Question about GE Refrigerators
GE Side by Side Stainless steel Ice Maker water will not shut off
I have a GE Side by Side Stainless steel refridgerator which the water continously runs to the icemaker and will not shut off. The refridgerator is only 3yrs old. Does anybody know what is wrong?
  • olee45 May 18, 2009
    The model number is LSS25XSTA SS Thank you
  • 585 Answers
The fill valve may hae a chunk of debris such as rust in it. If you disconnect power and water, you might disassemble the valve if it's the type that was screwed together. If it's riveted, you'll have no choice but to replace. In either case, make sure you have a filter in the line so this does not happen again.
Posted on May 19, 2009
  • 1,543 Answers
If the icemaker has finished a cycle and stopped, or if you unplug the icemaker and the water will still flow in, replace the water fill valve. (the part the incoming water line connects onto) If you post your model number (located on the wall of the fresh foods section of the refrigerator) I'll look up the part number for you.
Posted on May 18, 2009
  • Carl Schulzetenberg
    Carl Schulzetenberg May 19, 2009
    The valve is a part number
    WR57X10032 which goes for about $50. The water line filter (pre-valve) that Bat1956 mentioned might be a good idea also. (available at hardware and appliance stores) A bump up on the rating would be appreciated. Thanks.
How do I shut down the water flow to the ice maker
There are three ways.
1. Shut water off to the fridge via plumbing valve.
2. Lift arm on ice maker or use on/off switch depending on ice maker model.
3. Unplug ice maker wiring harness. It won't be able to call for water.
It depends on why you want the water off. A make and model of the fridge would help so I can give you a more specific answer.
Apr 05, 2016 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE Profile water pouring from ice maker
shut off the water to the unit and sounds like either the disp switch is stuck or the water valve faulty.
Apr 02, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ice maker not working Water works fine in the door. (GE Profile side by side)
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
gfs4
May 29, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Profile refrigerator side by side, water and ice through door. Ice maker works fine, water will not shut off. Had to turn water to frig off.
The water inlet valve on the back where the water supply connects to the unit is stuck open. You may can clean the valve out and get it to closing or just replace it.
Dec 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile side by side with water/ice dispenser. The water is working but the water to make ice is not working, hence no ice. I had ice, used it all and then nothing.
I would try putting water in ice maker if it freezes ice maker is ok if so feplace water valve. careful only 4oz. of water in ice maker
Oct 16, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Profile ice maker stopped making ice
ice maker for ge profile wont' make ice.Unplugged elect supply from both waterin the door coil and ice maker coil.Plugged water in the door elect to ice maker valve coil and pressed water in the door input sw out front and got water to ice maker so this let me know it wasn't the solonoid valve.Got another ice maker unit plugged in and mounted waited several days still no ice.
Sep 27, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
243 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
