Question about Garden
I have a Murray 20'' mower with a 3.5 HP B&S engine on it and for some reason I can get it to start, but it runs SUPER rough. I changed the plug, oil, and cleaned the carb and still it is running bad. Any ideas?
  • LeeatCSE May 11, 2010
    Have you changed the gas? Also could be an issue with the head gasket or valves.
Piston is cracked
Posted on Jun 02, 2009
I have a Murray 20 model 20213A with a Tecumseh engine. The lawnmower will start but it dies a few minutes later. What could cause this and where can I get a manual for this model lawnmower?
Use high test fuel without ethanol, and
Murray 22" Lawn Mower - Carburetor Cleaning, Nasty ...
? 7:33
www.youtube.com/watch?v=_dzcDZUh1MY
May 10, 2013 - Uploaded by mountainbikekayak But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
Sep 09, 2015 | Tecumseh Garden
Have a B/S model 31C700 Type0230E1 17.5 HP on a Murray mower and it will run smooth at lower throttle but when I throttle up it starts backfiring and runs rich. I have changed the fuel and fuel filt
I had a similar problem wit a 10hp B/S. It was the carb - needle valve/float sticking open and flooding. Tapping the carb body with a light hammer will solve the problem temporarily. When parked, mine also would overflow gas into the cylinder and from there into the crank case. Had to put in ma shutoff valve in the fuel line. B/S uses a poor carb sometimes.
Jun 16, 2017 | Murray Garden
Need manual for Murray 20" cut 3.5 hp Classic push
This engine is one of Briggs & Stratton`s basic engines, quite a simple engine, post your problem and i`ll answer,
If you really feel that you need a manual they are available through some outlets, try Wal Mart. or ebay
Jul 03, 2011 | Briggs & Stratton Garden
I have a Murray 6.0 hp 20 inch push lawn mower. How much oil do I put in when changing oil.
If there is a dip stick add some oil check the level till you get to the full mark. It should take a little more than a quart. If there is no dip stick then there is an oil fill plug down low on the engine. Fill slowly until the oil reaches the threads in the engine housing (almost overflowing). Be sure to replace the plug or you will have oil everywhere when you start it.
Don't just dump the oil in, check the level as you go!
May 20, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Need manual for Murray 20'' 3.5 hp lawn mower
sounds like its running out of gas. I changed spark plug, still sounds like its about to die
Apr 11, 2010 | Garden
Describe your Poulan "" Push
Please change your are filter,or clean it, I hope this helps you and thank you
Sep 10, 2009 | Poulan "" Push Mower
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Riding mower having problems starting then runs roughly
I would bet you have a fuel problem. Either the carb is clogged and dirty or needs adjustment. Try opening the screw on the bottom of the carbuerator about a half turn see if that improves it. Also check the air filter and clean it.
Jun 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Murray quattro ultra mower
Murray for the Mower and I imagine its a Briggs engine, go to Briggs.....If any other engine go to the maker of that engine.
Jun 04, 2009 | Garden
Garden Logo
306 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
