Question about Viper Security and Remote Start System (basic install included)
Check engine light is on since the installation on my 2006 chevrolet 2500 HD
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Since you installed what ???
Posted on Dec 29, 2013
Chevrolet diagrams
Mary, 2003 Chevrolet Silverado 2500HD suspension and steering diagrams. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
2003 Chevrolet Silverado 2500 Parts GM Parts Department Buy genuine GM...
2003 Chevrolet Silverado 2500 HD Parts GM Parts Online GM Parts Direct
Chevrolet Silverado 2500 HD Ball Joints eBay
How To Install Replace Inner Tie Rod Chevy Silverado GMC Sierra 99 06...
Aug 02, 2014 | 2003 Chevrolet Silverado 2500HD
2006 gmc 2500 hd sieara duramax diesal,reduced engine power light came on, what is the problem??
Unhook battery wait a few minuites reconnect battery should reset computer codes to allow you to get it to a repair shop.
May 25, 2014 | 2006 GMC Sierra
2006 chevy 2500 HD the trailer breaks don't work
the braking system is not installed a the factory just the wire from the plug to the fire wall you need to add the fuse and control box
Apr 21, 2012 | 2006 Chevrolet Silverado 2500HD 2WD
Repair steering column on 2006 Chevy silverado 2500 hd
The steering wheel has to be removed and further troubleshooting to replace or replace the column or wheel can be performed.For complete step b step procedure.Click the link below :----http://technoanswers.blogspot.in/2012/02/chevy-silverado-2500-hd-steering-wheel.html
-----------This will help.Thanks.
Feb 08, 2012 | 2000 Chevrolet 2500
How do i tell if my egr valve needs to be cleaned or replaced? I have a 2006 Silverado LT 2500 HD 4X4 6.6 LTR. Diesel. Chevrolet makes two different model engines. LLY and LBZ i think, can you tell me...
The EGR valve recirculates unburned Exhaust gasses to your Intake in order to increase Fuel Efficiency and lessen Emissions. What are the codes on your truck? The check engine light comes on when a sensor is out of range, or failing, and a code is stored. Autozone, etc. can check your code for free.
Feb 17, 2011 | 2006 Chevrolet Silverado 2500HD 2WD
My 2006 silverado 2500, 6.0 engine shows a code for bad o2 sensors, put 2 new ones in, check engine light still one, the code never goes away even after it is reset with the engine off. whats up with...
You have to reset the check engine light. It will erase all the bad codes that you have fixed. To do this, you have to remove the positive battery cable for a minute or so and reconnect. It should clear the check engine light..
Aug 30, 2010 | 2006 Chevrolet Silverado 1500 2WD
2006 Chevrolet Silverado 2500HD tail lights stopped working
I am having the same problem on an 04 2500hd there isa 15 amp stop light fuse inside the cab on the side of the instrument panel and a 25 amp stop light fuse under hood. you could also have a break switch issue the switch is located up on the break pedal linkage you should have power on the white wire when you push the pedal in (check with a test light) in my case I have a broken wire along the frame rail in the harness it is a light blue wire,
Mar 08, 2009 | 2006 Chevrolet Silverado 2500HD 2WD
Open Questions:
Viper 4806v won't program I am trying to install a viper 4806v two-way remote start/keyless entry in my automatic 2004 toyota camry LE 4cyl. I got the lock/unlock, horn, lights to work, and trunk pop to work. I can't seem to get the remote start to work. When I press the remote start button on the remote keypad, the car does not start and the headlights flash 7 times. Troubleshooting says 7 flashes mean a manual transmission mode error. This means I have to enter programming menu 3 and change the starter to automatic mode. When I follow the directions to get to menu 3, nothing happens because I cannot get to menu 3 when I hold down the control button after turning the ignition off. In other words, the control button is not working. The neutral switch is on like it is supposed to be. Kind of bummed about this. Could use some guidance. My wiring goes accordingly and this car