No audio on right speaker channel. i already check and relpace some of power transistors, i already check the resistors and capacitors.whats the problem of my amplifier?
    New Friend:
  • 62 Answers
It maybe a preamp for one of the channels thats faulty, try to see if you can find audio to the preamps with a small earphone piece. try & track your fault that way.
Posted on Dec 29, 2013
SOURCE: Output volume has dropped in right channel
dear sir,pls check the HT voltage fuse, LTsupplay also and out put stage,and volume controle,
Posted on Feb 01, 2007
SparkGap
  • 363 Answers
SOURCE: Audio Amplifier JVC Model A-GX3
If the service manual is not available on the JVC websites then you should just Google search "JVC A-GX3 service manual" There are many websites that archive manuals. You'll probably have to pay for a copy. Why can't you disassemble the unit and see the output transistor numbers first? More importantly how do you know this is the fault?
Posted on Sep 22, 2007
  • 319 Answers
SOURCE: Rotel RMB-1095 Power Amplifier Problem
Sounds like wiring problems. Unhook everything, then get owners manual for proper instruction
Posted on Apr 17, 2008
  • 398 Answers
SOURCE: How do I connect a subwoofer to an amplifier marantz pm-68
double up the speaker and then use the two extra screw to hook sub and center
Posted on Feb 27, 2009
petraman7
  • 1175 Answers
SOURCE: Proton 520 Integrated Amplifier with quiet left channel
Hi...
Flush all the switches and controls with De-Oxit D5 or better.
Then get back to me.
Thanks
Posted on Mar 01, 2009
I have a Pioneer VSX-305 receiver. I blew channel A speaker outputs by allowing speaker wires to touch while the output was on. Everything else works, including the B speaker outputs. There are only three...
There are independent relays for the speaker A and B switching.Best place to start would be from the relay. When you select A do you hear a click, if not relay is not switching. The circuit involved is a small transistor , a low value resistor ( could be the culprit ) and a shunt diode.
Aug 16, 2011 | Pioneer VSX-305 Receiver
No audio output
check whether the plugs are inserted properly and check whether the pins are working properly
Jun 20, 2008 | Kenwood VR-407 Receiver
Fuses on board blow after a minute or so after power up
Most likely the wire for the speakers, if you have them wired for a specified ohm that the amp doesnt support will cause the issue, as well as bad ground, cross connecting wires. I would start by removing all wires and connections, ensure they are clean and speakers are wired properly.
Nov 19, 2007 | QSC MX1500A 2-Channel Amplifier
Right channel sound is distorted
You most likely should remove the casing of your reciever and take a can of compressed air to clean it out start with that and also while you hvae it open look for any solder that looks messy or melted
May 24, 2010 | Audio Players & Recorders
Onkyo TX-DS696. No right channel speaker sound
hello there 2 transistor 1 for the right channel and 1 for the left first thing 2 do is a visual check in good light check for any burn't part or any bulging capacitors if everythink looks ok then check underneath the board for dry joints if then you will need a mulitmeter to start testing components
regards
shasun
May 15, 2010 | Onkyo TX-DS696 Receiver
I have bad static from my Pioneer vsx 49 Elite
sorry no easy solution as it sounds like the output transistors blew out or the emmitter resistors. you will need a service manual and an multimeter to measure the resistors on or around the audio output transistors they are a low value resistor usually around 1 to 2 watts in size. Do not replace any bad , burnt or discolloered resistors around the audio output transistors as if tou do you might just cause more damage to the output transistorsor audio output stage including the audio driver stage of the amp!!!!!!
Larry Dillon
Aug 27, 2009 | Audio Players & Recorders
Left output ports for both left and right channels do not work
Hi, first thing to do is to check the power supply look for a larger capacitor & using voltmeter measure both sides from ground to positive & ground to negative. Next check the speaker protection circuit if active. If not active measure the voltage from ground to the speaker output before the relay of speaker protection device. The voltage should be zero or close to zero volt. If more then the power transistor or power IC is toasted.
Aug 10, 2009 | Cambridge Audio Azur 540A Amplifier
Humming noise when turned on
Annebatiste:
Humming almost always comes from DC supply problems.A leaky SCR [silicon control recitfiter] transistor [used in a/c to dc power supply], leaky Capacitor [large metal type for heavy voltage\current], bad or value changed bias for SCR transistor, value changed filter resistor and loose transformer[Xformer] that the coils INSIDE vibrate sending a radio frequency [R\F] SIGNAL (like a radio station) into the audio amp section or right into the speakers causing the hum.
Check entire power supply, all filter capacitors, coils, chokes ,transformers (somtimes used to push signal into speakers)
Jun 28, 2008 | Samsung DLP HL-P5663W 56" TV
Bose acoustimass 15 series 1 channel loss
Sounds like you may have a blown output transistor or chip, which generally show no external signs of damage. This would take an experienced technician to find and fix, and I commend you for knowing to check the speakers, receiver and cables through substitution! If you're handy with a soldering iron and can find the parts, try replacing the output transistors or chips in question. These are what usually fail in audio power amplifiers - also check any power resistors for opens - some of them are designed to act as fuses to protect the more expensive components.
May 21, 2008 | Bose Acoustimass 15 System
 Grubhead
Grubhead
