Question about Frigidaire Refrigerators
I have a Frigidaire model #FPE-24VWAL-0 side by side. I want to hook up the ice maker. I need some instructions.
  • Frigidaire Master
  • 4,654 Answers
Should not be hard to do if the existing parts ar there for the ice maker. The plug receptacle, dual water control valves and plastic tubing from the water valve. Let me know what you need help with, Sea Breeze
Posted on May 18, 2009
Ice maker sometimes makes ice and other times does not
When it does not make ice see if there is water in icemaker if not the water valve in back of ref
(its the thing the water line from the wall hooks to) needs replaced
Also check temp in freezer (should be about 0 to 10 degrees) IM's will not dump above 10 to 15 degrees.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 20, 2011 | Frigidaire FRS23KF7AW Side by Side...
On my Frigidaire Ref/Frzr Model number FRS6LR5ew5-Ice maker is not working???
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 07, 2010 | Frigidaire FRS23H7CS Side by Side...
Ice maker stopped making ice. Repairman replaced water valve yesterday-said bin would fill overnight-still no ice cant get repairman on phone Frigidaire FRS26znhD2
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Mar 27, 2010 | Frigidaire FRS266ZDSB Side by Side...
Can you tell me how to hook up a waterline for a refrigerater's ice maker?
Detailed installation instructions at http://manuals.frigidaire.com/prodinfo_pdf/Anderson/242008000en.pdf - Page 7
Please be sure to follow the instructions exactly as indicated and follow the safe procedures. Check for leaks every 12 hours after installation just to be sure there are no leaks.
Aug 30, 2009 | Frigidaire FRS26R4A Side by Side...
Water and ice not dispensing on Frigidaire side by side
We have a similar fridge were told that it has a resivoir inside that needs to fill with water before it will start to dispense water. Had to stand holding in the actuator for quite a while befrore it started putting out any water. Shoud be the same with the ice maker, but there is an arm inside the freezer that controls how much ice you get it could be turned off.
Jan 24, 2009 | Frigidaire FSC23F7D Side by Side...
Ice Maker in Freezer in side-by-side not working
CHeck to make sure your freezer is 0 to 5 degrees. If it is warmer than that the water valve wont open to the ice maker. Have you replaced the water filter?
Nov 15, 2008 | Frigidaire Freezers
Ice maker not working
what filter? drying filter? Water filter? Dust Filter?
Jun 24, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
100 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
