is trying to print on both sides.if it is happening also during copying then u have to check the settings you have made.you can also clear the settings in common settings in additional functions . if u cant take 2 sided copies then u have to get ur copier check for duplex unit malfunction.
Aug 03, 2011 | Canon ImageRUNNER 3235i Black and White...
Double print
Both sides or 2 copies, if both sides go into the printer settings and correct. If 2 copies make sure you don't have that checked. It may have happened by accident. That should all be available in your printer application settings.
May 18, 2010 | HP Deskjet 870cse Printer
Duplex copying on HP Photosmart C8280 All-in-One Can't see how to do two-sided copy apart from scanning both sides and printing two-sided! Old HP printer could do 1-1 1-2 2-1 2-2 etc.
Open HP Solution Center, click on Settings, click on Scan Preferences, select "Scan both sides of original when using duplex feeder."
or
Open Solution Center, click on Scan Document, and you should have a check box towards the bottom of the window which would say 'scan both sides of the original document'. check that box and start scanning.
Jul 22, 2009 | HP Photosmart C7280 Laser Printer
2 sided copying
You just select 2-sided printing in the print dialog box. I think it's on the finishing tab. I'm assuming you aren't trying to print on 2nd side of pre-printed stock. That would be a different issue.
Apr 09, 2009 | Xerox Phaser 8500/DN Printer
I have a Samsung CLP-510 and I want to print 500 copies of the exact same document, which is 2 pages color. When I do this from MS Word, the printer takes about 25 seconds thinking between each copy. It...
CHeck your settings. If they are ok, then try printing the job from open office or wordpad. Are you using 2 sided printing? I have the same printer and it blazes thru stuff like this printing 2 sided and all. Just have problems with using cheap paper (jams).
Feb 04, 2009 | Office Equipment & Supplies
Wrong count
FYI, if copy 1 side of A4, then is count as 1. If both sides, count as 2.
If copy 1 side of A3, then is count as 2. If both sides, count as 4.
That's the default settings on the MFP.
If u want to be copy 1 side of A3 and count as 1, u need to adjust the setting mode.
Press 08 and ON MFP, Enter 346, change "1" to "0".
Jan 28, 2009 | Toshiba Estudio 200L Copier
Canon imageCLASS MF6530; can't set up duplex (2sided) printing
hi there
there are 2 ways to copy 2 sided
one is full duplex which means your copier must have a duplex attatchment fitted on the copier lid
the other if it hasn't got a duplexer is to copy in 1 to 2 mode which means you have to turn the copy over. it sounds like your machine has not got a duplexer fitted but it can still do double sided using 1 to 2.
hope this helps
beergut707
Oct 15, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