does not have an immobilizer because I used a regular metal key to start it. This car has no alarm, just a stock keyless entry, trunk release, and panic button. Again, the problem is :The remote start comes in default manual transmission mode so I have to switch it to automatic transmission mode but I can't seem to enter programming. When I try to enter programming with the procedure followed using the control button, nothing happens. It does not chirp and the LED does not blink. I also cannot enter valet mode using the control button. When the car is locked, the LED blinks and stop blinking if car is unlocked ignition is turned on. I do not understand what is going on. VIPER 4806V Wires --->Camry Wires Main Harness 6pin connector H1/1 Red 12volt input (+) --> (+) White/Red at ignition Harness H1/2 Black Chassis Ground (-) --> Car Frame (-) H1/3 Brown 200mA Horn Output (-) --> Green/Black (-) at steering column H1/4 White/Brown Light Flash Isolation Wire --> NOT USED H1/5 White Light Flash --> Hazard Light Flash Relay Lt. Green Black wire (-) H1/6 Orange Ground when armed --> NOT USED Door Lock 3 pin connector 1 Blue 500mA Unlock Output (-) --> Blue Wire (-) white connector at driver kick panel 2 Empty --> NOT USED 3 Green 500mA Lock Output (-) --> Blue/Yellow wire (-) blue connector at driver kick panel Auxillary/Harness 24 Pin Connector 1 Pink/white 200mA Ignition 2 output/ Flex output (not used) --> NOT USED 2 Blue/White 2nd Status/Rear defogger output (-) --> NOT USED 3 Red/White 200mA Trunk Release Output (-) --> 5pin Relay Pin 85 (86 & 87 to +12V, 87a White/blue trunk wire toward dash, 30 white/blue trunk wire toward trunk) 4 Black/yellow 200mA Dome light Output (-) --> NOT USED 5 Dark Blue 200mA Status Output (-) ---> NOT USED 6 White/Black 200mA Aux 3 Output (-) ---> NOT USED 7 White/Violet 200mA Aux 1 Output (-) ---> NOT USED 8 Orange/Black 200mA Aux 4 Output (-) --> NOT USED 9 Gray Hood Pin input (-) ---> Installed at hood and Switch is open when hood is closed 10 Blue Horn input (Jumper set (-)) --> Green/Black (-) at steering column 11 White/Blue Activation Input --> NOT USED 12 Violet/White Tachometer Input --> Black/Orange wire on the Datalink Connector 13 Black Neutral safety/Parking Brake Input (-) ---> (-) Ground to metal frame of car. 14 Green/Black 200mA Factory Alarm Disarm Output --> NOT USED 15 Green Door Input (-) --> Red/Black Wire (-) (Door open indicator on dashboard) 16 Empty --> NOT USED 17 Pink 200mA Ignition 1 Output (-) --> NOT USED 18 Violet Door Input (+) ---> NOT USED 19 Violet/Black 200mA Aux 2 Output --> NOT USED 20 Brown Brake Shutdown input (+) --> Green/White Wire (+) at brake switch above brake pedal 21 Violet/yellow 200mA Starter Output (-) ---> 5 pin Relay pin 85 (Pin 86 & 87 is +12volts, Pin 30 black/yellow starter wire (+) at pin 8 in ignition harness) 22 Gray/Black Diesel wait to start Input (-) --> NOT USED 23 Orange 200mA Accessory Output (-) --> NOT USED 24 Green/White 200mA Factory Alarm arm output (-) --> NOT USED Remote start 8 pin Connector 1 Red/black 12v Constant Input for Acc and starter relay (+) ---> White/Red wire 12v (+) at ignition harness 2 Pink/black Flex relay input 87A key side (+) --> NOT USED 3 Pink/white Ignition 2/ Flex Relay output (+) --> Black/yellow pin 4 at ignition harness 4 Red 12V constant input for ignition 1 Relay (+) -->White/Red wire 12v (+) at ignition harness 5 Violet Starter Output (+) --> Black/White wire (+) at ignition harness 6 Accessory Output (+) --> Blue/Red (+) at ignition harness 7 12v Constant input for ignition 2 and flex relay (+) ---> White/Red wire 12v (+) at ignition harness 8 Pink Ignition 1 input/output (+) --> Black/Red wire (+) at ignition harness.
Oct 20, 2014 | Viper Security and Remote Start System...
See all Viper Security and Remote Start System (basic Questions
Viper Security and Remote Start System (basic install included) Logo
19 people viewed this question
Top Viper Home Security Experts
Will Halftowaite
jason
Kevin Daniels
Are you a Viper Home Security Expert? Answer questions, earn points and help others
