Question about Xerox ColorQube 8570dn Color Printer
How to set the 2 sided coping on the printer
    New Friend:
    Problem Solver:
  • 13 Answers
Basically, the healthcare.gov is powered by a healthcare software solution. This healthcare software solution is riddled with errors, and it is imperative that the government fixes those errors for a perfectly functional federal marketplace. Once this is fixed, the healthcare.gov will be in a much better position.
Posted on Dec 29, 2013
Is there a way to increase size of print off of what I am copying ?
Are you coping from your computer or just coping from the printer itself?
Mar 24, 2015 | Canon PIXMA MG3520 Inkjet Multifunction...
My PNY HCSD 8GB card wont read in any of the various photo printers ive tried it in but will read in cameras and computers. its not locked and the previously mentioned printers have no problem with any...
There could be many reasons for this problem..
1. The card is just too big - some readers can only cope with 2 or 4 Gb max.
2. The card's transfer rate may not be compatible - there are many differing speeds at which they can run and not all readers can cope with it.
Have you tried connecting the camer to the printer via USB? pic-bridge etc. will use the camer itself as a card reader avoiding compatability issues.
Hope this helps.
Jan 26, 2011 | PNY 8GB Secure Digital High Capacity...
RICOH Aficio 1013F coping
Check if your copier has DUPLEX unit installed, the Duplex unit is a optional component for copiers, seems that you don't have that option installed.
Feb 15, 2010 | Ricoh Aficio 1013F Copier
We can duplex copy but not duplex print on the KM Bizhub 250. When printing from the computer, in the Konica Document Properties Window on the Layout tab, when the Print Type pull down screen is activated...
Hello
See if you have selected weight paper from the tray in the duplex mode.
Weight paper is selected in duplex mode only from the bypass.
So you check that the paper in the tray 1 or tray 2 must be plain paper and in duplex mode it can print normally.
Jan 29, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Duplexing
Someone has changed the settings on the unit. If you go into Additional Functions press set on Common Settings scroll to Paper feed switch and set it for Speed Priority not Print Side for each category. The only other thing that would cause this is that each individual setting was set for 2-sided in which case you would want to check Additional Functions and each one Copy Settings, Printer Settings and Fax settings.
Nov 24, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Lost reverse side printing option
Yepperz
The double sided printing option relies on Status monitor working correctly. If information cannot travel from the printer to the computer, the option will be greyed out.
Make sure you have a direct connection to the computer without any hubs. If that doesn't work, try the following.
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS
2. Right click on your Epson printer name, and click CANCEL ALL DOCUMENTS.
3. Confirm cancelling all documents.
4. Right click on the Printer again, and select DELETE.
1) Click on START, SETTINGS and CONTROL PANEL.
2) Double click on the SYSTEM folder and select the Device Manager tab.
3) Click on the "+" for "Universal Serial Bus Controller"
4) Right click on "USB Printing Support" and select "Uninstall" and confirm it
5) Disconnect the USB cable and reconnect it.
Try Printing
Sep 07, 2007 | Epson Stylus R265 InkJet Photo Printer
Xerox ColorQube 8570dn Color Printer Logo
123 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
matt
matt
k24674
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
