Question about Mitsubishi WS-55613 55" Rear Projection HDTV
Horizontal lines in picture
My ws55613 has horizontal lines when we first turn on set. They disappear after a minute or two. This has been going on for a while, any suggestions?
  • 4,889 Answers
That's almost always due to RF interference from an electric motor. It doesn't even have to be close to your TV, just operating on the same circuit or near a poorly insulated wire, which acts as an antenna, injecting 60Hz (and harmonic) noise into the power supply.
If it's right next to the TV it will be even more pronouced because the RF interference resonates into the TV circuitry itself, not just the power supply to the TV.
Typically a high current AC motor like a vacuum cleaner, refrigerator, dehumidifier, air conditioner, furnace, etc.
Posted on Oct 18, 2007
Samsung 5271f. Picture usually great but sometimes when an image with horizontal lines appears (e.g. crawl at the bottom of the screen) picture jumps and flickers. Reverts back after crawl disappears.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Feb 12, 2017 | Samsung Televison & Video
Toshiba CZ32V61 no picture
1) you have problem with the Raster
2) the main causes are a) raster b) picture c) sound d) synch
3) since this are not video, the problem is raster. your must
test the voltage from section horizontal out +125vdc+vertical output +80v+all other circuit +12vdc
4) test the power supply for defective. see the diagram attached
Jul 12, 2012 | Toshiba CZ32V61 32" TV
Horizontal lines shadowed / blured picture after 20-30 minutes
There are some semiconductors or capacitors that are leaky. Might need thorough check up inside the TV.
Jul 07, 2012 | LG 55LH40 55 in. LCD HDTV
When first turns on, large black horizontal lines make picture unwatchable.
from possltd@hotmail.com the problem is the 3 thin ribbon wires that go to the lcd have become lose,or something else open top cover 6 screws 4 on the sides 2 on top must remove dark gray plastic piece have pic if needed Oct 4th 09
May 30, 2009 | Sony VPL VW10HT Multimedia Projector
KV36XBR400 fragmented picture horizontal overlapping lines
this will continue to degrade, almost any failure that can be affected or temporarily cleared up by hitting the set is caused by bad solder joints.
A good shop should be able to find and fix the bad solder connections for probably a little under $100
if you bring it to them and pick it up.
Feb 10, 2009 | Sony KV-36XBR400 36" TV
How to fix horisontal lines on display ( see the picture)? They stronger when system is restarted and then fading but never disappearing. They always stay the same.
horizontal lines can be caused by either a faulty grapchics card or a faulty monitor. try adjusting the screen refresh rate. if you are using a windows xp system goto
start>control panel>display>settings>advanced>monitor
then adjust the screen refresh rate and see if the horizontal lines disappear. if not, then you probably have a faulty graphics card or monitor.
Jan 27, 2008 | XFX GeForce FX 5200, Graphic Card
VW10HT screen filled with horizontal lines until unit warms up (5-10 minutes!)
I have a similar problem with our projector. It help to reverse the output for some reason. When reversed, all horizontal banding disappears.
Jan 22, 2008 | Sony VPL VW10HT Multimedia Projector
Horizontal lines
If you're having horizontal lines, you could try the steps below:
POWER RESET:
- Turn off camera
- Remove batteries for a minute
- Return batteries
- Turn on camera
MASTER RESET
- Turn on camera
- Press MENU button
- Scroll to the right until you see SETUP
- Scroll down and look for RESET
- Press right button so you could see YES or NO
- Select YES
- Press MENU button
- Turn off camera for a few seconds so that
settings will be refreshed
* If it still does not work, call the Manufacturer so they
could tell you how to send camera for repair.
Dec 10, 2007 | Samsung Digimax S500 Digital Camera
Curved horizontal lines in picture
Its Sounds like Convergence Circuit,If you take the Back off and look on the right side you should see a Board with Big black Ics Mounted beside a Large Heatsink,Mark the wires where they go and Make sure the POWER is Off Pull the Board out and Inspect the Connections from the ICS,you find Circle Breaks,They need to Be resoldered and That should fix the Set....
Jul 20, 2007 | Samsung PCK5315RX TV
Horizontal lines
If this model has a "lint screen" or air filter, I would check to make sure the set is getting proper ventilation. Otherwise, you probably have a bad solder connection or capicators going bad, causing your symptoms. Hopefully you won't have to get a replacement Printed circuit board as they are quite expensive.
Jan 02, 2007 | Toshiba TheaterWide 62HM84 62" Rear...
Mitsubishi WS-55613 55" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
