Question about U-Line 2075RF Compact Refrigerator
U-Line 2075FS won't cool
Vacuumed out...still not cooling. Where is the thermostat located?
Thermostat won't change from heat to cool.
Go into the programing and change the reversing valve setting to the next number.
Jun 15, 2013 | Heating & Cooling
It freezes but won't stop
as long as the compressor is running on your freezer the longer the fan runs has to too cool the compressor . . .thermostat problem
Jan 11, 2013 | Boating
Furnace won't come on
10-17-12
Change battery on thermostat.
Usually located back of thermostat.
Oct 16, 2012 | Hunter Fan Company 5/1/1 Programmable...
New battries in Duracraft Programmable Thermostat for A/C...still won
Remove the thermostat and just touch the wires together and make it run until heat wave is over then figure it out. Kinda of a pain but at least it be cool
Aug 07, 2017 | Honeywell Electronic Programmable...
Where is the thermostat housing for the cooling system located on a 2003 suzuki areo?
open your hood look at your radiator, the top large diameter hose feeds the engine's cooling system this is where your thermostat housing will be located. The hose on the bottom is the return line
Apr 23, 2011 | 2003 Suzuki Aerio
Where to locate the thermostat on an 03 pontiac grand am?
Not sure which engine you have so please pick the appropriate engine:
2.2L Engine
  1. If equipped with an automatic transaxle, remove the exhaust manifold, as outlined in this section.
  2. Drain the cooling system.
  3. Remove the thermostat housing to water pump feed pipe bolts.
  4. Remove the thermostat housing to water pump feed pipe.
Thermostat mounting-2.2L engine
3.1L Engines
  1. Disconnect the negative battery cable.
  2. Drain the cooling system to a level below the thermostat housing.
  3. Remove the air cleaner assembly.
  4. Disconnect the surge tank line from the thermostat housing.
  5. Remove thermostat housing-to-intake manifold attaching bolt and nut, then remove the housing.
  6. Remove the thermostat.
3.4L Engine
  1. Drain the cooling system.
  2. Remove the air cleaner.
  3. Remove exhaust crossover pipe.
  4. Disconnect the surge tank line fitting from the coolant outlet.
  5. Remove the thermostat housing to intake manifold bolts.
  6. Remove the thermostat housing outlet and thermostat
  7. Clean the mating surfaces.
Nov 01, 2010 | 2003 Pontiac Grand Am
Location of thermostat on 2002 olds alero 2.2
Thermostat Removal & Installation 2.2L Engine To Remove:
  1. Remove the exhaust manifold. If equipped with an automatic transmission.
  3. Remove or disconnect the following: chevy_cav_02-04_tstat.gif
    • Thermostat housing to water pump feed pipe bolts. chevy_cav_02-04_feedpipe.gif
    • Thermostat housing to water pump feed pipe.
    • Thermostat.
To Install:
  1. Install or connect the following:
    • Thermostat.
    • Thermostat housing to water pump feed pipe bolt.
      1. Tighten bolt to 89 in lbs (10 Nm).
    • Exhaust manifold if equipped with an automatic transmission.
  2. Fill the cooling system.
2.4L Engine To Remove:
  2. Remove the exhaust manifold heat shield.
  3. Remove the coolant inlet housing mounting bolts through the exhaust manifold.
  4. Raise and safely support the vehicle.
  5. Remove the coolant inlet housing stud from the oil pan.
  6. Remove wheel and tire assembly.
  7. Remove the engine splash shield.
  8. Remove the mounting bolts from the transaxle-to-engine block support. Remove the support.
  9. Remove the coolant housing pipe.
  10. Remove the thermostat.
  11. Clean the mating surfaces.
To Install:
  1. Install the thermostat.
  2. Install the coolant housing pipe.
  3. Install and secure the transaxle support-to-engine block mounting bolts.
  4. Install the engine splash shield.
  5. Install the wheel and tire assembly.
  6. Install the coolant inlet housing stud to the oil pan.
    • Tighten to 19 ft lb (26 Nm).
  7. Lower the vehicle.
  8. Install the coolant inlet housing bolts through the exhaust manifold.
    • Tighten the coolant inlet housing bolts to 10 ft lb (14 Nm).
  9. Install the exhaust manifold heat shield.
  10. Fill the cooling system.
  11. Inspect the system for leaks.
3.4L Engine To Remove:
  6. Remove the thermostat housing outlet and thermostat.
To Install:
  1. Install the thermostat and housing outlet.
  2. Install the thermostat housing bolts.
    • Tighten the thermostat housing bolts to 18 ft lb (25 Nm).
  3. Install exhaust crossover pipe.
  4. Connect the surge tank line fitting to the coolant outlet.
    • Tighten the fittings to 15 ft lb (21 Nm).
  5. Install the air cleaner.
  6. Fill the cooling system.
  7. Inspect the system for leaks
Oct 14, 2010 | Oldsmobile Alero Cars & Trucks
Where is the thermostat located on a pontiac grand am 2004 v6 3400
3.4L Engine
To install:
  2. Install the thermostat housing bolts. Tighten the thermostat housing bolts to 18 ft. lbs. (25 Nm).
  4. Connect the surge tank line fitting to the coolant outlet. Tighten the fittings to 15 ft. lbs. (21 Nm).
  7. Inspect the system for leaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 23, 2009 | 2002 Pontiac Grand Am
Frigidaire Gallery Side by Side - Fridge not cooling
Locate the defrost timer and rotate the dial a small amount clockwise. If the compressor starts the timer should be replaced. If the compressor does not start check the temperature control. It may be bad, if it is bad try jumpering the thermostat wires. If it starts and runs the thermostat is bad. Replace the thermostat.
Mar 30, 2008 | Frigidaire FRS26ZSG
U-Line 2075RF Compact Refrigerator Logo
47 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
