Question about Air Tools & Compressors
I have a speedaire compressor that fell over and pulled the electrical cord from the motor. I've pulled the motor apart but I don't know where the black, white and ground wires connect on the plastic piece on the inside of the motor, please help
  • 62 Answers
Need a good picture of the place they go on to tell.
Posted on Dec 29, 2013
2 Suggested Answers
dmftrucker
  • 1922 Answers
SOURCE: when wiring up 240v of power to compressor what is
blk/red are your two 120 volt lines the white is your neutral, if this is a 120/240volt combination motor make sure you change the wiring in the motor configuration to make it 240volt from 120volt
Posted on Sep 25, 2009
How can I adjust the torque settings?
PDF]SD Compressor Service Guide - Sanden
www.sanden.com/productlibrary/manuals/sd_service_guide_rev_2.pdf
6.6.2 Suction Gas Condition. 6.6.3 Ambient ... Internal compressor pressure can be relieved by removing shipping caps ... Never leave PAG oil exposed to air for a prolonged time. Tightly ..... Place rotor pulley shaft protector (Puller set) over the exposed shaft. 4. ... Replace retaining nut and torque to specification. 1/2-20: 20- ...
Speedaire Air Compressors - About Air Compressors
www.about-air-compressors.com/speedaire.html
when i try to start my gas compressor it backfires why 5.5 speedaire by dayton, serial ... cant find cylinder head torque specs for 35w347 need the torque specs to properly break .... I also need to know how to change the oil on the 1z943b motor ...
[PDF]80 Gallon Industrial Air Compressor - Mi-T-M Corporation
Dec 08, 2015 | Air Tools & Compressors
Plastic cooling fan fell apart - where to buy replacement
is this the fan at the end of the electric motor
if it is they may be serviced from the manufacturer , but I go to motor rewind shops as they have a selection of motors and fans that may fit your motor
they may be able to get a new one for you
Oct 20, 2015 | Air Tools & Compressors
What will cause my compressor to start bogging down and trip the electric motor after reaching 30 to 40 psi? it has fresh oil and air filter. The electric motor also checked out ok.
It sounds like the run capacitor needs to be replaced. If yours is weak or defective the motors run windings will over heat and trip the overload. You can find replacements at "Drillspot". Another issue is using an extension cord that cannot handle the load.
Don F
Aug 24, 2011 | Ingersoll Rand - Rand Type - 30...
Husky Compressor Model WL660800AJ, S/N L8/4/04-00830 started, filled tank, cut off and now will not restart. I turned the reset switch to off overnight, but still will not start this morning. Power is...
All electric motor compressors have a reset switch somewhere on them, usually on the motor itself. Look for a small, usually white button, sometimes with a number on it. If its tripped the button will stick out, push it in to reset it.
Air compressors need a fair amount of amps to run and the requirement rises as the tank fill because the motor is working against the pressure in the tank. A rule of thumb is: always run longer air lines, NEVER use extension cords. If it is absolutely necessary to run an extension cord, make sure it's a 12 guage cord or larger, no more than 50 feet long.
Jan 05, 2011 | Garden
I need i shop manual for a dayton speedaire model 3z244d
The dayton brand is sold by Grainger.
Check for the manual at grainger.com they also have a cust. service number that maybe can help you...
heatman101
Sep 28, 2010 | Dayton Audio Dayton Speedaire Air...
I have a 2hp compressor motor that keeps tripping the breaker after about 5 minutes of use. i have changed the caps but it keeps popping the starter cap. is the motor just bad?
Our 2 HP Speedaire horizontal tank compressor is rated 115 / 230 volts at 24 / 12 amps, respectively. This means at 115 volts, a 30 amp circuit breaker is the bare minimum. That also means that the wiring should be #10 copper wires for short runs, but the next size up; #8 copper wires would be better connected to a 40 amp circuit breaker. Running at 230 drops the amperage requirement by half, to 12. A #14 copper wire is minimum for short runs with a double pole 15 amp circuit breaker, but #12 copper wires connected to a double pole 20 amp circuit breaker would be better choice.
If the compressor is cord connected (or even directly wired) with the minimum sized wires, it will likely a voltage drop problem unless very close to the panel. This problem is more pronounced as the distance between the circuit breaker and motor increases, or when smaller wires are in the circuit. All the voltage at the circuit breaker does not reach the motor, as it is lost as heat; so the compressor only sees 90 to 105 volts instead of the 115 volts it expects.
If the cords, connections, etc are getting hot, it is a tell tale sign of under-sized wires and /or poor connections. Once you solve these problems, the compressor should run "as advertised " because motors usually don't "go bad" but fail all at once. Unless you have a bearing problem - or there is a problem with the load itself (compressor).
I hope this helped.
Nov 12, 2009 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Hi - While being moved, Speedaire compressor (model 32180) fell on its side. Side opposite pulley and dammaged unit directly opposite of pulley. I have no idea what the unit is called or its function. Was...
Lee,
I'll email you the breakdown. The pump is probably actually a 3Z180, made for Speedaire by Champion. If you are looking for the assembly sticking out of the back of the pump, it is probably the centrifugal unloader, which vents the pressure after the compressor shuts down. You can get the parts from Grainger parts (888-361-8649), or your local Champion compressor distributor.
Nov 06, 2009 | Air Tools & Compressors
Can't find parts for a Speedaire Model 5Z705
not sure of a relay you are referring to but check Grainger for speedaire which they are sold there.
Apr 09, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
79 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
