Question about Microwave Ovens
Kenmore elite ultra wave microwave hood f9 error model 767-8529300 (LG)
At first could not set vent fan speed...rebooted and that was fine...then, could not cook for more than 6 seconds... removed control panel, tested door switches and replaced panel...rebooted again...now the turntable motor is on and oven light on when door is shut and start button does not work. I am thinking that this is a control panel problem but would like some input before I continue to test other components. Thanks
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave runs with door open
I would say you have a failing door switch or the mount which holds your door switch is loose or broken. In most designs, it is the upper door switch that will produce these very symptoms when it is intermittent or its mount is broken or loose. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. Slamming the door, damage during shipping or transportation and sloppy manufacturing techniques or materials are the primary causes of trouble with the door switch mounts. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 22, 2007
reg501
  • 413 Answers
SOURCE: Kenmore ultra elite microwave hood combination
F9 code can mean something different depending upon the particular model.....
1.) IF your Microwave uses "UltraWave technology"/"SmartWave technology"...Then either the Magnetron has failed or the Inverter board has failed OR maybe the control board has failed (HUH?).
2.) IF your Microwave does NOT use "UltraWave technology"/"SmartWave technology" then one or more of the door switches has failed.
** "UltraWave technology"/"SmartWave technology" **
I'll explain a few things about this wonderful technology...
The control board (accepts the pushbutton commands) has to talk to the inverter board to tell it how much power should be applied to the magnetron. The inverter board will then power the magnetron and inform the control board if the magnetron is working OK.
If there is something wrong with the magnetron or inverter board or a there is a communication breakdown between the control board and the inverter board...WA-LA-----F9----
A pretty reliable test for the Magnetron is to operate the oven and listen for a ticking sound 5-6 times about a second apart. If you can hear the ticking....The magnetron has failed..if no ticking, the control or inverter board failed.
Note: This 'technology' may come in other flavors as well
Posted on Jun 11, 2008
golu_fixya
  • 213 Answers
SOURCE: WHIRLPOOL MICROWAVE GIVING F-7 CODE
hello sir
you are right magnetron is fully interrupted....... but tell me  !. do you want to repair machine( 4 sec problem) 2. do you want to buy inverter , magnetron  please tell i am ready to help you sir
I believe that is a microcomputer board failure. You will have to replace this board. Website below.
I have gotten parts from "repairclinic" on line and they worked fine. I saved $600 on the last repair of an oven. Good luck.
or sir you can find and fix each and every type of code error
http://www.applianceaid.com/micro_faultcodes.html#WLP
Posted on Oct 18, 2008
  • 92 Answers
SOURCE: GE Microwave oven vent fan not working
You are correct the fan motor is either stuck or needs replaced.
There is no way to do this without removing the entire microwave. In case your not familiar with how microwaves work, there is a capacitor that is very large inside and can hold a charge even after it is unplugged for up to 24 hours, please take action to prevent getting shocked.
Posted on Sep 11, 2009
My Kenmore Elite Microwave Model No. 721.64683300 does not seem to be heating well and will shut off and flash an F9 code. What does the F9 code mean
Oct 07, 2009 | Kenmore Microwave Ovens
Kenmore Ultra Wave Microwave has no power
after removing the cover of microwave chk for continuty of cavity thermostat usually calld TCO(thermal cut off). it is located on top of the cavity and circular in shape.usually neutral wire goes through this 2 control board and this TCO is for protection of cavity from overheating.if this tco is open.then replace it.usually this happens when u cook for 2 long.
Aug 15, 2009 | Goldstar MV-1515 Microwave Oven
9Fp and microwave cuts off
F-9 means the inverter board has failed. A bad magnatron can also cause this code. Recommend replace the Mag. and inverter board.
Feb 27, 2009 | Kenmore 62622 Microwave Oven
F9 Error
You can find exploded views and order parts by entering your model number at the Sears parts site.
Dec 06, 2008 | Microwave Ovens
Microwave Ultrawave with Hood fan
You are right. f4 means shorted oven temperature sensor (RTD). Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Apr 04, 2008 | Microwave Ovens
Jan 19, 2008 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
43 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
