Question about Petzl Camping, Backpacking & Hiking
Asap petzl instructions - Petzl Camping, Backpacking & Hiking
Led light doesn't work
replace led light it went bad.
Feb 27, 2011 | Petzl Myolite 3 Headlamp
Petzl tikka plus torch repair
I understood that fixya was free from reading the word free all over the place. I wasted my time filling in the form to find out it was not free, but only 7 days free trial but you needed credit card details before. I will not be the first to write this and am tired of being told things are free when they are not. Do not mislead people.
Jan 05, 2010 | Petzl Tikka Plus
Facewest quiz
I believe you are looking at power settings, range compairson
Nov 11, 2009 | Petzl Tikka Plus
Petzl Tikka switch is not working properly. Light not steady.
Would you describe the light as flickering and fading perhaps? Are you using rechargable or Lithium batteries?
Here's an excerpt from a Petzl alert put out a couple of years ago. It may shed some light on your problem..
LED light sources are susceptible to being damaged by the use of lithium batteries due to the different characteristics of lithium batteries in discharge. This has meant that some people have had problems with their headtorches failing when using such batteries... Petzl have reported this problem and other manufacturers are expected to follow suit. However this does not affect all head torches...
There are problems being reported over the LED lamps in certain headtorches when used with lithium batteries. Incandescent bulbs will also suffer a reduced burn-time when used with lithium batteries although this is less severe.
This is because the lithium batteries have a higher output during discharge.
The benefits of a lithium battery are the increased burn time, especially at low temperatures over the traditional alkaline batery.
LR6 or AA and LR03 or AAA are the two size of battery litkely to be used in a headlamp.
Petzl are one of the few manufacturers to advise on this at the moment. Other manufacturers products will also be affected.
The following Petzl headlamps should not be used with lithium batteries:
  • TIKKA / ZIPKA range: TIKKINA / TIKKA / ZIPKA / TACTIKKA / TIKKA PLUS / ZIPKA PLUS / TACTIKKA PLUS / TIKKA XP / TACTIKKA XP / TIKKA XP ATEX / TIKKA XP HAZLOC.
  • MYO range: MYOLITE 3 / MYO 3 noir / MYO XP.
  • DUO range: DUO LED 5.
  • SAXO AQUA.
  • MYOBELT 3
  • DUO LED 3.
  • Oct 12, 2009 | Petzl Tikka Plus
    How to replace halogen bulb in petzl duo headlamp
    Easy enough. The grey rippled rubber ring around the glass is threaded. Grab it good and tight and twist anti clockwise and it unwinds like a tank track..
    Hope this helps...
    Sep 22, 2009 | Petzl Replacement Halogen Bulb for Duo
    Are Petzl climbing helmets ok to use @ OSHA worksite
    The Vertex Vent and Vertex Best are the only two of Petzl's range that are rated for commercial use. The rest are sport models..
    The link here is for their site..
    http://www.petzl.com/en/pro/helmets
    Any half decent outdoor/climbing shop will be able to sort you out. Don't be surprised though if shops don't stock the commercial range as therer's not a lot of turnover on it. A good store will be able to get in gear for you to try..
    Personally, I have come across a few people (tree surgeons and mountain rescue mostly) who will still choose the sport models for the lightness and less bulk but we always advise them not to.
    If you are in the EU then the ratings on Petzl's site will be correct but if you are in the US or AU then it would be worth checking the local regulations before purchase. I don't see it being a problem though, Petzl are globally accepted.
    Either way, it could be an insurance nightmare if there is an accident involving someone wearing gear that's not covered..
    Hope this helps..
    Sep 09, 2009 | Petzl Rock & Ice Climbing
    Petzl Tikka Plus Headlamp has a short and is eating batteries
    There's really not much that's serviceable in these things. Try cleaning all the terminals again but this time use VINEGAR instead of alcohol which does not neutralize the corrosion as vinegar does. Just dip a q-tip in the vinegar and swab it on the terminals, then with a dry one, swab up the excess. Then install all NEW batteries, do not mix old ones with new ones as the new ones cannot make the old ones work any better than they are used. If they still don't work, welome to the world of cheap products that are intended to be tossed when they quit functioning. Good luck. :)
    Apr 19, 2009 | Petzl Tikka Plus
    I need to disassemble Petzl Myo 3 - snapped cable
    i also have the same problem can you please give me instructions on how to disassemble it? thanks!
    Apr 10, 2009 | Petzl Myo 3 Handsfree Headlamps
    Hard had
    Yes, but it's not an industrial hard hat.. And you would be in breach of all sorts of insurance regs if you wore it on a site.
    Petzl have two in their range that are rated for commercial use, The Vertex Best and the Vertex Vent.. See the link below for more info..
    It's not worth the risk for a few quid less..
    Dec 02, 2008 | Petzl Altios Helmet
    One helmet gor various activities
    I see this has been here a while... But hopefully it can help. The only multisport helmet to hit the market recently is the Kong Scarab. We had a few in the shop here with mixed results.. It's rated for a bunch of sports though variously I got responses like "too heavy" "too hot" Too bulky" etc, depending on whether it was a climber, paddler, skater etc.. So I guess the answer is yes, it does exist, but it's not perfect...
    Dec 01, 2008 | Black Diamond Diamond Tracer Climbing...
    Camping, Backpacking & Hiking Logo
    49 people viewed this question
    Top Petzl Camping, Backpacking & Hiking Experts
    Tom Chichester
    ray gallant
    Are you a Petzl Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
